"Hard Solder" for Aluminium
Reply
Old 05-14-2006, 03:06 AM
ukmike
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default "Hard Solder" for Aluminium
I have several JMB silencers and notice that the joints are made with what they call "Hard Solder", the appearance resembles that of a very smooth soft solder joint, not at all like a TIG weld.
My question is this. Does anyone know how this hard soldering is done and can it be purchased for home use?
I have tried the types that need a stainless steel wire brush and a filler rod that has to be applied by a scratching action. The end results are very ugly and altogether not very good.
Were the hard solder system available then I think it would be much simpler to make bespoke silencer systems for our engines as well as repairing damaged ones.
As a matter of interest, Tony Clark lists what may be the type in his Practical Scale catalogue.
Thanks for reading this, any info most welcome.
Mike
ukmike is offline
Old 05-14-2006, 02:52 PM
tail strike
tail strike's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: "Hard Solder" for Aluminium
I googled hard solder came up with www.ring&things.com
they talk about hard and soft solder check it out.
I.m watching you Larry
tail strike is offline
Old 05-14-2006, 03:02 PM
tail strike
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I'll try to send this page on hard solder.
For get-bout-it, not supported.
Old 05-14-2006, 05:48 PM
tkg
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
www.alumiweld.com
tkg is offline
Old 05-15-2006, 06:33 AM
ukmike
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi tkg.
Thanks for the info.
Unfortunately that is the type that uses the stainless steel wire brush then scratch/rub the filler rod onto the work.
The type that JMB and some other manufacturers use produces a very smooth joint very much like a soft solder joint.
I have tried the aluweld system, and several others like it, without much success, but no doubt others will extol its virtues.
Regards.
Mike
ukmike is offline
Old 05-15-2006, 08:52 AM
BillS
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Jewelers use hard solder and it comes in three types, soft, medium and hard. Soft melts at about 1100* F and hard at about 1600* F. Maybe a Jeweler will sell you a small quantity to experiment. Strength comes from close fitting overlapping joints.
Bill
BillS is offline
Old 05-15-2006, 11:49 AM
ukmike
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi Bill
Do jewellers solder aluminium (aluminum) ?
Mike
ukmike is offline
Old 05-15-2006, 05:05 PM
BillS
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I think a Jeweler uses hard solder mostly for gold and silver things but they do fix other trinkets.
Bill
BillS is offline
Old 05-15-2006, 05:54 PM
ukmike
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Bill.
I'll call some jewellers tomorrow, maybe they will be able to help.
Thanks.
Mike
ukmike is offline
Old 05-15-2006, 08:16 PM
rmh
rmh's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The process is brazing at those temperatures - The product may be called solder but the process is brazing
Soldering ends at about 550 F
The problem with aluminum is that its surface oxides immediately after cleaning - this is what protects it Anodizing is a better protection but plain old aluminum lasts a loooong time
Also it is difficult to make aluminum rust ---
rmh is offline
Old 05-15-2006, 08:57 PM
BillS
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Yes it is a brazing process.
Bill
BillS is offline
