gas oil mix results
My Feedback: (69)
AR
RE: gas oil mix results
Back in the day, I ran a 24x10 on my sachs 4.2 (was on an ace 33% 230), and I believe I ran 50:1 oil, I cant remember which brand though. Any of the good oils should be fine.
My Feedback: (32)
I specifically cannot answer the question but if you already did not look here is Air Hobbies web site. A quick look did not find it but maybe you could send an email to them
http://www.aero-sports.com/airhobbies/
Also. I think Ralph Cunningham works on these engines you could send him a PM. He's really good
RCIGN1 is his member name
BTW...that';s a gorgeous plane
Using the same plane as Flyingrzrback, but with a Precision Eagle Husky 4.4 conversion, I was using Motul 800 and Redline synthetics at 50 and 60-1 after finding that 32 and 40-1 was sticking the rings. The Sachs is on the same line as the Husky. That's been awhile, but the engine is still in good running condition with plenty of compression.
thank u very much bubba i appreciate all the help i can get ill send him a pm and i cant wait to fly the hurricane hopefully this weekend. thanks again
ON, CANADA
I have a Sachs 2.4 that was reconditioned (crank straightened) by Brison and they were specific about using a 60:1 mix as the sachs has a special alloy piston that requires less oil. They figured by using a standard 32:1 mix I was losing between 600 and 1000 rpm.
Barry
Barry
