ZDZ 80 RV-J eng template on Comp ARF extra 330L 2.3m
Hi all,
I have ZDZ 80 RVJ(Super 80) in hand would like to use on my Comp ARF extra 330L 2.3m plane. Instruction shows how to mount the DA50 onto engine doom. I have searched the web about the engine installation template and could not found yet. Anyone has the dimensions or drawings or tamplate for ZDZ super 80 on CARF extra 330L 2.3m engine doom??*
Reccommendations highly requested
thks
thks
My Feedback: (24)
GA
RE: ZDZ 80 RV-J eng template on Comp ARF extra 330L 2.3m
Just make one, It is easy, Get the dimensions form center to center for the mounting holes and draw on a pc of paper, Or you can remove the carburetor and lay the engine on cardboard and trace the layout. Then draw a center line in both directions to get layout for firewall.
Milton
Milton
Alternativly, put the engine on its stand offs and put the fus vertical supported on its wing spar in the tube, mind the fin and rudder don't rest on the ground, they will not take the weight, then put the engine in place on the firewall and put on the cowl, move the engine around until it lines up with the cowl and carfully remove without disturbing the engine position, then mark the position of the mounts on the firewall, dont forgett the extra washers for side and down thrust.
Mike
Mike
