First Mintor 3M 110cc engine in North America
Reply
Old 09-19-2006, 02:13 PM
  #51
Aladdin
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: First Mintor 3M 110cc engine in North America
http://www.gajnervesa.it/motori_sergio.html
Sergio is a crazy guy!!
Marco
Aladdin is offline
Old 09-19-2006, 02:45 PM
  #52
wingburner
wingburner's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
According to my measurements,the 110cc has the same firewall mounting dimensions as the DA 100...The 110 engine is shorter from backplate to prop hub by 16 mm...The prop hub bolt pattern is also the same as 3W and DA.....The end of the center bolt is also tapped for 10\32 spinner bolt.
wingburner is offline
Old 09-19-2006, 07:01 PM
  #53
mikaelmiki
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
i currently fly the 75cc twin with a world models 29% katanaS
Its the old version with different muffler tips.
I have a new 75cc coming for a Fedon Aircraft Extra 300s in redbull scheme.
Im luigi's son
Mikael Fedon
mikaelmiki is offline
Old 09-20-2006, 06:01 AM
  #54
4REDave
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I can hardly wait to see what the 150 will do. I'm thinking in a 40% Yak
4REDave is offline
Old 09-20-2006, 04:35 PM
  #55
CiprianGugu
CiprianGugu's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I just don't like the carb intake's position.
CiprianGugu is offline
Old 09-28-2006, 08:52 PM
  #56
RVM
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
So, any updates for this beautiful engine?
Quote:
ORIGINAL: wingburner
Thought a few of you would like to see some pics of the new Mintor 110cc.
Jack
RVM is offline
Old 09-28-2006, 10:15 PM
  #57
wingburner
wingburner's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I believe the first 3 sizes,the 150,110 and 75 are in production now....I just received a new updated version of the 110 in exchange for my first one....I has a different carb block mount and intake to allow a better midrange...I tested it on the bench and it turned the same prop at the same RPM as the first...
The gentleman that's building my Carden Yak has it now for measurements and such...I don't believe it will be finished before the snow falls....Unfortuneatly[]
So I'll be left drooling till spring.
Jack
Old 11-13-2006, 10:19 PM
  #58
vbortone
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I have a Mintor 140 since 2002 that probably has more than 1000 flights. The Mintor 140 glow has been one of the best engines I ever had. I also ordered one Mintor 110 cc that should come in the next two weeks for my new IMAC project. I will try to translate the manual. My roots are Italian and I can undertand a little. However, I have a good friend that teach Italian and I will ask for help to translate the instructions. I will post the most important sections here as soon as are available.
Regards,
Vicente "Vince" Bortone
vbortone is offline
Old 11-13-2006, 10:52 PM
  #59
wingburner
wingburner's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi Vince,
That will be great....Will you get your 110 in the air fairly quick or will you be till spring also.
Jack
Old 12-09-2006, 12:53 PM
  #60
felker14
felker14's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Vince
You get engine yet?
felker14 is offline
Old 01-31-2007, 10:50 PM
  #61
felker14
felker14's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
What is distance between 2 headers (where they bolt on)? Wondering if its wider then DA-100?
felker14 is offline
Old 03-05-2007, 11:33 AM
  #62
vbortone
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I started the Mintor 110 cc first time in the back yard yesterday. It was very easy to start. Just follow the instructions and make sure that the carburetor is getting fuel. The high end in my case is around 2 1/2-3 turns out. The manual says 13/4 but I found that setting is too lean. The low end was better in the middle that was the initial adjustment. I used a couple of tanks and at the end of the second tank; the 28-10 was turning at 6800 RPM. The engine sound great (it is soft mounted) and idle is reliable. Transition could not be better and I would like to check it in fly. I am planning the first fly any time soon. Here some pics,
ID:	635697   Click image for larger version
vbortone is offline
Old 03-08-2007, 10:21 AM
  #63
vbortone
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I found that the ceramic filter was causing the problem in the high end setting. My suggetion is to be careful wiht the filter type you are using. I took out the ceramic filter and the engine is running well with the 13/4 turns out now. I will do in fly break-in and I will update of final results when the engine is fully broken-in.
vbortone is offline
Old 12-30-2007, 09:11 PM
  #64
sisu
sisu's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi Vince
This is TimGastinger
How did the Mintor 110 turn out?
Tim
sisu is offline
Old 12-31-2007, 06:40 AM
  #65
Tired Old Man
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I'm another that's interested in the final outcome of this engine. We need another twin manufcaturer in a bad way and the Mintor could fit the market nicely if the quality, weight, and power output are in order.
So how are they working out?
Tired Old Man is offline
Old 11-22-2008, 02:54 PM
  #66
DKjens
DKjens's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I just picked up a 3M Mintor 150B4 with ignitions, I desperately need some instructions, heck, I don't even know how to hook up fuel and the remote needle to this thing. I also need to make a header system for it but I think I've found some Krumscheid flanges that'll work.
If anybody has a lead to where I can talk to anybody who knows about this/these engines, please contact me: dkjens0705@yahoo.com
DKjens is offline
Old 11-24-2008, 08:27 AM
  #67
Alexzzz
Alexzzz's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
It's a beautiful engine for sure
Alexzzz is offline
Old 09-09-2009, 05:30 PM
  #68
Mavpro
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I got my new Seb Art Su 29 2,6 yesterday (a beautiful kit). I had planned on mounting my 3W 106 into it. That was untill I went through the mounting instructions, and discovered this fantastic Mintor on the pictures. Now, I really have to get my hands on this engine. Awesome.
Mavpro is offline
Old 10-16-2009, 12:43 PM
  #69
Pontiac_40
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Mavpro, did you ever get your Mintor?
Pontiac_40 is offline
Old 10-16-2009, 02:12 PM
  #70
Mavpro
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
No, I didn't. I tried to sell my 3W, but no one wanted it. Now, it's resting in the SU. Too bad, since I really wanted the Mintor.
Mavpro is offline
Old 12-08-2010, 05:26 AM
  #71
luvthestang
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hello all looking for some updated info on the mintor 110. What's the verdict?
luvthestang is offline
Old 12-09-2010, 07:34 PM
  #72
flyinrazrback
flyinrazrback's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
There are several threads on the FG site about the 110.
flyinrazrback is offline
Reply
Display Modes
