Copperhead Venom 45
Old 02-06-2008, 10:42 PM
  #1251
les2097
My Feedback: (508)
Default RE: Copperhead Venom 45
Mark Fuess....
What's going on with Copperhead Aviation....????
Are you doing service work for them... on Venom 45 engines....??
Larry
[email protected]
Old 02-07-2008, 03:46 PM
  #1252
Jonathan Ott
My Feedback: (25)
ORIGINAL: 72
The Venom 45 bolt pattern is 64mm by 75mm. It is like a bolt width off in each direction.
Thanks 72.
Jon
Old 02-07-2008, 05:37 PM
  #1253
mfuess
mfuess's Avatar
ORIGINAL: les2097
Mark Fuess....
Larry
[email protected]
PM sent...
Mark
Old 02-07-2008, 06:35 PM
  #1254
w5kfg
w5kfg's Avatar
Mark
Pm sent
Old 02-18-2008, 05:38 PM
  #1255
w5kfg
w5kfg's Avatar
Well!!!
Igot my answer back from the Washington BBB.
Looks like Copperhead aviation is not going to return my engine that was in for Warrenty work.
I am not going to fight this case for a $300 engine
I will however not recommend this company as to their past performance not answering emails or the phone and the lack of PR.
Quote: don't bite the hand that feed you
Old 02-19-2008, 06:06 AM
  #1256
mfuess
mfuess's Avatar
That just isn't right.
Copperhead owes you an engine, repaired or not. My venom 45 is sitting here with a broken crankshaft and it won't be sent back.
Old 02-19-2008, 06:26 AM
  #1257
Flyer Freq
Flyer Freq's Avatar
I am one of the fortunate one's. I was tempted to buy one of these engines, but didn't. Unfortunately, I did talk one of my buddies into trying one. He has yet to mount it on anything, and I fear the day he does. He had trouble with the carb, right out of the box. He was to receive a new carb, and it never came. It is possible that the only way to bring justice here is to boycott Tim and all the company's selling Tim's other products, and letting them know why. It is my understanding that his factory is or will be producing ARF's for other company's. A boycott would take a lot of effort to accomplish, without a good line of communication. As it is, my statement will likely get removed.
Best wishes to everyone!
Andy
Old 03-16-2008, 08:29 PM
  #1258
Chumley
My Extra 260 profile reached an untimely end today. In the course of falling to the ground after a mid-air, the motor took most of the impact. I am trying to aquire some new parts. If unsuccessful, I may have some parts someone else could use.
Chumley
Old 03-17-2008, 04:59 AM
  #1259
sean sutherland
sean sutherland's Avatar
Surely they will send your engine back w5kfg ? Whats the outcome ? I was thinking of giving this engine a try !
Old 03-17-2008, 03:33 PM
  #1260
w5kfg
w5kfg's Avatar
Sean
I don't beleive the vendor is going to send my engine back even tho I lawfully own the engine.
I would not buy from this vendor as to his past performance. Read the last several pages abt the problems other pilots have had
Bill
Old 03-17-2008, 03:35 PM
  #1261
w5kfg
w5kfg's Avatar
Sean
You would come out better by buying a DL 50 from
www.dlusa.net
Old 03-17-2008, 06:34 PM
  #1262
sean sutherland
I Think ill go with a MT 57 from Larry at www.lsproengines.com
Old 03-18-2008, 12:29 PM
  #1263
norbert001
Well if that doesn't provoke a responce from Copperhead or OMP, then nothing will...!![X(][X(]
Norbert
Old 03-18-2008, 01:08 PM
  #1264
Flyer Freq
Flyer Freq's Avatar
ORIGINAL: sean sutherland
Yup! Adam at BCMA will be carrying these also. They are not on his website at this date, though. http://bcmaengines.com/
Old 03-18-2008, 04:55 PM
  #1265
w5kfg
w5kfg's Avatar
ORIGINAL: mfuess
Mark
You may get JJtorrant in Mexico to get a crankshaft turned for you. An earlier post reflects what he did
Bill
Old 03-18-2008, 09:00 PM
  #1266
bec123
Hello mfuess or others
I went to swap my venom 45 to a cap 232 and noticed on the ignition module on the one end was a hole a bit larger than the lead end of a pencil?? Is this normal?? is it a vent hole?? Any responses would be appreciated as I am right in the middle of installing and will use a different engine until I can get the ignition box fixed... I have sent Tim an email but also thought I may get a response here...The engine runs good so if others respond try to focus on does your ignition module have a hole in one end. Thanks in advance
bec
Old 03-18-2008, 11:06 PM
  #1267
les2097
My Feedback: (508)
Mine has a hole in the end... for what purpose I don't know...
Old 03-21-2008, 07:10 PM
  #1268
vwtrey
any place to buy a replacement crankshaft? is it the same as any other engines?
Old 03-22-2008, 07:27 AM
  #1269
Chumley
vwtrey,
I have an email in to Tim right now to see about parts. Last I heard he was traveling to China so I haven't heard back yet. I'll let you know what I find out, but if I can't fix my motor, I may have a usable crank shaft I can let go.
Chumley
Old 03-22-2008, 06:57 PM
  #1270
vwtrey
OK Chumley. I have emailed Tim too, but I don't know how long it takes for him to respond. Let me know about the crankshaft. Thanks!
Old 03-22-2008, 07:02 PM
  #1271
Flyer Freq
Flyer Freq's Avatar
I will be shocked if Tim responds to you, and I used to be on his side!
Old 03-22-2008, 07:04 PM
  #1272
vwtrey
sure hope he does.
Old 03-22-2008, 09:01 PM
  #1273
Chumley
Great news! Tim just emailed me and will get a new case to me. It took about a week, but based on Tim's travels, this is reasonable.
Chumley
Old 03-22-2008, 09:29 PM
  #1274
marcnrobin
Tim has always responded to my needs so give him the benefit of a timely resolution.......I haven't started my 45cc engine yet but can't wait to get my 25% GP Patty Wagstaff Extra in the air with it.
Marc
Orlando, Fl
Old 03-22-2008, 09:37 PM
  #1275
Chumley
Marc,
The Venom 45 pulled my 19 pound Extra real well. It wouldn't rocket out of a hover, but it hovered well and would climb straight up out of sight from takeoff! You'll be pleased.
Chumley
