Gasser Throttle Servo???
Reply
Old 07-25-2007, 05:05 PM
bzyguy01
bzyguy01's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Gasser Throttle Servo???
I am asking for good sources for a gasser throttle servo. I have installed a brand new spektrum digital (CHEAP) servo on my fire wall of my H9 33% Edge w/ brison 100cc. Killed the servo in 1 flight. I am hearing conflicting stories on MG servos for the throttle??? Any input here would be great.
Oh yeah...for those that were wondering what happened to the throttle when it failed....Yeah, Stuck WOT for 15 min's until I lost the 2 top cowell screws due to the intense 15 min's of WOT and ate the cowell to stop the engine.....Dead sticked it in. That was an intense 15 min's trying to keep the air speed to a minimum.....we got pretty good at flat spins tho!
bzyguy01 is offline
Old 07-25-2007, 05:32 PM
AirWizard
AirWizard's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Gasser Throttle Servo???
I use Hitec MG servos for the throttle on all my gas planes.
AirWizard is offline
Old 07-25-2007, 05:51 PM
krayzc-RCU
My Feedback: (31)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
i have various one on my gassers right now i have 2-811 and 1-hitec 605 and one jr 517, and one 3121 mini. I do love those 811 but its only on the bench can i tell anything in the air all of my throttle seem good wth either mixing or a good resuliton set up.....
krayzc-RCU is offline
Old 07-25-2007, 06:01 PM
mrbigg
My Feedback: (21)
mrbigg's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Anyone running standard digitals? with nylon gears?
mrbigg is offline
Old 07-25-2007, 06:05 PM
BaldEagel
BaldEagel's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
If you read the advice given by Quique Simozimi he reccomends not using digital servos, because of thier constant referencing back to the servo position and therefore draining the battery uneccesaraly, he reccomends a good analog servo.
Mike
BaldEagel is offline
Old 07-25-2007, 06:36 PM
TLH101
My Feedback: (90)
TLH101's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
And a radio controlled kill switch, or a servo operated choke.
TLH101 is offline
Old 07-25-2007, 07:51 PM
Josey Wales
My Feedback: (61)
Josey Wales's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Ive used 811's 5965's and 6965's
Josey Wales is offline
Old 07-25-2007, 08:13 PM
cap10b
cap10b's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
All,
I go with Baldeagle in that I use a fast analog non-digital servo on throttle and choke. However last weekend I got up to the flight line and flip flip flip and no start. Seems the choke servo went out leaving the choke in operative. I am wondering since both throttle and choke servos were in stalled fresh overhaul from the factory at the same time, if I should replace the throttle servo just to be safe. ? Hmmm good question.
Servo Specs
Airtronics 94151 High Speed MOS Fet Pro servo
96 oz/in at 6 vdc at .07 speed. at the time these
were about $90 servos.
I have some DS 821 JR sport digitals but I'm afraid to use them because
of the splines popping off under load. I hate to waste an 8611a on throttle
and choke.
JDS
cap10b is offline
Old 07-25-2007, 08:18 PM
mrbigg
My Feedback: (21)
mrbigg's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I have some 8611's laying around. I would like to swap one in just to see the speed difference. I just have a 148 on there now.
mrbigg is offline
Old 07-25-2007, 09:06 PM
Nogyro
My Feedback: (10)
Nogyro's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I"ve used 148's before, and now I'm using a Hitec 545 I believe the number is. It's a 5 pole motor analog servo with nylon gears. Centers very well...Over 300 flight on the 545 with no problems.
Nogyro is offline
Old 07-25-2007, 09:15 PM
nonstoprc
My Feedback: (90)
nonstoprc's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Make sure the prop and spinner are balanced.
nonstoprc is offline
Old 07-25-2007, 09:27 PM
Charley
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Maybe you should think about a ignition kill switch for the future.
