Kalt KG-22 engine
Kalt KG-22 engine
I have just been given a Kalt KG-22 engine. It looks to be in good shape but I'd like a source for any information on it that might be available, i.e. a parts list if possible. It appears the prop shaft is 8X1.25 metric thread, the carb insulator uses 5X0.8 2cm long screws and the Walbro carb requires about 5X0.8 5cm long screws. Does this sound correct? Any comments such as "Is this engine worth trying to use?". thanks, Rodney
DC
RE: Kalt KG-22 engine
A Kalt KG22 is a Zenoah G23, early style...The prop was held on by 2 nuts on a 6mm threaded rod...There's a set of points behind the flywheel..The spark plug MUST be a NGK BMR6A, any other plug is too long, the piston will hit the side electrode and close it...If you have any problems getting it to run it will need a carb diaphragm kit, about $5....16 inch props work best...It will last a very long time if not crashed...
DC
Also, the points must be set very close on these KALT 22's. I think the point setting is .010, Ralph do you remember? I have three of these that I've been running for many years. Likes to turn an APC around 8500 at sea level. I had Ralph convert one to his EI, just for ease of starting, a good move. This Aeronca is 13lbs, 86" wing, a good flyer on that engine.
SC
I too have a Kalt G-22 that looks to be in good shape. Do you have any idea where parts may be found, I.E. carb diaphrgm, points etc? Is there a manual for this engine anywhere that you may know of? I was told that the engine was CDI engine - that's apparently wrong. Any info would be greatly appreciated, I'd love to run the thing in a small ultra stick.
Mike
Mike
ORIGINAL: vnaimo
I ALSO HAVE A KALT G-22, LOOKING FOR A CYLINDER HEAD. CAN YOU HELP. THANKS VIC.
Check with Ralph Cunningham at RC Ignitions, 928-635-2455 as he might just be able to assist you.
Karol
TX
I have taken the flywheel, points, condenser, and coil off of my Kalt G22. Any body need them? [email protected]
NY
Just got a Kalt, thanks for posting the manual!!
Going to use it in a Greap Planes PT-19 ARF...
http://www.greatplanes.com/discontinued/gpma1301.html
Bill S.
Bill S.
Your Kalt should be a good engine for the PT19. I have had two of these motors for years, and love them. I am always on the lookout for more of them at swap meets, etc! I have found the best prop for them to be a 17x6. I have one Kalt in a 17lb DR1 and the other in a 18lb DVIII, both quarter scale. Check out J'tec mufflers for one that is much narrower than the stock one. Loud, though! Duane
NY
Thats good news!
Any source for parts, such as the coil, or points?
A club member of mine checed his and said it had no points but had a moduel.
Any replacments?
Bill S.
Any replacments?
Bill S.
Don't know about parts, haven't needed any! If you don't mind spending a little money, you could send your engine to Ralph Cunningham (Antique) and let him put in a RCXL ignition. NOW, that would be sweet....
I have a G23 converted to ECDI with D&B electronics. love it. Here is a test review of the early G23 that I think was SA the Kalt
EDIT: Note, The last attachment is actually the first page of the document.
Last edited by spaceworm; 10-20-2016 at 06:03 AM. Reason: noted that the last attachment is the first page of the document.
