DL-50 engine
#4326
My Feedback: (17)
RE: DL-50 engine
ORIGINAL: Super08
Bob, yes I did that on purpose and it seems to work good.
Chuck I don't run filters on my planes. I use a felt type filter on the pickup in my gas can as well as an inline filter on the filler hose going to the plane. So far I haven't had any problems with gunk building up in my carb screen. That's not saying it won't happen. But so far it has been working for me.
Doug
Doug
I was doing the same as you and got gunk in the screen. I also put a "crap trap" on the vent line because someone posted about getting dirt up the vent line from an unpaved runway. Cheap insurance for me.
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXD742
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXFU77
Chuck
#4329
My Feedback: (29)
GA
RE: DL-50 engine
I have a new dl-50 engine installed on a giant sundancer. After making the initial prep, I tried to fire up the dl-50. All I get are sputter and that is it. I can hear the engine wants to start but will not fire up properly. I tried to play around with the carb but still getting the same sputter. Any suggestion on getting the engine running is much appreciated. Thanks
PLY68
PLY68
#4331
UT
RE: DL-50 engine
I found that if I crack the throttle a touch it fires right up. I discovered this after I completely flooded the crap out of it several times because it simply wasn't getting enough air along with the gas. Mine sounded exactly like yours though. It would try to start, but the more I tried the less it tried to start (ie - the more it got flooded). Once it is going it idles perfect with the trims that low, but mine needs more air to start - that's it.
#4333
RE: DL-50 engine
Can someone please tell me should the gas line to the carb be long or short or what? I might have al ready got this but this goes to show you about old age DUH!!!!
#4334
MN
RE: DL-50 engine
PLY68, Small gas engines just like any gas engine need the proper fuel air ratio in the combustion chamber to fire. On a carburated motor it is tough to get the mixture just right to start. Different altitude, temperature, humidity,and choke all make a difference. The manufacture tries to design the choke to work in all the different scenarios but inevidably they can't. When you only get one compression stroke to start and run, your mix has to be perfect. That's why you have to open the throttle a bit to start these engines. The mix isn't just right.
#4335
MN
RE: DL-50 engine
Eric, the only reason the vent line needs to be run to the back of the tank is to stop syphoning when you tip the tail up. Or on long down lines while in flight. The carb feed line can be any length you want.
#4336
RE: DL-50 engine
I'm not sure what you mean exactly Eric, but the fuel pump will pump fuel from a very long distance away and will pull it verticaly more than 3 feet. So I don't think your plane is big enough to have to long a fuel line. You want to leave an inch or so of slack between the tank and carb.
#4337
RE: DL-50 engine
ORIGINAL: paul5992
#4338
RE: DL-50 engine
Thanks I got it now. You guys are so nice this is a great thread thanks. I got some of the crap trap filters two of them do I really need one on the vent? And yes are field is dirt hard pack. We just put up a nice shade here is a link to alot of videos from our club. http://search.live.com/video/results...&go=&form=QBVR
#4341
RE: DL-50 engine
ok guys I know that this has been talked about before and I went back through the threads and did not find it
what is the best way or things to use on the exhaust flange and bolts to keep them from comming loose thanks
JIM
JIM
#4342
RE: DL-50 engine
ORIGINAL: OldRookie
Where can you get a one way valve like the one you described?
http://www.horizonhobby.com/Products...?ProdID=FOR150
tank -> T coupler -> valve -> intake at the top of the firewall
When you fill the tank, the valve closes and fuel is forced through the return line connected to the coupler.
#4343
RE: DL-50 engine
ORIGINAL: SIXGUNS
#4344
RE: DL-50 engine
actually, if you tighten them (when cold) just right, not too much, and not too weak, they wont come off at all from vibration or any other cause. No need for red or blue loctite or any other stuff.
#4345
RE: DL-50 engine
I don't know where I heard this but it works great. Take them apart and when they are nice and cool put a little oil on the threads and they won't come apart. It works I do it on my saito's and they never come loose.
#4346
MN
RE: DL-50 engine
I've had my muffler fall off 3 times. So do yourself a favor. Go to the hardware store and buy yourself some new bolts that are long enough to go threw the muffler and threw all the threads of the head on the motor. Also buy some washers that will fit in the muffler bolt holes. Also get some red lock tight or some other permanent loctite. I've had to buy an 80 dollar Heili coil set because I thought I new better. Do what you want. But if you don't do it right you will be back on here asking me where I got my heili coil set.
#4348
My Feedback: (42)
NC
RE: DL-50 engine
ORIGINAL: paul5992
#4350
My Feedback: (42)
NC
RE: DL-50 engine
ORIGINAL: giddyuperic
It is even worked on my DL too. I thought locktight will melt under the heat???????