CR
Charley is offline
Old 07-25-2007, 11:37 PM
bzyguy01
bzyguy01's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: Charley
CR
You can say that again!!! Live and learn. School of hard nox!
bzyguy01 is offline
Old 07-25-2007, 11:41 PM
bzyguy01
bzyguy01's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Yeah....It was good but the engine is a Brison single cylinder 100cc! She's a shaker! Big difference from my twins or even my g62 singles.....The brison makes fairly good power tho. I'm sure I will need to pick the very best option in this perticular bird with the Brison. I was shocked that all it took was one flight to kill that digital servo.
bzyguy01 is offline
Old 07-25-2007, 11:45 PM
bzyguy01
bzyguy01's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: mrbigg
Thats basically what I had in my bird. It was a standard spektrum digital with nylon gears. It failed within one flight.
bzyguy01 is offline
Old 07-26-2007, 01:05 AM
Tired Old Man
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I've run from Hitec 225 mg's up to JR 8611's for metal geared, and JR 4721 and 8411 for nylon geared. No throttle servo failures to date. In performance I prefer the coreless or the digitals because the throttle and the flight surfaces are similarly timed. With the analogs I note a lag betwen the throttle response and the surface responses. Seems I can never get the two in sync with the analogs. The small mini servos that are used for electrics are definately a no go.
As for increased battery drain with a digital throttle servo, just how much of an increase are we talking about here? If I can get 4 to 5 flights a day over a couple of days out of a single 4,800mAh flight lithion and a 2,400mAh ignition lithion who cares about the difference? I have to charge the mini battery JR puts in the 9303 long before I have to charge the plane.
Tired Old Man is offline
Old 07-26-2007, 07:37 AM
JoeAirPort
My Feedback: (41)
JoeAirPort's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I like Hitec 5945's. Got them in two planes and work great (one of them for a year, many many flights on a ZDZ 50 NG).
JoeAirPort is offline
Old 07-26-2007, 12:28 PM
StevL
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: BaldEagel
Mike
I don’t think its battery drain alone. A digital servo for a lack of better description has for example a hundred positions for the 60 degrees of throw. An analog servo has an infinite amount of positions.
This relates; kind of like the heli guys would never use a ratchet throttle on their radios, and a lot of 3d airplane pilots don’t use the ratchet either.
StevL is offline
Old 07-26-2007, 06:42 PM
JoeAirPort
My Feedback: (41)
JoeAirPort's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I don't see that excess drain at all with digital servos on the throttle. Also there are no infinite positions with anything unless you have a analog transmitter (if one exists). Our transmitters and receivers only have so many steps in position (resolution). Lastly the analog servo is only so precise so the infinite positions is limited by the servo error. Even analog sytems have error. I would bet that the digital servo is more precise than an analog unless the analog is a really good quality one (i.e precise).
Old 07-26-2007, 07:57 PM
Tired Old Man
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Which is one of several reasons we went to "digital" servos in the first place. Better resolution, better centering, higher starting and holding torque, and consistent speeds. You don't need a digital on a throttle, but I sure notice the lag when I don't have one.
Old 07-26-2007, 09:03 PM
altavillan
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
http://www2.towerhobbies.com/cgi-bin...?&I=LXLN95&P=0 My currant throttle servo of choice. Excelent speed. Very little gear lash. And acording to Tower the SMT is for high vibration environment.
altavillan is offline
Old 07-26-2007, 10:42 PM
JoeAirPort
My Feedback: (41)
JoeAirPort's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: altavillan
I wonder if this is just the Hitec 5245 with a Hobbico sticker?
Old 07-27-2007, 12:13 AM
skreamer
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I have used 645 mg 5945mg and one nylon. The nylon worked for 4 flights. I always use metal gear servos now and lately Digital servos only, throttle and choke as I use the choke as my second method of shutting off the engine. This came in really handy when my throttle servo went to sh8t.
skreamer is offline
Old 07-27-2007, 07:46 AM
JoeAirPort
My Feedback: (41)
JoeAirPort's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I used to use the Hitec 5245 mini MG but I realized that I didn't want to lose a throttle servo ever so I went with the 5945 for the added insurance. I doubt I will ever lose my throttle control with one of these.
Old 07-27-2007, 08:23 AM
BaldEagel
BaldEagel's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I hope you have not got a reed induction engine, because if you use the choke often as a means of cutting the engine you will fray the reeds, also with the engine on WOT you could hydrolock the engine which could bend the conrod, this is posted just for information.
Mike
Contact Us Archive Advertising Cookie Policy
