DL50 props and RPM
Reply
Old 09-21-2007, 11:39 PM
tomyrcmodels
tomyrcmodels's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: DL50 props and RPM
I like turn my engine with big prop at low RPM , 24-8 and 24-10 JXF , about 6450 , less noise and got more stastic thrust .. and mid rang transation are just WOW. Not DL 50 but my 62CC engine , (if change to 22-10 JXF prop , the RPM are going too high , it's over 7400 )
tomyrcmodels is offline
Old 09-22-2007, 05:55 AM
closetguy
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: 3DDino
Looks like DL is waaaay stronger than 3MM
7700 !!!! that rivals mvvs58 and lighter in wt too
thx
on what prop!! noway is the DL 50 going to hold a candle to a 58!!put a 24-8 prop on it and let's compare numbers.on a pipe or on a pitts muffler.
let the games begin
closetguy is offline
Old 09-22-2007, 09:54 PM
cygnet
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I turn a mez 22x10 at 7300 two gallons through engine 3500 ft and stock muffler
cygnet is offline
Old 09-23-2007, 01:32 PM
tomyrcmodels
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
3500ft are about 90.4% air density compare with sea level altitude . so if you can get 7300RPM with Mez 22-10 at 3500 ft. you may got probable 6600 rpm at low altitude but even more thrust.
Old 09-23-2007, 02:38 PM
cygnet
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Could be all I know is it pulls like crazy have had it on two 14lb models and the power is insane
cygnet is offline
Old 09-23-2007, 05:27 PM
  #31
Prapan
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I run DL-50 with Bolly 22 x 10 and turns out at 7200 rpm.
Prapan is offline
Old 09-23-2007, 06:46 PM
  #32
BillS
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
After measuring a few small glow engines I find that you can get more rpm and less thrust with different manufacturer's props. Does anyone have thrust numbers to go with the rpm?
Bill
BillS is offline
Old 09-27-2007, 09:19 PM
  #33
carmerxr400
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
What brand and size prop: NX 22-8
Bission wrap around pitts muffler, has a nice sound.
How many gallons of fuel through the motor: 4 Gallons
What brand and ratio of oil: Klotz model lube 40to1
What's you RPM: 7200
Elevation 750ft
Temp 80 degree
carmerxr400 is offline
Old 11-12-2007, 12:26 PM
  #34
teazers
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
HI
JUST OREDERED MY DL 50 PLANING TO USE KLOTZ KL 310 IN IT WITH 22X8 JXF PROP
ANY TIPS OR IDEAS (FIRST GAS MOTOR)
PLANE CAP232G (HANGER 9)
THINKING ABOUT BISSON WRAP AROUND BUT DONT WANT 2 LOOSE POWER??
teazers is offline
Old 11-20-2007, 09:21 PM
  #35
h82crash
h82crash's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Uh, I wouldn't worry about loosing power with that engine on that little plane. It's gonna hover at 2 clicks above idle. If you haven't already bought the plane, get something bigger. Not that it won't be fun (a friend had a DA50 on the Italia H9 Cap) but you won't have optimal wing loading. Get an Extreme Flight or SD Yak and you won't be able to stop smiling.
I take it back, I looked up that plane, should be fine if you can keep it under 15.5 lbs.
BTW my avitar is my Lanier kit Cap with a DA50 and 14.5 lbs, highly modified during construction.
h82crash is offline
Old 05-16-2010, 10:30 PM
  #36
modifyit15
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I have a Albatross prop 22x8 from TBM my DL-50 spins this prop at just over 2800 its right at about 2228 on the ground. I can hear my prop hiting supersonic in the air if I let it. is that amount of RPM bad for the motor? my motor temps are at 152 F
Motul Synthetic 2cyl oil
used motor got of here no idea how much time on it.
modifyit15 is offline
Reply
Display Modes
