DA50 Mounting Diagram
My Feedback: (9)
UT
In order to get my DA50 mounted to my Patty, I drew up a mount diagram. Mostly because it is not included with the engine.
After getting it complete I realized that there may be quite a few others here that may benefit from the diagram as well.
I have made a .pdf file of the diagram and made sure that the scan is very accurate. I will attach the pdf with directions for printing to insure that the print is as accurate for you guys as possible. With everything though, measure twice and drill once.
Hope you guys find this helpful.
Since RCU no longer supports .zip files, I renamed the extension to .txt to be able to upload it. Simply right click the below link and save as and then change the .txt to .zip and you should be good.
Jason
Jason
My Feedback: (21)
NY
RE: DA50 Mounting Diagram
SilverEagle2-RCU:
The file works good. As long as you save it as a .zip, you get the Microsoftword & the .pdf files. Just thought I'd let you know it works....
