Engine makes loud intermitent pop noise in flight?
I have already put a galon of fuel trough my DA50 . The engine runs flawlessly, It starts easy (When I don´t mess up the procedure), It has fast transition, a very low and reliable idle and very good power. However it makes an strange loud pop noise during flight only. I have adjusted the needles and because how the engine runs I believe they are OK.
What do you guys think is the reason for the pop noise. I was told it should go away as the engine breaks in but it is kind of annoying. I don´t think I have an air flow issue with the cowling because the engine behaves well not matter if it is inverted, in knife edge or any other attitude.
Could it be too rich or too lean in the low end ...?
Andres
Andres
PA
RE: Engine makes loud intermitent pop noise in flight?
low end needle settings are just that used at low end, they work into transition at mid range. High is also just that, used at top end and worked into at transition. Your popping noise as long as you have not overleaned the engine which if it runs well you have not, is completely normal. I believe the DA manual even states this. It takes three to four gallons before it gets better or even goes away. By the way enjoy the noise it screams out in the air HEY I Am A DA.
DC
A loud popping noise is normal??
And it gets better after running a few gallons of fuel through it ?
A smooth regular exhaust note is all that should come from an engine, other noises are definitely not normal...I don't care who says it is, DA or anyone else......Sheesh....
P T Barnum was right
Breaking in an engine changes nothing, just makes it looser...Vibration levels come from the weight of the internal parts, there is no change in rotating weight with more time on it an engine...An engine might seem to be smoother when the carb is adjusted properly from the CYA rich "factory" settings...
This stuff gets better all the time
Well,
I am lost here. The engine sounds perfect on the ground and it only makes the noise in the air (high speed) so it has to be something related to air pressure in the cowl. Maybe I should try the carb plate modification or running the pressure line inside the fuse. This is my first gasser and in my area there is not a single gasser so I don´t have anything else to compare with.
If the engine was going rich in the air would it make a similar noise?. Now that I think about it, there is some kind or burble (not much) together with the intermittent pop noise.
I appreciate the help.
Andres
Andres
ORIGINAL: RCIGN1
Bill
PA
ORIGINAL: RCIGN1
och
pop noise is its just a bit rich and and fuel is ingiting in larger volume thats all its anoying what i did was adjusted high first then back off 100rpm then adjust low to get a smoth transition .
good luck it should be right mate .
My Feedback: (61)
NJ
ORIGINAL: srm99
och
och
A smooth regular exhaust note is all that should come from an engine, other noises are definitely not normal...I don't care who says it is, DA or anyone else.. ....Sheesh....
The purpose of these threads is share knowledge and help people in the process. If you know so much about engines as you probably do the least I expect from you is a helpful post not one that has nothing to do with my question and makes fun of other´s people opinion which is even worst.
I would still like to hear a possible cause for the noise though......
Andres
B-MCCOR8
This popping sound he expresses is very typical of every da-50 for the reason yes you run it a little on the rich side during break -in. He never stated and vibration problem. After 3-4 gallons of fuel when the mixture is leaned and the high mixture is also leaned the pop will no longer be there.
Thanks for your help.
Andres
quote:
ORIGINAL: srm99
och
Exactly! Besides being slightly rich isnt necessarily a bad thing..I have 30 gallons thru my first one and it still burbles once in awhile but it runs like a champ!
ORIGINAL: srm99
och
Thanks everyone,
Andres
DC
Hey Mccord
From one clown to another (and all other engine experts out there)
check out this web site....
www.mototuneusa.com/break_in_secrets.htm
Maybe the guy who answers the phone at DA should read it too
My answer was for Mccord, not Andres...I ALWAYS set the needles when flying a new engine and have never heard a popping noise..And no, I do not own a DA50..I did, however, test one of the very first DA50s, got it from Dave himself, leaned it out properly...NO popping noise...
CA
The "popping noise" I assume is 4 stroking. A rough running engine that does not sound smooth, but I would not really call it a popping. If there is a real "POP" you have another problem.
No matter what anyone says, RCIGN1 is right. IT WILL NOT GO AWAY BY RUNNING A LOT OF FUEL THRU IT.
You have to adjust your needles to change a rich condition, if it is 4 stoking. Running 5 or what every how many gallons of fuel thru it will not help.
With modern metallurgy and machining heat cycling is really not that big of deal. Seating the rings over time due to frictions is what you want.
Set your engine 100-200 rpm on the rich side from day one and run it.
By the way, the term "loose", as apposed to women, refers to a very well broken in engine that has many hours on it and is producing max power. I believe the racers use this term.
PA
ORIGINAL: RCIGN1
Hey Mccord
Hey Mccord
CA
Not to sound mean, but there sure is some one that is unarmed. Dissimilar metals WILL ALWAYS have dissimilar expansion rates, even after break-in.
Breaking in is using friction (friction causes heat) to seat the rings and too much heat is not a good thing.
DC
A company that has to recall a few thousand engines because of NOT enought testing might just be a little suspect about recommendations relating to break in....
PA
ORIGINAL: RTK
now you are starting to understand. Breaking in, (rich) burble more oil and fuel. expansion rates (friction). Seating, less friction= fuel leaner no burble. Now you can see the process.
PA
ORIGINAL: RCIGN1
My Feedback: (61)
NJ
ORIGINAL: b-mccor8
Let me know what you mass produce and sell; your qualifications and I will be sure to buy my next engine from you.
CA
Yes, but you said earlier that the burbling will go away with more run time (fuel you burn) and I don't want anybody to think that is so. Only the needles will stop or cause burbling, not more breaking in.
There is one other cure for burbling, THE BOX. But it has nothing to do with needles and is not pertinent to this conversation yet.
ORIGINAL: b-mccor8
ORIGINAL: RTK
CA
ORIGINAL: b-mccor8
DC
I don't mass produce engines, just make the best ignition conversions for Zenoah engines, a company that has been making RC airplane engines far longer than any other current manufacturer..Zenoah was selling airplane engines when Dave Johnson was still polishing gemstones...Closest was Quadra, seen any of those advertised lately ?..NO Zenoah has ever been recalled for the wrong con rod design or putting the pulse port in the wrong place...
RCIGN1 is absolutely correct in post #2.
It sure did not take long for some who are lesser informed to get their panties in a wad.
No engine is supposed to pop, spit and hiss at you. A “strange loud pop noise during flight” is not OK.
Bill
Bill
