Copperhead Venom 45
Reply
Old 09-26-2007, 04:24 PM
  #1101
dubflyer
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Copperhead Aviation Venom 45-30
Quote:
ORIGINAL: mfuess
Dubflyer's engine is running great. The issue he had was the primer bulb leaking air. I recommend to anyone that still has the primer bulb connected to the carb... get rid if it. I solder the nipple closed, but any method will work.
I just received the engine yesterday and will fire it up againg this week-end on the test stand. I have ordered the B&B Muffler which fits this motor ..same as the Quadra 52 Type.
Mark called me while he was running my engine and it sounded Great............It should be ready for prime time as there is already about 4 gals of fuel through it by now. I am expecting a smooth idle and tons of power. I will continue to use 32:1 to complete the 5 gals of breakin mixture and then switch to Belray HR1 @ 40:1 mix.
Thanks Mark for figuring out the air leak.
I do not have an engine box on the Decathlon to mount the engine + pitts style muffler. I am afraid to build one on as I will have a hard time getting it to CG correctly. I have only to use 1" stand-offs to get the cowl and motor aligned.
I will report later when I fly the decathlon in 2 weeks time.
ciao,
Dubflyer
dubflyer is offline
Old 09-26-2007, 06:43 PM
  #1102
mfuess
mfuess's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The site is having some issues...
mfuess is offline
Old 09-27-2007, 03:14 PM
  #1103
dubflyer
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi Mark,
I opened my parcel with the venom 45 and found the engine mounting bracket bent where it oviously came in contact with something hard as the coating is also damaged on the edge.[sm=disappointed.gif]
The box looks OK however I need a new bracket as I do not want to risk bending the bracket as it will fracture and fail. I am unable to insert the bolt through the bracket due to it being distorted. see picture below.[sm=spinnyeyes.gif]
How can I get a new brocket..??[sm=drowning.gif]
Thank you,
Martin
dubflyer is offline
Old 09-27-2007, 04:37 PM
  #1104
mfuess
mfuess's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: dubflyer
Hi Mark,
Thank you,
Martin
Hi Martin!
NOT A PROBLEM!
I have your address here and I'll send a replacement mount tomorrow... I guess the Post Office turned the Gorillas loose on your package!
Please do not run the engine with the mount like it is. There's an extreme "possibility" that it will break from the engine running.
mfuess is offline
Old 09-27-2007, 04:53 PM
  #1105
mfuess
mfuess's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
CORRECTION!
It's ALREADY on the way to you!!!!!!!!!!!!!!!!
mfuess is offline
Old 09-27-2007, 08:25 PM
  #1106
dubflyer
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks Mark,
Great service.....
Will be looking out for it ..............in the meantime I am waiting on the B&B quadra 52 side dump Muffler which has the correct bolt hole centers. Must be the same one you used ..?
Almost ready to fly.
dubflyer is offline
Old 10-01-2007, 09:48 PM
  #1107
Mitsu1
Mitsu1's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Man I like this engine [sm=lol.gif]. Don't know who taught Tim how to make an engine, but he learned well! Mine is a keeper! Took my plane out this afternoon and put 4 more flights on it, and with my V45 swinging a Xoar 21 X 8 @ 7000, I had unlimited vertical. I know the prop played a big part in that too, .. but I could take it from wide open horizontal .. pull vertical ... and the thing just kept the same constant tone while moving straight uphill with no hint of bleeding off! I could hover it, then pull out with authority! I didn't like wide open horizontal too long, because this is a new plane ... and the airframe wasn't proven yet (Had an Ultimate bipe explode on maiden once![X(]. At the field today it was about 5 mph winds, 80 degrees, 69% humidity and elevation at sea level. My Katana is 14.4lbs.
Mitsu1 is offline
Old 10-03-2007, 12:48 PM
  #1108
3D_Junkie
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I'm thinking of getting a new plane. Mfuess, how well do you think the V45 will work in a OMP 92" Edge Hybrid?
3D_Junkie is offline
Old 10-04-2007, 08:10 AM
  #1109
mfuess
mfuess's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: N7160F
I am not familiar with that aircraft other than photos. It's very very boxy looking... sort of a semi-profile airplane. It weighs 16+ pounds according to the site. To each his own, personally that's not my kind of aircraft. I'm sure it will fly nice.
mfuess is offline
Old 10-06-2007, 07:18 AM
  #1110
w5kfg
w5kfg's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I would like to see your electrical setups killswitch set wiring
Bill
w5kfg is offline
Old 10-06-2007, 10:41 AM
  #1111
w5kfg
w5kfg's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Mark
I sent you aPM
Regards
Bill
w5kfg is offline
Old 10-06-2007, 02:07 PM
  #1112
mfuess
mfuess's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hey Bill,
I just sent you a reply...
