RCGF Engines
Old 05-02-2017, 11:25 AM
  #6751
captinjohn
Default Engines
Hi Karol, It is kind of nice to be home. The thing is though it turned very cold here in Michigan. May have frost at night. I cannot seem to get warmed up good....wife keeps the heat set too low. Got to go & get a hot shower. It is good hearing from you my Friend. John
Old 05-09-2017, 09:26 AM
  #6752
SwampFlier-RCU
SwampFlier-RCU's Avatar
Originally Posted by rt3232
Tom
I have 2 of the 26's with stand off mounting, what I have learned with gas engines, when bolting thru the fire wall ( even with A/C ply) in time it tends to crush and the bolts get lose, So I make some OAK dowel 1/2 dia and epoxy them in the ply and a fender washer both sides blue lock-tite and have not had any problems with this even with G-62"s it is a bit of extra work but well worth it in the long run.
Hope this helps
Cheers Bob T
Bob:
Could you post a picture of this setup please
Thks
Patrick
Old 05-09-2017, 02:46 PM
  #6753
wally3185
My Feedback: (26)
wally3185's Avatar
Default 15cc low end idle
Just starting to break in a RCGF 15cc (my first RCGF). From mid throttle to full, good transition and good rpm, running a 14x6 Xoar. Haven't gotten a good reliable idle yet, it wants to pulsate a lot at that lower rpm, can't decide if its a little lean or to fat. Or should I just run some more fuel through it at mid throttle and then see if its better?
Old 05-09-2017, 04:51 PM
  #6754
do_hickey
Could someone tell me the gap for a CM6. I have a twin 40 and love it. Put it in a Corvus with Hitec 5645 servos and is a great prefomer for me. Running rough mid rang so checked gap. One was 30 and other was 19. Set both at 20 and runs better but want to make sure it is correct?
Old 05-20-2017, 05:54 AM
  #6755
mikeboztx
Wonder if anyone can figure out my problem with a new 56cc I just bought this week? I put it on test stand to start break in, and thank Got I was also trying out a new Rolling Chicken Stick also. When I flipped it it back fired and broke a new $25 prop. Put on second prop and now I'm $50 in the hole. I pulled plug and with magnet 180 from sensor (motor not turning and ignition on) plug was constantly firing. Does this sound like a sensor problem or an ignition problem. I have to call Valley View on Monday. Mike
Old 05-20-2017, 10:15 AM
  #6756
karolh
For most engines they seem to perform best when gapped between .020" and .024". HTH.
Old 05-20-2017, 04:26 PM
  #6757
do_hickey
Default .22 works
Set plug gap at .22 and runs like a sewing machine, thanks
Old 05-21-2017, 02:55 PM
  #6758
rt3232
Just a comment on plug gap over the last 30 years of running gassers I all ways set all plugs @ .024, and after a few tanks of fuel thru them check for carbon build up. even my weed whip, lawn mower , but then I only use 100 ave gas in my model engines.
Cheers Bob T
Old 05-22-2017, 09:51 AM
  #6759
jimbrock2
Thinking about the 20cc. Anything changed since 2008?
Old 05-22-2017, 01:18 PM
  #6760
karolh
There are several available options, some new and some old, such as, DLE20, RCGF20, NGH20, VV20 & 21, Evo 20, OS 22 (for those with deep pockets) and the Zenoah G20 to name a few.
Old 05-22-2017, 05:04 PM
  #6761
ahicks
To my knowledge, it's virtually the same engine, that's still making new friends all the time.
2 things noteworthy maybe, are that there is a 26cc beam mounted engine (that's nearly the same size and weight as the 20) that you don't hear about much (despite the fact it pulls an 18x6 easily) , and second, ValleyView RC is now involved in selling/supporting RCGF. That's a huge bonus in my book!
Old 05-23-2017, 05:34 AM
  #6762
karolh
In fairly recent times I have found Valley View a bit fickle in their offerings as they have carried a few engines and then quite suddenly stopped. But then what do I know, that might just be the price for business progress.
Old 05-23-2017, 05:14 PM
  #6763
do_hickey
I have a RCGF twin 40 that I put in a 76" Corvus. I have about 50 flights on it to date. I run Redline oil at 40:1 with regular gas. I put a 20-8 prop on her and does a wonderful job for me. Stock mufflers work fine. I get 10 min of flight time with a couple to spare on 18 oz tank. Had to cut cowl for plugs but looks fine. Hope this helps. Would buy another one in a heartbeat!
Old 05-24-2017, 01:57 PM
  #6764
SwampFlier-RCU
Better to go to the source, Joe has a smooth running operation!!
Regards,
Patrick
Old 05-28-2017, 02:53 AM
  #6765
OldScaleGuy
OldScaleGuy's Avatar
All, please have a look. Mention this post and receive a 10% discount.
http://www.rcuniverse.com/forum/prod...rc-models.html
Old 05-28-2017, 07:51 AM
  #6766
erieqc
Default Rcgf 15 muffler
I need a little help I don't have one of these and I would like to know what the measurement is on the bolt holes if anyone has one and are kind enough to measure it for me I would really appreciate it.
Thanks Bill
Old 05-28-2017, 08:38 AM
  #6767
OldScaleGuy
Thanks Bill
Hey Bill, muffler centerline spacing on an RCGF 15 is 29.0mm.
Old 05-28-2017, 09:37 AM
  #6768
erieqc
Ok thanks
Old 05-28-2017, 11:27 AM
  #6769
karolh
Hi Steve, I just visited the Leisure RC Models web site hoping to find some information on RCGF engines but found nothing, how come ??
Old 05-28-2017, 02:06 PM
  #6770
Desertlakesflying
My Feedback: (28)
Best place for info is Tom at Valley View
https://www.valleyviewrc.com/
Old 05-28-2017, 04:16 PM
  #6771
karolh
Thanks for that bit of info.
Old 05-30-2017, 02:59 AM
  #6772
OldScaleGuy
Leisure RC Models just recently, within the past two weeks, became a dealer for RCGF. Plus i am the webmaster for the the site and don't really like sitting in front of a computer all day to make updates. Updates will be coming it will just take some time. Please bare with us. In the mean time if there is anything we can help with send a PM, e mail or phone text or call.
Thank you.
Old 06-01-2017, 03:40 AM
  #6773
rt3232
Hi guys I have 4 RCGF 's 2-26 both stand off 2-62 stand off and a 32 stand off and have found that all are great engines for there price and reliability and because of the newer porting they produce a better power curve than some of the others, but none of them are a bad choice it's just a matter of $$$
Just my thoughts
Cheers Bob T
Old 06-01-2017, 08:18 AM
  #6774
karolh
Steve, can you say if the beam mounted RCGF 20 and 26 engines share the same bolt mounting pattern.
Old 06-04-2017, 08:06 PM
  #6775
captinjohn
Smile
I agree with that !
