faulty plug wires
DC
faulty plug wires
Never saw this happening .If the coils spark to the manifold try tightening the screws that hold the coils on...Also try some new spark plugs..Way cheaper than a couple of $65.00 coils.....
DC
faulty plug wires
No such thing as too much battery..
I know Bill's ignition ( Brand X) is good, but there must be some problem with the insulation on the wires....Does it jump from where the wires enter the coils or somewhere along the wire ??
Have you grounded the ignition box to the engine ?
faulty plug wires
it jumps all along the wire. dont try and touch because it shocks the hell out of you. I tried covering the wires with metal tape to shield, but with no success. btw you fixed a g38 for me about 8months ago and it still purrs flawlessly. the ignition box is grounded with the ground provided. Is there another way to ground it besides the one provided?
DC
faulty plug wires
Nope, unless the ground wire is somehow disconnected from the circuit inside the box. Try running a new ground from under one of the screws in the box to the motor mount...
The shield on the wires won't help, just lets the spark jump to the shield instead of the carb or manifold....
You might try about 3 layers of heat shrink on the wires..
WY
faulty plug wires
Ok now the question is why?? Check the 3 black wires on the ignition module.
The battery lead, the ground wire, and the black wire to the sensor. All three should be common to each other. If you find one that is not thats your problem.
