New SV Gassers
Reply
Old 04-15-2008, 06:28 PM
  #651
rfmullig
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: New SV Gassers
No, I did not run a static line. I don''t even know what one is.
Rob
rfmullig is offline
Old 04-15-2008, 07:30 PM
  #652
jstanton
My Feedback: (14)
jstanton's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
If you engne runs very rough when you install your cowl and runs great with out the cowl than you need a static line.
The carb has a hole in the diaphragm plate. You would install a 8x32 or 6x32 pressure nipple into the hole on the diapgragm plate than run it into the fuselage. This would insure that the pressue on the diaphragm would stay constant. I have had to run a static line on my Brillelli engines. The carb on the XYZ-50 is a WT-805 which is a different carb and if your engine is running right with the cowl on than you don''t need one.
jstanton is offline
Old 04-15-2008, 08:49 PM
  #653
rfmullig
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks a TON for the info. So far the engine is running fine. Would the Wt201 be a better carb?
rfmullig is offline
Old 04-15-2008, 10:42 PM
  #654
sean sutherland
sean sutherland's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
This thread is For SV engines and their other forms i dont think XYZ are the same maybe you could start your own thread on them?
sean sutherland is offline
Old 04-16-2008, 05:56 AM
  #655
jstanton
My Feedback: (14)
jstanton's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I don''t really thin the WT-201 would be a better carb. I will know more once I test run my XYZ-50 tomorrow. The WT-805 carb that comes with the engine is a 13.5mm carb so it is the right size for a 50cc engine. I could try the WT-201 carb on the engine just to see if it would make a differance
jstanton is offline
Old 04-18-2008, 08:48 AM
  #656
blw
blw's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Sean has a point, and let's not get into a situation where the thread is hijacked to another brand. I know the XYZ talk is important too, but....well, you know.
blw is offline
Old 04-24-2008, 04:41 PM
  #657
ozzmanace
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
what is the reed assembly? i have run about three tanks thru mine but it doesn't seem to be running right. could you explain about the reed.
ozzmanace is offline
Old 04-30-2008, 06:50 PM
  #658
ozzmanace
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
wow, either the moderator put a stop on this thread or nobody knows what a reed assem. is. it's been over a week since i posted the last thread. what's up guys.
Old 04-30-2008, 08:07 PM
  #659
freeonthree
freeonthree's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
They are little valves (flaps) between the carb and the crankcase. They allow fuel in, but don't allow crankcase pressure to enter the carb as the piston is going down.
freeonthree is offline
Old 04-30-2008, 08:38 PM
  #660
freeonthree
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
There ya go, I added a picture of a reed assy to my last post for you.
Old 04-30-2008, 08:39 PM
  #661
ozzmanace
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
thanks. i guess that's why the other carbs didn't work.
Old 04-30-2008, 08:47 PM
  #662
freeonthree
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Remove the carb, then the reed assembly (noting it's position), and flip it over and look at the reeds. My engine was hard to start and would only idle. It would die if I gave it any throttle. Then we found the broken reed. Note which gasket goes where.
Old 04-30-2008, 08:52 PM
  #663
ozzmanace
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
freeonthree, i just test flighted a ultimate bip. i have to say i'm hooked. i've tested everything else. turbines, electrics, 540-trainers. that was the most fun i've had yet. right before i told you this i ordered a 120 ultimate for myself. i'll put the infamouse 26cc motor on it. the one i test flew had the same motor on it. it wasn't running good. i mentioned some of the pointers i got from this thread and the sob ran great. thanks all!!
Old 05-01-2008, 04:18 AM
  #664
sean sutherland
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Another happy owner good to hear these little engines are finally being accepted, i know mine has accepted me !
Old 05-01-2008, 08:34 AM
  #665
rfmullig
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Which Ultimate Bipe did you get? What company?
R
rfmullig is offline
Old 05-01-2008, 09:28 AM
  #666
freeonthree
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
These little 26's are the ultimate little engine's in my opinion. I don't think I even need more than my one gasser now. I never get tired of flyin my Stearman with the SV26.
Old 05-01-2008, 05:49 PM
  #667
ozzmanace
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
it's the nitro models version
Old 05-01-2008, 05:52 PM
  #668
ozzmanace
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
i also have one in an balsa usa neuport 17. but it's still in the works
Old 05-01-2008, 06:04 PM
  #669
freeonthree
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
No, it a Great Plane, and it's about 1/4 scale roughly, they don't tell ya...
Old 05-06-2008, 06:36 PM
  #670
ozzmanace
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
well whoever will take credit, it looks awesome. the one i flew had a 16/8 prop. it seemed to need alittle more prop. but i dont know about an 18/6 like the add says. any thoughts?[&:]
Old 05-06-2008, 08:20 PM
  #671
jstanton
My Feedback: (14)
jstanton's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I use a APC 17x8 and it will take e little larger prop so a 18x6 should work fine.
jstanton is offline
Old 05-06-2008, 09:20 PM
  #672
freeonthree
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Here's my SV26 with an 18x8. The plane weighs about 15 pounds.
http://www.youtube.com/watch?v=bYxJrV_MIMc
Old 05-07-2008, 11:12 AM
  #673
NM2K
My Feedback: (14)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: freeonthree
I'm glad to hear someone else say something like this too. I'm the same way, if I'm lucky enough to stumble across a combination that I really enjoy.
I had a Goldberg Cub with an Enya 80-4C and a Florio Stunt Wagon with an OS .32F-H that fit the same profile. When I was flying those (different eras), my other planes just sat in the garage with no usage.
I like to fly the same model so much that I learn it to the point where I can begin to do stunts with it that others would think are impossible. You need a really steady model and consistent running engine (not the most powerful or expensive) to do this kind of flying. What's cool is that you show up with a model that looks ho-hum and not particularly special, then you subtly, without any kind of announcement or fanfare, begin your routine. Your routine appears to be just normal sport flying for most folks, then you begin to tighten up the low flying maneuvers, and move them even lower to the ground. I push it until I begin to hear signs of relief, oohs and ahhs from the audience. But, I still try to appear as though I'm just casually sport flying, with no expectation that anyone is watching my peformance. What a hoot. Especially when they applaud upon landing.
There used to be some old fellows that had a routine using models of Cubs. I do not know their names, but they always put on quite a show. I wish I could fly as well as they.
Ed Cregger
NM2K is offline
Old 05-07-2008, 01:20 PM
  #674
freeonthree
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I don't get to fancy with my Stearman, I never learned too many stunts. I tried flying inverted in the past, and it alway ended the same eventually, so I just quit for plane preservation. I do loops, rolls, and hammerheads, and some cool turns, but thats pretty much it. I perfer a medium slow speed, and my favorite thing is landing. I probably land 10 to 15 times per flight. I just like to land really...
Old 05-07-2008, 01:46 PM
  #675
NM2K
My Feedback: (14)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
One of the things that the older gentlemen did was to run their Cubs around the field on one wheel. I still can't do that for long, but these guys could do circles and figure eights on the ground. I have a long way to go to get anywhere near as good as these guys. Whatcha wanna bet that they both started out just loving to land? 8>)
I'm hoping that the SV26 I have turns out to be a long lasting engine with very reliable performance. I have a couple of larger Cubs that I've been saving for just this size engine.
Ed Cregger
NM2K is offline
Contact Us Archive Advertising Cookie Policy
