THROTHLE LINKAGES
Old 11-18-2004, 11:53 PM
fredycompean
fredycompean's Avatar
Default THROTHLE LINKAGES
Hey everyone. I need suggestions on throtle linkages for a DA 100. I've heard that it should be plastic to avoid noice from metal against metal. But if so, which links do you guys suggest. Pictures are apreciated. I'll show you the set up I have.
Old 11-19-2004, 12:11 PM
Rodney
Default RE: THROTHLE LINKAGES
Yes, use non metalic pushrods. Ball joints are the prefered type connectors.
