3W 75 PROBLEM
3W 75 PROBLEM
Hi guys:
I am experiencing a weird problem with a 3W 75 US installed in an Extra 330. Whenever I go from normal position to inverted the engine gets richer. This happens with throttle not full.
Any clues.
Thanks in advance !!!
JC
Any clues.
JC
RE: 3W 75 PROBLEM
I have the same problem with a 50i and asked the same question on 5/20/07 see page 14 on this forum. Nobody has given an answer. At a local show when talking to Iain Nicols of IAD Designs he said it was the spring on the diaphragm that works the demand needle that is weak. He suggested streching the spring. Another manufacturer (i cant remmember who but somewhere on this site) suggested lenghtening spring 2mm to overcome the same problem.As my problem suddendly got unbearably worse I am in the process of getting a carb kit as needle may also be worn. Also have a look at geistware.com aircraft proving grounds do it yourself tips about walbro tune up and pop off pressure or aercorsair. Much luck
My Feedback: (30)
RE: 3W 75 PROBLEM
It sounds like you need to slightly lean the mid-range by leaning the lower end needle. With the engine mounted inverted, excess gas is spit out the intake and when you roll inverted, all the fuel goes into the engine.
Elson
Elson
RE: 3W 75 PROBLEM
Kfir2: I will definevely try what you told me, but first I will try what Elson told me about leaning the mid-range.
Thanks to both of you.
I'll let you know how this work.
JC
JC
TX
RE: 3W 75 PROBLEM
There needs to be a vent coming off of the diaphram cover going into the fuse (for a constant pressure).
Just take the cap that covers the diaphragm and solder a hollow tube, then just run a line into the fuse.
Hope this helps
[img][/img]
Hope this helps
[img][/img]
My Feedback: (221)
RE: 3W 75 PROBLEM
Update. Just flew my 3W 55 again today and I tweaked the needles again. I was still getting just a little drop off when rolling to inverted (thought I had it all out). I had to close them both just a tad today. The low end is now open 5/8 turn and the high needle is just under 3/4. Excellent transition, smooth steady idle, and tons of power at the high end. I'm convinced this phenomena is carburetor adjustment related now. At least it was for me.
