3W ENGINES HELP!!!!!
My Feedback: (9)
WA
RE: 3W ENGINES HELP!!!!!
Here's the setup I'm using with my 3W-50 in a pica Spit with Keleo live exhaust. I've made a duct from the front cowl inlet to the front of the cylinder head, and there is a large opening in the firewall behind the engine, with air routed out the oil coolers. I haven't run it yet, but have high hopes for it. All of the ideas came from others on this forum. Evan, thanks for putting your Spit rebuild on RCSB, I've used a lot of the ideas when refurbing mine. Cactus sells a one inch extension for the prop hub, which I ended up not using on this setup, but will use it on my Vailly Hurricane.
Sam
Sam
