New SV Gassers
#226
NC
RE: New SV Gassers
ORIGINAL: freeonthree
I made a little degree wheel tonight and checked my timing. It was too far advanced bigtime ! I had to elongate the slots in the sensor to make it go retard far enough to get to 30 degree's before TDC. Now, the screw on the left is right next to the sensor housing. Here's a pic showing my sensor position after setting the timing.
#227
RE: New SV Gassers
are here results with more returded timing? what I can say, that when I have retarded it from facktory settings as far as I could, I got about 0.5kg more thrust and better ideling, and high rpm ignition misses ahve been dissapeared. but it misses sometimes even now when it's not worm enough
#230
RE: New SV Gassers
misses at wot. adn i noticed, that when I retarded ignition, it needs leaner high speed needle settings to prevent missses. what about youres, what are your needle settings? my are 1.1/2
for sure it's 4 cyclening when ideling [8D]
#231
RE: New SV Gassers
Yep, mine would randomly miss (da da dada da da dada da da dada), but the full throttle miss went away after I retarded the timing the first time. I was never able to get the miss out of the midrange, but there would always be a sweet spot at about 1/2 throttle where it would be mint. Either it needed to be more retard, or the ign box is having an issue, but then how would we explain the sweet spot, and it would not miss as long as I held that throttle setting. It's real windy here now, so I havn't fired it up yet since the repairs and 18x6.
#233
RE: New SV Gassers
Im not believing that at all. I bet the piston to cylinder fit is just as accurate. Walbro carbs are fine, and bearings are bearings. I suppose it's possible that the cranks may be balanced better in the more expensive engines, but who knows. What else is there besides more detailed outside finishing, good for nothing really, and more expensive advertising which drives up the costs as well. The electronics may be better, but I hear that one of the big brand name cdi boxes had an overheating problem at one time, and mine has never even gotten warm when I checked it, so the real test will be how long it lasts. Weedeater specs ? Our last el cheapo $99.00 weedeater lasted about 10 years, and still ran when I snaged the choke for my plane the other day, so the clearances couldn't have been too sloppy. My SV 26 doesnt sound that much different than my bud's Brison 50 when it's running smooth, just smaller, and I have a feeling today, at least I hope, it will be running top notch. I seriously doubt that the engine itself has any issues. Looks like fine quality to me for a little gas engine.
#234
RE: New SV Gassers
Im a Saito guy origionally, this is my first gas engine, but I have been a mechanic my entire life, and I feel this engine is sweet. Greg and I just tested my engine with the new fuel lines, and ignition timing and 18x6 prop. It vibrated badly so we put the 16x8 and spinner back on. Flipped her once more and she started instantly. After a breif warmup, it transitioned beautifully, but had to fatten the top about 1/2 turn or so. Not one gurgle came out of this engine since, and it's spinning that 16x8 at 8200 rpm. The origional Jenn Feng spark plug is back in it now because the Autolite crossover from the NGK BPMR-6-F glitched the plane badly. Thats not to say he crossed the plug number correctly, I doubt it mostly. Overall, right now, my SV 26 is running like a swiss watch, and does not misfire at all anymore. Oh, we can't forget that I also switched to QuickSilver Full Synthetic @ 100:1. Gregs Brison 50 had been running on it for years. With the Pennsoil Outdoor 2 Stroke @ 32:1, I had black sludge all over the belly, and when I put my hand behind the exhaust, it would get real oiley, but now, the only thing that came out onto my hand was a few tiny carbon specs, and that quit shortly. There is zero moisture or smoke that I can feel or see coming out of my exhaust now, and I love it ! Yipeeeeeeeeeeeeeee ! This SV 26 runs every bit as nice and smooth now as Gregs Brison 50, it just makes a little less noise.
#235
RE: New SV Gassers
Greg and I just got the deal of the century ! He called me up and said he just bought a gallon of the QuickSilver Full Synthetic for $15.00 at Walmart. I paid $12.74 for a quart of it last night ! at walmart ! Needless to say, I got there fast and got me a gallon for $16.09 out the door ! At 100:1, thats 84 gallons of fuel mix at 19 cents a gallon for the oil ! I think we died and went to heaven...
#236
RE: New SV Gassers
Well I havent changed the plug,,,or the carb,,or anything eles except the timeing,,spinning 18x8 @ around 7200rpm ,,no miss or splutter good spool up real good on a 10lb 3D plane
#238
My Feedback: (14)
RE: New SV Gassers
I have an APC 18x6w on mine and the SV-26 spins it at 7400RPM. I would check your prop and make sure it is balanced correctly. A prop that is not balanced with vibrate badly. I am almost finished with my Stinson and I can wait to going flying. The plane weigh's 12.5 lbs. I is very cold here now and I don't like flying in cold weather so it my be a while before she goes up. I'll post a pic when I have finished the build.
#240
My Feedback: (14)
RE: New SV Gassers
I just backordered an SV50. The 26 looks so good, I decided to give their 50 a try.
It was all I could do not to order the SV50 TWIN and 100 TWIN as well.
Ed Cregger
Dagnabbit! Forgot to say TWIN the first time. Gettin' old stinks, but it's not as stinky as the alternative. <G>
Ed Cregger
#241
RE: New SV Gassers
Oh boy ! You lucky dog ! I don't see me stopping here either really. hehe
I decided to stick with the 16x8, and thats because I found these Zenoah 26 specs on prop size (Benchmark Prop: APC 16x8 @ 8,700 - 8.900 rpm). Good enough for me, for now anyway, im doin 8200. Close enough... The Zenoah has a velocity stack and probably a slightly larger carb, so im not offended.
#242
RE: New SV Gassers
Greg and I took the Stearman out to see how it would do in the air now, and it was super windy. The engine didnt require any further tuning, but it did need to warm up before it would get up some real speed up there. I'd say that 1 minute running on the ground, and another minute in the air, and she was awesome from there. Not on gurgle or sputter like before. I attribute that to the timing. It does do the 4 cycle thing when ya pull the throttle back, but so do most of the gasseres I see flyin. The main thing is, now it doesnt keep misfiring randomly anymore. Runs as good as Gregs Brison 50 now, just has less beans in the pot.
#244
RE: New SV Gassers
I agree... For putting up with a few little issues, like having to make a choke, and enlongate the hall sensor slots to correct the timing, we got quality engines that should last for many years. According to the HC site, there going to have parts and accessories for em soon too.
#245
RE: New SV Gassers
in my application I can get carburator with finger. of course choke should be much better and comfortable for me, but only 1 choking is requared per flight day as I see.
#247
My Feedback: (14)
RE: New SV Gassers
Talking about a choke for the SV-26 does anyone know if you cover the exhaust pipe on the muffler than spin over the engine wheel that ack like a choke? I know this works on my golw engines. It is in the 30's & 40's here in Memphis this week so I wheel need a choke of some kid to make the starting a little easier.
#249
RE: New SV Gassers
Here's how my SV 26 is running now. Most of the time, the plane is too far away to see well, but you can sure hear how close it is to perfect tune. I find it amusing that the ign timing was so far off from the factory. Also, the 6 volt, 2000ma NiMH ign battery sure did the trick. I flew quite a bit tonight, and was only down to 90%.
http://www.youtube.com/watch?v=dcyO6j6yikA
