Break in oil for Zenoah G26
I have Zenoah G26 mounted in a Pitts S2B, what is the recommended break in oil mix. The manual states Mix Gas & 2-stroke oil at a mixing ratio of 25-40:1
I ran the MVVS 35 on 33:1 for break in. Can I use the same mix? I plan to use a 18x6 Mejzelik carbon prop. Is it ok to run in on the ground for, say two tanks (650 Ml) then commit to flight?
Thanks in advance
Mike
Thanks in advance
Mike
DC
RE: Break in oil for Zenoah G26
The manual also states
"No specific break in is required,
the engine is gradually broken-in as it is used the the output is also gradually increased"
Only reason to run it on the ground is to get familiar with the carb settings.
More oil makes more power, 33:1 will be fine..
Pennzoil Air Cooled 2 stroke oil is great stuff, and inexpensive...
ORIGINAL: RCIGN1
Thanks for the quick response RCIGN1. 33:1 it will be. I have some Polaris (synthetic) Racing 2 stroke oil for my MVVS engines. Do you know the stuff? I was planning to use this..
Mike
CA
Any good quality oil mixed at manufacturers recommendation will be fine. As Ralph has stated more oil=more power, find an oil in a mix ratio around 32:1 but no leaner than 50:1
CA
Better sealing of the rings, more lubrication especially at higher temps. Ralph (RCIGN1) has done testing on this, Pe also posted a motorcycle article that had done the same testing and I "think" 15:1 produced the most power, but don't quote me.
After reading what the people in the know have said, I never felt it necessary to re-test. I have run a few different oils and none have ever failed me. The thinest I have gone was Amsoil 100:1 run at about 70-80:1.
My Feedback: (62)
UT
ORIGINAL: Miketc
Thanks in advance
Mike
Thanks in advance
Mike
NM
ORIGINAL: soarrich
Is that right? If so why, it's counter intuitive.
ORIGINAL: RTK
Also, I don't understand how most gassers don't require a specific breakin. My big gasser did when it was new and it was the most nerve-wracking 77 minutes of my life with the plane tied to the back of my truck.
Perhaps the manufacturers run the motors at the factory?
LS
My Feedback: (62)
UT
No one said they are already broken in. You just don't have to do anything special during break in except for following instructions. Put the engine on your plane and fly it.
More oil (up to a point as too much will foul plugs) = better lubrication and cooling which produces more power.
OK
From "that" thread:
ORIGINAL: Balsa Steel
Ahh, here we go... Found my "Dirt Rider" September 1998. There is an article by Gordon Jennings that shoots holes in many of the popular beliefs that people seem to cling to. I'm too lazy to re-type the entire article, so I did a search and found this:
http://www.bridgestonemotorcycle.com...oilpremix6.pdf
DC
Been preaching this for years, should be required reading for all the people who believe the conventional "wisdom" that says less oil makes more power...Say anything long enough with enough conviction and it becomes reality...
As in "overweight underpowered boat anchor"
OK
ORIGINAL: Birddog-RCU
Wait... that sounds like a liberal tactic. Meaning liberal amonts of oil that is least I start a political thread war LOL
My Feedback: (98)
I read that article. First it seems old, the changes in technology in the last 30 years is great. If this article still hold true, do you want an airplane with 15 to 1 oil? If you do OS Saito Super Tigre make engines just for you. I'm a sailplaner at heart, but I fly power too, but the thing that turns me off is the slim factor, which is what got me into gassers, low on the slim scale. If you run 15 to 1 oil I think you move to the front of the slim class, I think I'll check out that 100 to 1 oil.
Flamesuit on.
Flamesuit on.
My Feedback: (62)
UT
No flame suit needed here. You just don't get to take advantage of the good advice offered is all. I think the point is an engine does not run better if it has less oil and more gas. I think we all agree that we don't like slime and that there is a point of diminishing returns where too much oil could just not work well and foul the plug(s).
OK
In spite of the advancement in oil technology in the past 30 years, more oil in the gas still seals the rings better. I personally don't know any gasser flyers using, or recommending a 15:1 mix. (although testing does prove it makes more power)
DC
We use it in our racing twins...Leaves two nice long black streaks on the top of the fuse from the end of the open pipe all the way back...Never stuck a piston...
Same McCoy #9 glow plugs lasted two racing seasons, never changed...
