BME 115 Any Field Reports?
#776
CA
RE: BME 115 Any Field Reports?
Did a little flying and tweaking on the needles today. I have flown both carbs and blocks. I have NOT done the mod to the new carb though. I can set my needles so that 99% percent of any noticeable change with AOA is gone. The big but,,,, I re-installed my on board temp unit and when set as such the temps rise higher than I would like (it never sagged though)....So,, if you do "NOT" have the modification done to your carb you definitely will have some richening or increased temps and if your density altitude is high it's gonna be worse. MY first series carb (WGA) did not seem to exhibit the characteristics of the VII (WB) carb. Again, mine has not gone through modifications Keith recommends.
I am waiting to go flying with altavillan, he might have something, although I never noticed his engine running rich or stumbling at any AOA before, then again he runs cans.
Too my knowledge yes.
ORIGINAL: flyinrazrback
will a tilotsen fit without any mods?
#779
PA
The 4 test kits will be ready to ship in 3-4 days.
1 more test pilot postion is open.
You must have the right experience working on the engines to be considered.
And be in the geographic location @ 3000' -2000' ASL SW OR NORTH near Canada.
This will cover most aspects of elevation.
Regards,
Patrick
Regards,
Patrick
#780
PA
Kits are almost done. need those disclosures back ASAP for you to get the test kit.
Make sure you do the training and engine/fuel set ups.
Then the kit install 2-3 hrs est time and tuning set up is easy.
Make sure things are right !
Then you'll be - WOW!
#782
PA
The kits are done.
Soon as the disclosure come back here. I will send the kit too the test/review people.
They will ship by UPS. 1 or 2 day air
remenber when you were a kid, sending in for the free offer, and have to wait 6-8 weeks in anticipation for it to arrive.
NOT THIS TIME !
NOT THIS TIME !
#784
My Feedback: (54)
Just a quick note, we put 6 more flights on the 115 this weekend and have the needles set about right now. There is very little burble in the mid range and the power is excellent. Its been very reliable so far and this is with the updated carb and stuffed reed block. There is no more burble in the mid than any other 100cc engine I've owned and even less than some. This is an incredible motor for the 100cc class planes!
#785
My Feedback: (36)
ORIGINAL: Steve
Carb mod and what is a stuffed reed block?
Jim
#786
CA
Stuffing the reed block is putting wedges (etc) to decrease the open area and prevent fuel from puddling in "that" area, IF and only if there is puddling will this work.
#787
CA
Steve If you don't mind pass on your set up specs. Ie. Exhaust, Plane type, Baffling, Intake air filter? Diaphram tube length, Prop and rpm's, etc.
Suggest you watch for over heating if you do a lot of wot runs.
#788
My Feedback: (54)
Right now the motor is on a Hanger 9 Extra 330. No baffeling. The stock muffers are being used and the carb plate exits the cowl, so there is no tube or cover. The motor rockets this plane verticle so its not at wide open very often, but it is right there when needed. Low idle and advancing has also been good so far. This carb has the mod that Keith has posted for the low speed and it does have the stuffed reed block that is also posted. The prop is a 27 X 10 and I can't remember what it tached at. We'll have it out again once the hinges are replaced on the plane. The rudder hinges broke so all are getting replaced.
#789
PA
JUST MAKE SURE THE ENGINE RUNS ON KE AND INVERTED WITH OUT LOSS OF RPMS @ 1/4 THRU 3/4 RANGES DO A INVERTED SPIN ENTRY @ LANDING IDLE RPM
SPIN 3 OR 4 TIMES INVERTED AT TRUE IDLE. WHAT HAPPENS WHEN YOU DO THAT ?
YOU NEED TO TEST ALL POSTION FLYING WITH A SETUP.
#790
CA
Patrick, Capitol letters means you are yelling. Do you mean to yell at us or did you drop a hammer on your foot. Maybe you should start your own post so those who do not particularly enjoy your abundance of good humor do not have to.
#791
My Feedback: (54)
There was a lot of inverted flying and a couple of flat spins. I don't think Ron pulled off a blender yet. I'll ask him. The blender is the test in my opinion. The knife edge was good also. This plane and engine combo doesn't need much throtle for knife edge.
