Go Back  RCU Forums > Glow Engines, Gas Engines, Fuel & Mfg Support Forums > Gas Engines
Reload this Page >
FUJI 32 EI SPARK PLUG CABLE FIX HELP!
Old 12-15-2007, 09:25 PM
flaviosi
Default FUJI 32 EI SPARK PLUG CABLE FIX HELP!
Hi, guys,
I'm a happy owner of a Fuji 32 EI and unfortunately the cable that goes from the ignition to the spark plug was loose and a sharp edge cut it...
Is there any way I can replace it? Or fix it? Or do I have to buy another ignition?
Thanks for any help!
Flavio
Old 12-15-2007, 10:37 PM
tkg
Default RE: FUJI 32 EI SPARK PLUG CABLE FIX HELP!
See if you can unscrew the lead form the ignition box. If you can then its a simple repair to use some plug wire from a motorcycle.
Old 12-16-2007, 06:49 AM
flaviosi
Hi,
I don't think so... The ignition seems shielded. No screw to unscrew....
Flavio
Old 12-16-2007, 10:43 AM
tkg
Ok the unit is bad, so you can't hurt it any more[:@]SO see if the spark lead will twist and unscrew from the bix. Shielding you make from RG 58 coax cable.
Old 12-16-2007, 11:18 AM
Tired Old Man
Worst case, send TKG a pm and send the unit to him for repair. He does that sort of stuff all day, every day.
