"Calling All "WALBRO" Experts"
Reply
Old 11-06-2005, 03:01 PM
tande
My Feedback: (48)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default "Calling All "WALBRO" Experts"
I've noticed that some "Walbro" carbs. use a check valve in the high speed fuel circuit spray/bar (just before the fuel is released into the air/stream---& of course some don't)---My guess is this is to prevent air back/bleed into the fuel reservoir when not operating on the high speed circuit---Can anyone discuss this & the criteria used to decide when this style carb. is beneficial & when not?---
tande is offline
Old 11-06-2005, 03:32 PM
Antique
Antique's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: "Calling All "WALBRO" Experts"
The REAL expert on Walbro carbs is in Cass City, Michigan, at the Walbro factory...His name is Luis Salas...He KNOWS Walbro carbs....
Antique is offline
Old 11-06-2005, 06:15 PM
rmh
rmh's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Not being an EXPERT - I have to ask which model carb you are concerned with .
I run into some odd stuff on these carbs from time to time and find that some "Walbro " types (Tillotson/Bing) use a different approach to some of the features. Some good ---- some not so good for model airplane engines.
rmh is offline
Old 11-06-2005, 10:05 PM
captinjohn
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I am no expert also.......but i do have a Walbro carb book. I will see what it says about the check valve. Regards......Capt,n
captinjohn is offline
Old 11-07-2005, 02:20 PM
tande
My Feedback: (48)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks Guys for the response!---For those who care, I just talked with Luis Salas at "Walbro" (Thanks to RCIGN1 for that tip!) & he confirmed that the check/valve is indeed designed to prevent air back/bleed into the fuel reservoir where it CAN mess with idle circuit fuel calibration---Said his personal opinion is that ALL carb models should have it & knows of many in the racing world who modify their carbs to use it (Sounds like the spray/bar-check/valve is available as a service part---forgot to ask---oh well!)---Now why does all this concern me?---Well, I have two YW48 twins (Nice engines aside from this particular complaint) that I cannot get to idle down in the air, to set/up for a landing (Idle sounds like maybe 3000 RPM, who knows)---After they are on the runway & come to a stop the RPM's will drop right down---Seems as though it has something to do with the engine being "Windmilled" by the prop while moving through the air & I am wondering about the low speed mixture "Leaning out" with the throttle pulled back---I can somewhat help the condition by adjusting the low speed mixture to the rich side but then the midrange & transition falls all apart!---Thought about the spark advance curve not cooperating---Talked with "Terry" at "C.H. Electronics" & agreed it might be a possibility---Tried one of their (C.H.) spark advance circuit boards---No dice!---Any thoughts Guys!--
Thanks to all---
tande is offline
