any info about this? (cheap!)
Location: SantiagoReg Metropolitana, Providencia, CHILE
This engine is listed in united hobbies, at a very low price
https://www.unitedhobbies.com/UNITED...idProduct=5460
tell me what you think...
RE: any info about this? (cheap!)
I've seen a couple of them being used over here. They seem to be a pretty strong motor for their size and I've not seen the guys using them having any reliability problems.
thanks, I have no experience with gas engines, maybe this is a good start with this kind of stuff, but I`m still not sure to buy it
Interesting how many different designs were copied and incorporated into one engine. Pay attention to the part where this engine just finished development and testing. It may run good on a bench but how does it perforem on a plane, and for how long? Since you're new to gassers my question is whether or not you feel qualified enough to become a guinea pig for a new design. Yep, it's a great price but can you afford to spend it once then even more if it doesn't work out?
My thoughts would be to let a few people that have a lot of time with gassers get their hands on a few and see how the stack up against the competition and where the quality stands in the big picture.
Without wanting to get into a war over specific engines....this appears to be near identical to a number of other Chinese engines. There are differences between certain models but it is highly probable they all come out of the same couple of factories.
I have a 45cc that looks near identical....ignoring the fancy anodised look, trumpet, and plastic intake manifold.
On second look the basic castings, ignition unit, and muffler are identical to mine (which has yet to run)
Check out the CRRC Pro thread for details on the CRRC engine and other similar engines.
ORIGINAL: rc bugman
Weedwacker or a chainsaw engine dressed up to look like a airplane engine
Elson
Elson
Actually a copy of a rather well known R/C Engine.....
Seams this engine is being judged as a piece of junk before anyone has even bought one yet. Because it's got some saw parts inside? Come on guys.
But really, aren't most of them?
DA, ZDZ, 3W are the only popular engines that actually make their own cylinders, pistons and rods.
Just because it's got weedeater or saw parts inside don't make it a bad engine.
Hmmmmmm -- Zenoah, Brison, Fox, Brilelli, FPE and a BUNCH of other engines have chainsaw cylinders, pistons, rods and carbs. Most of them have a pretty good reputation.
My Feedback: (29)
Plenty of people will take a chance since its so cheap. Many of these folks will have limited experience so operational problems will be voiced here very quickly. If it is a G45 clone and it equals its performance/ longevity then it is an exceptional value. Has anyone noticed how all of these new cheap engines generate more enthusiasm than proven top of the line products?
My Feedback: (49)
AZ
well i just went there to try and order one but there out till sept somtime.i will try again.. but its also $50.00 for shipping when i checked my cart,air parcel from hong kong.wonder if i have to pay duties on top of that when it enters US.I could make a shorter intake manifold.
This looks very close to Peakmodel 45cc engine.
http://www.peakmodel.com/index.php?m...roducts_id=328
There is a thread here about peakmodel 45cc (and a separate one fr 65cc). Crappy muffler, loud but appears an excellent engine oterwise.
My Feedback: (7)
TX
They are coming out of the woodwork now....
like this one.
http://www.rcuniverse.com/magazine/N...roduct_id=2159
like this one.
My Feedback: (7)
listen to the experts here on rcu if you are asking whether a new engine is any good or not. they know exactly how it will run, what rpm it will put out on the ground, what airplane it would be best on and how good the customer service will be. pretty much anything else you want to know about it, without ever seeing one in person, let alone actually owning one and flying it. they are really amazing guys, you should listen to them.
My Feedback: (13)
Take a look at the success DL is having with its DA-50 knock-off. Most reports of the later engines are nothing but positive. Easier to start than the DA, less expensive than the DA, and more importantly more power than the DA.
Thats part of the reason some people get excited about these knock-offs.
Why worry about it if it runs better and sells for less money?
The only people I would be worried about is DA right now. If I was DA I'd be scared. In fact quite a few hard core DA folks have gone DL because they just work the right way from the get go.
Personally I never said anything good or bad about the engine but noted that it's only recently left design and testing, meaning that it does not have a track record to base a decision on. The only thing a newbie to gassers has to work with is a cheap price. My comment of waiting until some with a little gasser time worked with them and made some determinations is still not a bad idea, imo. Reports of things like "there's a few guys that started using them over here and I haven't heard anything yet" is not much to go on.
Chinese manufacture does not automatically make it bad, just as cheap does not automatically make it good. OTH, if you are brand new to gassers and feel like being a guinea pig with your plane and engine, go for it. Only you know what you are capable of handling.
My Feedback: (19)
ORIGINAL: Rcpilet
My Feedback: (29)
ORIGINAL: hvac
My Feedback: (40)
ORIGINAL: Kweasel
Where did that come from?
ORIGINAL: hvac
From the same mind behind spamming planes that aren't even available yet
My Feedback: (7)
TX
It looks somewhat similar to a Venom 45, and a Zenoah, and a Fuji.
The carb intake looks like white teflon. I have been told before not to use white Teflon in applications above 100 degrees C. There are other harder teflons that can withstand heat better. I have ignored that warning before and never had a problem....but I assume the person that told me this information must have had some basis in fact....
Are there other proven engine designs where white teflon is used on cylinder head temperature applications?
