DA 50 ignition test
ON, CANADA
DA 50 ignition test
Is there a way to test the ignition on a da50 I had a dead stick for the first time and now it won't start. This motor ran perfect with about 3 gallons through it. Can i remove the plug and ground it to the motor while flipping the prop. I checked the battery and its fine i also replaced the plug with a new one. is there something else i can do before sending it in Thanks
My Feedback: (61)
NJ
RE: DA 50 ignition test
You dont have to ground the plug..its already grounded thru the ignition cap/wire..If you want to test it an easy way is to turn the light out and spin the prop..its easy to see with the lights out..also sometimes you can hear the spark as well..Also check the power pole connectors to make sure there is a good connection..that seems to be a problem for a lot of people.
DONT FORGET YOU MUST SPIN QUICK AS I SURE DA HAS A SAFTEY THING EASER IS GET A MAGNET AND MOVE IT FAST NEAR THE PICKUP SENSOR .
FL
No need for complicated tests. Just take the spark plug wire off, stick your finger in it and spin the engine rapidly. If the ignition is working you will know [sm=lol.gif]
Better yet, get rid of that DA unreliable dog of an engine and get a Zenoah. The self contained ignition system is 100 % reliable and never has any issues. The DA is a very unreliable engine and a pain in the arse to deal with compared to the Zenoahs.
JettPIlot
JettPIlot
ORIGINAL: JettPilot
JettPIlot
JettPIlot
around around the merry go round
u just love to stir lol
My Feedback: (61)
NJ
ORIGINAL: srm99
ORIGINAL: JettPilot
JettPIlot
JettPIlot
LOL you are so right..
My Feedback: (19)
ORIGINAL: Josey Wales
ORIGINAL: srm99
ORIGINAL: JettPilot
JettPIlot
JettPIlot
Cheers!
Lee
Before you stick your tongue on the ignition wire to test it. . . check the power pole connector that connects the ignition to the battery. Vibration in many cases breaks off the wires in the connector. Inspect both red and black connector pairs for good contact before checking the ignition module.
Tony M.
My Feedback: (23)
FL
You guys laugh about the tongue thing...I was working on a GTO I had, hooking up a dwell/tach meter. The engine was running at idle. One side of the meter goes to the negative terminal on the coil and the other side goes to ground. I had hooked up to the coil post and was trying to get the ground hooked up to the air cleaner stud. Well, I had the meter in one hand and the insulating boot on the ground wire kept me from getting it on the stud...SOoooooo, I used my teeth to pull the ground clip out from the insulating boot...Let's just say that was one heck of a jolt!
