Convert G-62 from magneto to Electronic Ignition
My Feedback: (32)
RE: Convert G-62 from magneto to Electronic Ignition
ORIGINAL: splais
Does anyone have any idea of the cost for this conversion and somebody that does it. thanks.
CA
The conversion is about the same cost. I recently had one converted by Ralph and I am very pleased. The weight is 4lbs4oz with ignition and plug. Not to bad for and old industrial engine.
I choose the mechanical advance, the reasoning is that it will have a more linear response than any electronic ignition made.
I recently purchased a converted G-62 from Ralph and a muffler for it from Abell RC. Ralph removes quite a bit of weight from the stock engine and mounts his ignition unit inside the engine backplate/mount. Like RTK, I have the smooth ball bearing spark advance. Ralph is a craftsman and it shows in this engine.
The Abell muffler is ruggedly built (TIG welded) and ships for under $50.00. It even includes drilled mounting bolts and safety wire.
I hope to run this combination this coming weekend.
Bruce
Bruce
WY
www.ch-ignitions.com
PN 131, $124.95, no maching, install it your self.
By the time you add in a battery very little weight savings on complete plane, but the balance will change as you move a lot of weight back from the nose.
My Feedback: (90)
A good friend just put the C&H unit on a G-62. Works very nice. I have several Sachs motors with C&H, and if I had a G-62, it would have somebodys electronic ignition on it. Sure helps smooth the idle, and just can't seem to get along with the spring starter.
NE
RCING1 or C&H. Both are top notch conversions, Both are top notch people to do business with.
I would give each a call, and see what one would best address your needs. I will say that you will be 100% satisfied with either one, as they are both "old school honest gentlemen to do business with".
CA
ORIGINAL: Top Thumbs
I did conversion G62 with our auto advance ignition, new prop hub ( for save more weigh)and AL muffler . after all done, the new G62 are only 3.67LB, use one cell Li-po battery supply the ignition . total cost about 80 bucks.
VA