Mark
mfuess is offline
Old 10-06-2007, 04:12 PM
  #1113
w5kfg
w5kfg's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ok Mark
I got it
tnx for info
Bill
w5kfg is offline
Old 10-07-2007, 09:21 PM
  #1114
maxime chamberland
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hello
I want to know if someone have some info about the venom 30
I want to install it one of this plane Funtana x100
ultra giles 202 29%
I think it could be a great match!
maxime chamberland is offline
Old 10-08-2007, 12:06 PM
  #1115
norbert001
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi Maxime
Can't comment on the Funtana i'm not to familiar with them.
The Ultra RC Giles will take a 45cc, seen one go at the British Freestyles with MVVS 45, and it performed superbly. So thats what my 45cc going into when i finally get round to putting it together.
Norbert
norbert001 is offline
Old 10-08-2007, 02:03 PM
  #1116
CopperheadAV
CopperheadAV's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I agree, I think the 45cc would be a better match with some fire wall strengthening. I'm not sure about Funtana either.
Cheers,
Tim
CopperheadAV is offline
Old 10-08-2007, 02:07 PM
  #1117
CopperheadAV
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Over the past year I’ve had a lot of guys ask me about engine standoffs. It took me a while to find good hardware I was satisfied with but I finally had the time to complete them. I only have these in red anodized and they will fit most engines.
[link=http://www.venomengines.com/Comersus/store/comersus_listItems.asp?idCategory=27]Standoff Link[/link]
Old 10-08-2007, 02:24 PM
  #1118
Flyer Freq
Flyer Freq's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: maxime chamberland
Hello
ultra giles 202 29%
A guy in our club, who is real 3D wiz, has a Zenoah G20 in the Funtana X100. I am very impressed with the plane with a 20CC gas in it, so I am sure that one of Tim's 30CC engines would be a blast!
Andy
Flyer Freq is offline
Old 10-09-2007, 02:53 AM
  #1119
maxime chamberland
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hello
I want to know if the venom 30 have more power of the evolution 26Gt2 without pipe? because at the airfield someone have a 73" Yak 54 ARF with a evolution 26 he can make hover but the airplane need a little more power!
Maxime Chamberland
Old 10-10-2007, 05:44 AM
  #1120
mfuess
mfuess's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hello
I want to know if the venom 30 have more power than the evolution 26Gt2 without pipe? because at the airfield someone have a 73" Yak 54 ARF with a evolution 26 he can make hover but the airplane needs a little more power!
Maxime Chamberland
It does, however the Venom 30 is on hold the last I heard. You will have to check with Tim to see what the status of the V30 is. There are lots of choices available to you for that size aircraft.
mfuess is offline
Old 10-10-2007, 06:03 AM
  #1121
The Big Kahuna
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi Mark, my Venom45 cut out on me when I was landing. Normally I have to hit the ignition kill switch to stop it. Would this happen if the idle was set too low and therefore creating a lean mixture? Any suggestions?
The Big Kahuna is offline
Old 10-10-2007, 07:04 AM
  #1122
mfuess
mfuess's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
It's most likely too low of an idle. When you say cut-out, as in four stroking, or stalling?
mfuess is offline
Old 10-10-2007, 07:56 AM
  #1123
The Big Kahuna
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Stop dead, fan no move - stall may be the better terminology. But why? It's never done it before.
Old 10-10-2007, 10:30 AM
  #1124
mfuess
mfuess's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Several things "could" cause this. Idle too low, engine too hot, lowend too lean, or any combination there of. Your internal screen may be dirty.<---- this is very common.
mfuess is offline
Old 10-14-2007, 09:37 AM
  #1125
Mike Miller
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Mark Fuess,
I sent you a Pm asking for some advice on propeller selection. If you think that the question/answer is pertinent to add to the forum, then make it so. If not, just tell me I am a pain in the keester and to stop asking these damn stupid questions.
Some day I am going to surprise you and make a trip down to your country to visit your flying field. But don't hold your breath, it is not in the new future.
Mike Miller is offline
Reply
Display Modes
