Go Back  RCU Forums > Glow Engines, Gas Engines, Fuel & Mfg Support Forums > Gas Engines
Reload this Page >
Baffling for single cylinder engines
Old 08-13-2007, 08:46 PM
shanes300
My Feedback: (8)
shanes300's Avatar
Default Baffling for single cylinder engines
Hello,
I have purchased 2 3w 85xis for 2 1/3 scale Cap 580's for my son and I. I have made a big investment and I want it to last a while $$$$. Does anyone baffle single cylinder engines? If you would, please post pics, comments, and suggestions. Anything would be appriciated.
Thanks in advance,
Shane
Old 08-13-2007, 09:30 PM
tail strike
tail strike's Avatar
Default RE: Baffling for single cylinder engines
Most people don't use baffels on single thies picks are the best I can do for now.
ID:	741697   Click image for larger version
Old 08-13-2007, 09:45 PM
krayzc-RCU
My Feedback: (31)
no baffles on any of my singles about 6 of them.
Old 08-13-2007, 10:47 PM
ca$hey
ca$hey's Avatar
I would even more so with a 3W around run in period thay push a bit of heat,,,Here is my Yak (nothing like a cap),,with out it my temps were to high
Old 08-14-2007, 07:07 AM
reincarnate
Asked the same question a while back. Here's the link. Grab a soda and a notepad.
http://www.rcuniverse.com/forum/m_6147421/tm.htm
Old 08-14-2007, 08:42 AM
Jaketab
Shanes,
I’ll post a pic this evening after work on my 50cc single.
When cutting the cowl for the inverted cylinder, expose enough of the front to allow the air to hit most of the cylinder front. Also, cut as close as practical on each side of the cylinder to force the air to go through the fins instead of around.
Jaketab
Old 08-14-2007, 09:12 AM
BaldEagel
BaldEagel's Avatar
If your cylinder head pokes out of the bottom of the cowl enough you will not need to baffle, unless you fly in exceptionaly hot weather as a norm.
Mike
Old 08-14-2007, 12:45 PM
Jaketab
Extra cowl, single inverted cylinder with cut out and baffling.
ID:	742035   Click image for larger version
Old 08-15-2007, 05:58 AM
RustyTumbles
RustyTumbles's Avatar
Here's a link to a thread on FG that I started when I baffled my DA50. It it well worth doing IMO.
http://www.flyinggiants.com/forums/f...-baffling.html
Old 08-15-2007, 06:05 AM
Tired Old Man
Any engine other than one fully exposed will benefit from properly directed airflow, single or twin.
Old 08-15-2007, 07:24 PM
tail strike
ORIGINAL: RustyTumbles
Link don't work
Old 08-16-2007, 06:01 PM
shanes300
My Feedback: (8)
shanes300's Avatar
Thanks for all the replies.
Mike,
on the Cap, it is big enough to where I don't have to cut out for even the spark plug. I had a AW 29% Katana that the DA50 did stick out enough, but that is not the case on the Cap. on the pros vs con I get to enclose the engine, but I am worried about the cooling.
Jake,
Thanks for posting the pics. Now, on the two holes on the original intakes, do you have any kind of tubing going from that to the engine?
Thanks again everyone,
Shane
Old 08-16-2007, 06:21 PM
Aerobat
Aerobat's Avatar
Here's what I did on my CA 34% Extra and Quadra 100 (since upgraded to a Brison 6.4)
ID:	743450   Click image for larger version
Old 08-16-2007, 09:25 PM
Jaketab
Shanes,
There is no tubing attached to the small holes on each side of the spinner. I opened the holes to let ventilation around the ignition and battery.
I tested this configuration last weekend. The baffle in front of the bottom exit hole seems to have the biggest effect in venting the hot air from the cowl.
Jaketab
Old 08-17-2007, 08:15 AM
Big_Bird
Big_Bird's Avatar
Read this article: http://www.rcshowcase.com/html/faq.html#baffles
