Can a DLE 55 carb be reversed?
I have a plane that first owner had a DLE 55 engine on it. I went to install my DLE on plane and found throttle cable on other side of my carb. Can I just remove the two bolts holding carb and just rotate it 180 degrees and put it back on? Would this cause any problems with engine? It will take a lot of work to relocate throttle servo and cable, hope to find easy fix. Thank you for any help you can give.
