RCGF Engines
#6401
Hi Steve,
The RCGF USA engines sold by authorized resellers here in the USA will come with a 2 year parts and labor warrantee on manufactures defects. I take care of all the service here in the US. Also if you bust it we can fix it but it will cost you. The 60T is available. As for the twin family we have, 20T not for release yet, 30T, 40T, 50T, 60T, and the monster 120T. I do also have other engines on the drawing board but we don't talk a lot about them because when we do our competition runs in behind us and they have the same engines two weeks later.
#6402
Thanks for the quick reply. So, if the need arises to send it in for service, where does it go? In the U.S.? Sorry for all the questions. I used to just buy stuff online without looking into it first and learned a couple lessons the expensive way. I'm sure a lot of us have. I think I will buy the 60 T for a 1/3 Andy Sheber Pitts build. One more question, is the 60T available now, and what's the site where I can order? Thanks again for all the info.
#6403
Not a problem..
Yes for service you will send it to me in Southeast Arizona.
Yes the 60T is available now.
The site is: www.rcgfusa.com
good luck...
good luck...
#6407
Hey Lifer,
It uses a 1/4-32 plug. Thanks for pointing that out. We are still trying to clean up a few things. When the web designer posted the info I guess there was some cut and past that took place....
#6409
Well guys been NO activity on the thread for a bit. So I am looking thru my note's for the best way to tune a gas engine and for the life I can NOT find it. As I recall there is about 4 steps, but they should be done in the proper sequence. You would think a guy that has been running gassers for 25 years would have it in memory, but do to age (83) little things that I only need to do about once or twice a season I have to write it down, So if any one has the steps, Please post them, as one of my oldest RCGF-26 engine is telling me it needs to be tweaked.
Thanks in advance
Cheers Bob T
Thanks in advance
Cheers Bob T
#6410
Forget the fact that it's a gas engine and tune it like it's a 2-stroke engine. Start your needles rich (like 1.75 turns out), tune the high end til it is in a clean 2-cycle and then lean the low-end needle til it has a clean transition. From that point fly it and make fine adjustments to suit your preference.
#6411
Lifer
Thanks for the reply, I got to thinking about the hrs on this engine, so looked at the log about 15 hrs and never had a plug change, MY bad, pulled the plug it is showing some metal loss on the center electrode, but it is a nice dark brown, so a bit rich to, so will install a new plug and lean both needles a bit and see how it runs.
Cheers bob T
AMA13377
Cheers bob T
AMA13377
#6412
You are not alone, with your need to write things down.
#6414
Well been testing my RCGF-26 it seams to be lousing some RMP, what prop's size is recommended, I have tweaked the carb and the max RPM on a xoar 18 X 8 is 6350 engine has great idle, transition and sounds good at fuel throttle, but my engine log show's 6500 on the same prop back about 8 hrs, of run time, I am running it on 100 ave gas @ 40 : 1 and a new plug. So any suggestions ?
Cheers Bob T
Cheers Bob T
#6418
It just seams odd as this happened all to sudden.
Cheers Bob T
9
#6419
