RCGF Engines
Old 11-15-2013, 01:36 PM
  #6101
Lifer
Lifer's Avatar
Is there anybody in your area with experience with gas engines. When all else fails, I always go back to 1.75 turns on each needle and then set the high, followed by the low. Put in a new CM-6 plug gapped at 24 thousandths. Don't give up!
Old 11-16-2013, 09:41 AM
  #6102
oldbassard
Stangevil
I face the same problem and am interested in every ones responses. Here's what I am doing and have came up with on mine, by the way it's a 4star 120 and I am using the same engine you are. If I cut a hole in the firewall, it takes up room in the fuel tank department. Also by doing it that way, you will inevitably get gasoline inside your airplane. I guess you could make a sort of cup into the fire wall and fuel proof it for the carb to go back into. At this point what I am thinking is maybe mount the engine to the firewall with out the altering the firewall and counter balance the airplane, which will add a little weight in the tail. But that is just what I am thinking, I know there are a ton of guys here with WAY more experience than I have so let's see what others have to say.
Old 11-16-2013, 10:44 AM
  #6103
dirtybird
Originally Posted by hsukaria
dirtybird, I don't have direct RCGF experience, but based on other engines I have dealt with, I would sacrifice the low idle and set it to about 2500 rpm, then try a little richer setting on the low speed needle. Seems like it's leaning out in the mid-range. I would also make sure you are running with fresh gas mix.
That essentially what I wound up with. I set the low speed 1/4 richer then used my transmitter to limit the idle to 2300. Now it runs quite well and takes the throttle even if I jam it open and it runs in midrange.
Now maybe I can get a flight out of it.
Old 11-16-2013, 12:27 PM
  #6104
ANGAL
I think I solved my problem: wandering Italian Forum , such as :go-kart / motocross, and others where they use in all gasoline engines ..... is said that using a 100% synthetic oil the right percentage of oil is 2%
I just did a flight and the engine did not switch off ..... hopefully good
Sunday rain, so next week I'll do more flights and I will tell you ..... anyway I'm almost convinced that I have found the solution.
Who is in my condition suggest you do this test, it costs nothing.
Angal
Old 11-16-2013, 06:27 PM
  #6105
Hawk131
I have the 26cc RCGF blue head type engine on a Extra 260, it was maidened last Sunday. it has not been broken in yet. the idile is high for about 10 seconds after I go full power and then goes down to about 2500 rpm. Is it because it hasn't been broken in or maby the low needle off a little?
Old 11-18-2013, 07:32 PM
  #6106
rt3232
Well guys
Just an up date, as previously posted I bought an RCGF- 62 from B P Hobbies and right out of the box the ing was bad, E-mailed BP and they said send it back did that and now have a working ign nothing big.
I don't know who else handles RCGF
But I have to say B/P Hobbies has vary good coustomer service, and will get my business when they have what I am looking for.
Cheers Bob T
AMA13377
Old 11-18-2013, 10:44 PM
  #6107
Captmicom
Hi Bob,
Look at the bottom of my tag line. I am the RCGF service center for the USA but I also sell them too straight from the factory... Cheers!!
Old 11-19-2013, 04:43 AM
  #6108
ahicks
I think what you're talking about is what is known as high idle hang? This is where the engine doesn't return to idle speed right away, especially after being run at higher power levels. Not too big a deal. Low speed is likely just a hair lean. Richen a tiny bit at a time until the 'hang' is under control.
Old 11-19-2013, 01:16 PM
  #6109
av8tor1977
av8tor1977's Avatar
Yep. 1/8 turn (or less) more open on the low speed needle will most likely cure that immediately. Will make cold starts nicer too.
AV8TOR
Old 11-22-2013, 02:47 PM
  #6110
psgugrad
Originally Posted by Captmicom
Hi Bob,
Sorry to keep bugging you...ANY info yet on the 10cc engine? I'm pretty pumped about this thing
Old 11-22-2013, 06:44 PM
  #6111
Captmicom
Yes the engine is ready and I should have one if RCGF can got the new carb done. My next load is due within the next 2 weeks. The lil motor puts pretty good with a 15cc carb on it but the devo engineers feel that with a smaller more controllable carb on it, the engine will make a lot more power. So hang in there and I will let you all know as soon as it gets here. I will not be testing it right away though because I have a lot on my plate right now.
Old 11-22-2013, 06:55 PM
  #6112
Hawk131
Thanks guys I will richen up the carb a bit.
Old 12-03-2013, 05:22 PM
  #6113
Captmicom
Hello Blog Mates!!
Ok this is it.. I will draw the winner for the RCGF 60cc single tomorrow!! Good Luck to all of you!!
Old 12-04-2013, 09:46 AM
  #6114
Captmicom
Howdy Blog Mates!!
I would like to thank everyone for participating in the RCGF 10th Anniversary Engine Give-A-Way. We had a great turnout for the drawing. So may we have a drum roll please!!!
The Winners of the RCGF 10 Anniversary Give-A-Way are..........................
Tim5713
DDewey
You both will receive "The New RCGF 60cc Single Engine". If you two will PM me with your contact info I can get these engines started out to their new homes.
Thanks again to all of our participants and congratulations to our two "WINNERS"..........
Kind Regards,
The Capt'n
Old 01-20-2014, 05:44 PM
  #6115
voodoodb
My Feedback: (98)
voodoodb's Avatar
I got an old ( bought in 07) rcgf 50 engine that witha zoar 20x10 is turning 7200 rpm. Is this about right? I had trouble with after I got it and it has been put up since then. Got it out the other day and put a walbro carb on it and am just wondering if the rpm is good.
Old 01-20-2014, 05:57 PM
  #6116
Captmicom
Hey Voodo,
That sounds about right. I was swinging a 22x8 Xoar at about 7400 rpm back in the day. Who did you get it from? What does the case look like? CNC or cast?
Old 01-20-2014, 06:00 PM
  #6117
voodoodb
My Feedback: (98)
voodoodb's Avatar
It's a cast case. Rear carb, reed valve. I bought it from RCGF. I was working and living in Tianjin China. I got it and a side carb 65, but burnt the 65 up. Didn't locktite everything and the carb came loose in flight.
Old 01-28-2014, 04:15 PM
  #6118
[email protected]
i wanted to send my rcgf 15cc back to have a carb put on they said no they had no one to work on them still under warrenty to bad they said
Old 01-29-2014, 02:48 AM
  #6119
Lifer
Lifer's Avatar
The carbs for the DLE 20 and 30 will bolt right onto your RCGF 15. I have a 30-carb on mine and it runs great. About an 800 rpm increase. Tower sells the carbs.
Old 01-29-2014, 05:16 AM
  #6120
ahicks
Interesting. What company did you contact that told you that?
Old 02-01-2014, 12:27 PM
  #6121
[email protected]
iam looking for someone to do a repair on my 15ccrcgf gas engine>> thanks allen
Old 02-01-2014, 04:18 PM
  #6122
SU-31 flyer
SU-31 flyer's Avatar
BJ's Model Engine Service is has ad's in High Flight mag. I'm not sure if he works on rcgf engines but you could ask. E-Mail is: [email protected]
Old 02-01-2014, 06:02 PM
  #6123
erieqc
Captmicom he's a dealer get ahold of him.
Old 02-01-2014, 08:19 PM
  #6124
Captmicom
Thanx for the plug Eric... Bill is a repair for pay only shop. I would like to know how you got your RCGF 15cc engine from and when? Later.....
Old 02-01-2014, 08:23 PM
  #6125
Captmicom
Let me try this again... Allen where did you get your engine from, and when? Have you and I talked about it before?
