CH ignition
CH ignition
On a twin cylinder BME engine with ch ignition, is there a left and right sparkplug lead? And if so how do you tell which is which? Also, how do you toubleshoot for a spark? If I take out the sparkplug and turn the ignition on I get a spark. However rotating the prop I get no spark? Any suggestions?
CA
RE: CH ignition
There is no dedicated left or right lead. If you get a spark when you turn it on but it will not spark when you rotate the crank more than likely the hall sensor is out. Do you have the sensor connected correctly, and is the battery in good condition?? You can also test by completing a circuit on the plug from the ignition unit, but I can't remember which two you use. E-mail CH or PM TKG here on RCU.
CA
RE: CH ignition
The metal cap is grounded to the braided wire that goes to the unit. As long as you have a plug in it you will be fine. Well, UNLESS, you also have a ground strap because someone replaced the rubber boot cap with metal ones.
WY
RE: CH ignition
May I offer a radical suggestion.
Go to the CH web site and follow the trouble shooting instructions???
www.ch-ignitions.com
AZ
RE: CH ignition
ORIGINAL: tkg
Thats just plain unamerican.
