NGK CM6 Spark Plugs
RE: NGK CM6 Spark Plugs
Here is where I buy mine: http://www.sparkplugs.com/more_info.asp?AAIA=&pid=3291
DC
Nope...CMR7H are resistor, but the threads are too long for most engines made for CM6s.
The 10mm resistor plugs, Champion RZ7C and NGK CMR7H, are used in the G26 and have longer porcelains than the CM6...
ORIGINAL: Antique
Are NGK CM6 plugs resistor ? Thanks
don't know about DA or CH but the 3W cap has a built in 1K ohm resistor.
dave
While you guys are on the topic of spark plugs, what's the best plug for my 4 year old Zenoah G23 engine, which has only had about 2 gallons of fuel through it. Thanks
DC
It takes a short thread plug, NGK BMR6 or equivalent, or use a standard plug with an extra washer under it...The piston will hit a standard plug and close the gap....
WY
[sm=eek.gif]OOPS somebody goofed.... BPMR6F crosses to RDJ6J or 7J. The others are a 3/4" hex with a gasket. The 6F is a 5/8" hex with a tapered seat.
Gotta watch them racers
My Feedback: (100)
TX
Help guys
I have a brison 2.4 gas model aircraft engine. I crashed my plane and broke the spark plug. I can't find out what NGK plug was in this engine. Help.
Thanks Roy
Thanks Roy
NM
Hey guys,
the NGK CM-6 is a little bitty spark plug. The BPMR6F is the right size but I have a bosch cap ignition from C&H. Where can I get an adapter to go on the CM6 to make it the same size as the other spark plugs to fit my engine. (BME 50cc) Thanks.
John Franklin
John Franklin
My Feedback: (24)
GA
Ralph has them, If you are wanting to use the CM6 in place of the BPMR6F
Same as this
http://www.rcuniverse.com/forum/m_76...tm.htm#7647148
Milton
Same as this
Milton
