Taurus 52 experiences
Old 09-17-2010, 02:48 PM
  #126
closetguy
My Feedback: (13)
Default RE: Taurus 52 experiences
it is a walbro 76B,i like the carb because you can go very rich or very lean on both needles.i replace the carbs on both da50's with this carb.
Old 09-17-2010, 03:02 PM
  #127
Truckracer
My Feedback: (19)
ORIGINAL: closetguy
Oh no, you let the secret out!
Old 09-17-2010, 06:23 PM
  #128
w8ye
My Feedback: (16)
w8ye's Avatar
The Walbro WT-76 is the carb used on the 52cc Dolmar chain saw
It has no options except a choke
No high speed nozzle etc.
If it works and has a good midrange, that is what's important.
Old 09-17-2010, 08:42 PM
  #129
Truckracer
My Feedback: (19)
ORIGINAL: w8ye
It works extremely well ..... even the the WT-76 and WT-76A versions ... all good. Rcign tried to tell people many times that this carb was a good one .... few would listen. Brison used this same carb on the 2.4 and 3.2 engines ... great results. May have used it on other engines ... not sure. Taurus uses it on the 3.2 ... maybe others, again not sure. You can't argue with success. Far better carb than the Wt-201 used on the DA-50. On the other hand the current carb used on the DLE-55 seems like a darn good one and its cheap.
Old 09-19-2010, 08:14 PM
  #130
closetguy
My Feedback: (13)
anyone know what is the difference from the 76b to the 76 and 76a. i just went and look where i get my carbs from and the 76b is no longer stock.
Old 09-19-2010, 08:44 PM
  #131
w8ye
My Feedback: (16)
w8ye's Avatar
Typically this involves minor differences as to the throttle arm, purge pump, angle of fuel inlet, etc
Old 09-20-2010, 07:12 AM
  #132
closetguy
My Feedback: (13)
Thanks Jim.
Old 09-20-2010, 08:58 AM
  #133
Truckracer
My Feedback: (19)
ORIGINAL: w8ye
I have engines with all 3 versions of the WT-76 and though I have not compared them for the exact differences, I did note that 2 of the versions were made in different countries. That was Mexico and Japan. One version had different length needles. They all run pretty much the same with needles that have a nice broad range of adjustment and good idle ... midrange ... HS transitions.
Old 09-21-2010, 07:54 AM
  #134
closetguy
My Feedback: (13)
Thanks that is what i wanted to hear.
Old 09-21-2010, 09:18 PM
  #135
rcdude7
My Feedback: (264)
Just curious, has anyone here run the TS-42? Is it as fine a engine as the 52? Does the 42 use the same cyl/piston as the old brison 2.4ci engine?
Old 09-23-2010, 12:40 PM
  #136
fujiman
My Feedback: (133)
how about the wt-76-1???????? is this an updated version of 76a and 76b????????? anyone know?????
Old 09-23-2010, 01:37 PM
  #137
w8ye
My Feedback: (16)
w8ye's Avatar
ORIGINAL: fujiman
Most likely all you will come across. It is just the basic carb
Old 09-23-2010, 04:00 PM
  #138
Tired Old Man
The TS-42 was discontinued long before the company stopped doing business. The 2.4 and the 3.2 were almost the same size and weight, negating advantages in those areas for using the engine. Taurus did not use the same cylinders Brison did, at least not on the TS-52
Old 10-05-2010, 01:55 AM
  #139
fujiman
My Feedback: (133)
just bought and received a wt-76c, ordered a wt-76-1 and got the ''c''. the needles are rather long and had plastic adjustment stops on them(C.A.R.B. SPECS MAYBE??????????). fuel nipple is brass and is straight. internal pulse channel. my taurus 52cc has a wt-76a on it. runs great!!!!! i'll try the ''c'' on my shindiawa 45cc weedy engine. i'll let you know how that goes. FORGET CHINA let's keep Bill going, let's buy taurus engines, can't beat 'em. if you take good care of them, you better put them in your Will because you'll be pass'n 'em on.
Old 09-25-2011, 09:29 PM
  #140
nitro wing
Been flying my Taurus 52 all year, so reliable and wanting to perform ALL the time. Its fun, powerful/smooth and sounds great and sips the gas, ans starting it is a non issue, I doubt I wear will this thing out.
I do have a DLE 55 in another plane, it has no proper runtime on it, but initial runs do indicate that it will be different and is more like a barrell of firecrackers.
Old 09-26-2011, 12:11 AM
  #141
fujiman
My Feedback: (133)
i have 2 52's and a 72. i can tell you they are well worth the money. they mite not be the cheapest eng. going but i think that they are the best. properly adjusted and not run on sandy, dusty runways, etc., i doubt you could wear one out for many, many years of use. you should probably put it in your will. they are certainly well worth every penny!!!!!! taurus engs. is hurting tho because of the china invasion and the down turn in the economy and not because of issues with there engs. and that is for sure. Bill O. of taurus engs. is a stand up guy and deserves our support. to lose taurus engs. would be a travesty and a shame!!!!!! rock on Bill O.
