540edge 33%
My Feedback: (40)
RE: 540edge 33%
hrmm there's a title that makes sense *scratches head*
Have you gone through all your plumbing to make sure you dont have a cracked line or hole in one? A tiny hole will make it hard to pump gas. I would maybe hook a line directly to your gas can and see if you can pump from it. If you can then you know you need to redo your plumbing.
My Feedback: (41)
RE: 540edge 33%
Some other reasons your Edge 33% is not flying ( ) Your carb is gunked up and a flapper in the pump is stuck from sitting too long....or your choke plate is not seating tight on the carb induction barrel. To free the flapper, pressurize the tank with your fill pump and flip the prop. The choke plate will take some throttle servo endpoint tweaking....or whatever the problem is, needs to be fixed.
CA
RE: 540edge 33%
ORIGINAL: skypilot3
i got a zdz120 and its not getting gas to the caraber even when i chock it. whats wrong with it?
RE: 540edge 33%
Maybe if you stop shouting you might get better responses. Writing in caps is considered shouting and is also considered very poor taste [:'(]
Karol
Karol