#794
CA
ORIGINAL: Hammbone
flyinrazrback,
Did you ever try the tillison carb?
Jim
flyinrazrback,
Jim
#797
My Feedback: (309)
CO
Well, I guess I'm the first one to receive one of Patrick's kits. I have to say, I'm impressed with it. I signed a non-disclosure, so don't even ask what it is. I'm not going to say anything about what it is. I will give you my results after testing it though. Now that I've seen it, I have high hopes. I think it will probably work very well.
It's going to be a week or two before I can test it. We are having one of the biggest warbird events in the country at my flying field this weekend. I don't think they will want an aerobatic plane out there. :-)
Plus I'm still waiting for my new rudder (my original one was damaged after yet another BME 115 dead stick). This one happened on take off with no airspeed and no altitude and no where to go. Fortunately, the rudder is all that was damaged. The new rudder is coming from Germany so it is taking a little while.
I'll let you guys know how Patrick's fix works out. I am very impressed with the kit I received.
Jim
Jim
#798
New owner first look at the BME 115
This thread started out as a field report thread and like a lot of first time buyers I used this thread to help me make the decision on whether or not I should buy the BME 115. BME has some real fans and some others that have had real issues. The carburetor issue which takes up most of the posts was a big concern. However, a I did notice that a lot of people have dad no issues with their carburetor or have gotten past the problem.
My new motor was delivered 3 weeks ago. When I picked up the UPS box my first thought was that they forget to put a motor in here, the box was that light. My 3-W 60 weighs more. I know this is not news but when you pick this motor up for the first time its still a surprise how little it weighs. The motor is a work of art, everything that could be done to save weight has been done.
I decided to bench run this motor because frankly I wanted to see how it started and how it transitioned to high RPM. Not a great idea but I needed to know.
Set up was MSC 28 X 12 prop, Chevron regular gas and Lawn Boy at 32 to 1. I used stainless headers from 3W and a pair of 20oz collector cans to reduce the bark. Carburetor was the Walbro 2 needle.
We did 4 short test runs of two minutes each. Starting the motor was easy, restarts were also no problem. Idle was around 1300 rpm and the run up was smooth with a constant increasing of the RPM. No midrange burbles. High RPM on the first run was only about 4500 for just 15 seconds. By the 4th run the RPM was at 5000. Each run showed a higher top end. The motor ran rich at all times and we never changed the factory settings. Cylinder temperatures were close together about 25 degrees apart with the forward cylinder running cooler than the back cylinder.
Now that I have seen this motor run my first impression is that it’s a winner. I don’t see any carburetor issues with mine. It started, transitioned and ran as reliably as my 3-W did when I bench tested that motor. I will switch to a 27x10 prop, mount this motor to the Pitts Special that I am scratch building and fly the heck out of it.
#799
My Feedback: (15)
AE, GERMANY
TonyC,
I am interested to hear what your results are going to be. I was thinking of this motor in my Frank Knoll CE 2 kit. Its lightweight and more powerful when it does run correctly.
#800
My Feedback: (19)
Need some help. I got the new carb and ran the 115 with the new carb with sucsess 2 weekends ago. Only had time for 2 flights and didnt do anything much more than fly it around putting a little time on a brand new motor. Last weekend I had it out and had nothing but trouble. It would idle and transition well on the ground. In flight it ran fine on the low end but when I pulled to a vertical it seemed to lean out horribly and almost die. I richened the high end 3 or 4 times so much so that it would litterally bog when it tried to unload straight and level and it still near died on a vertical climb. Even a 45 would make it drop way off. My last flight I actually went a little leaner than the original setting and it was better especially straight and level and was a bit better on the vertical but still leaned where I couldnt do much at all until it wanted to die. Im kinda at a loss. Should I try richening the low end?. keep in mind on the ground it spools great and runs up great. It does surge up and down a little sitting at idle. I did have the carb sense line run back into the fuselage on a tube. I have replaced the stock china tank and fittings with dubro stuff and taken the line off the carb ( the nipple goes up under the cowl lip and is not exposed to direct air) any ideas
