RCGF Engines
#1252
RE: RCGF Engines
I ran a 62cc for a short little time last week. It was mounted on a ARF MFG SU 26 and looked good. The engine and the muffler fit completely under the cowl and I am assuming the nirto planes SU will be the same size and cowl.
The engine turned some 6600RPM with a Menz S 24X8 brand new and out the box. The customer was very hesitant to me touching the needles and left them at 1.5turns each.
The engine runs very smooth, and has no burble at all. I think that if we would have tuned it better, it would have turned higher nr's.
Please bear in mind, that I am stuck in one very high altitude Country and the engine was run at about 5000 feet above see level.
#1254
RE: RCGF Engines
Yes - There is not really much comparison between the 62 and the 65. IMHO the 62 wins hands down every time.
The 65 is about the oldest of the engines in the RCGF range. In fact they manufactured it as an OEM manufacturer for a couple of brands. It is a reliable engine but it is bulky and heavy by this years standards.
The 62 on the other hand is a more up to date design with more useful power than the 65 - it is lighter and MUCH closer to the "50 size" dimensions.
The Pitts mufflers (coming soon) won't fit the 65 (due to interference with the back of the cooling fins).
Ok - question time for you guys
Would you prefer to see the engines offered without exhausts? (Similar to how certain other manufacturers do) then you can order your exhaust of choice at purchase time?
That choice could include Pitts, Canisters, Standard Mufflers (as in the ones currently supplied) or standard with the corner cut off.
Henry and I are currently finalising details on the new range of exhausts so watch this space (That includes the 2 into one option for the 50 twin)
#1255
MO
RE: RCGF Engines
That would be nice to be able to pick your own muffler. But for the good price that the engines are now, who can complain... its like paying for the engine and getting a free muffler with it. So your saying that you buy the stock engine with no muffler at a lower cost, and add your muffler choice to it?
#1256
RE: RCGF Engines
ORIGINAL: T3beatz
Yes- that is exactly my thought.
It is just my thought - I haven't run it past any of the other distributors and I don't know how much lower the cost would be - just a thought.
#1257
RE: RCGF Engines
i still dont know how to link up the choke and throttle servos to the carb properly on either the sidemounted or rearmounted carb on the big engines. i plan on using the towerhobbies TS-69 standard servos on the choke and throttle with a magnet ring to eliminate radio interference. dont know what throw to use on the servo horns or the carb horns. or what length of horns. i see articles on modifications to the gasser carb horns with a longer horn and dont know if that is required.
i would like to have the pitts muffler for a uniform look not just one down tube hanging from the engine. im told by others that have the nitroplanes su-26 are adding alot of weight up front and putting all three batteries up in the cowl over the engine box to balance this plane because it is tail heavy. and also feels to them like it flys heavy. so if the pitts muffler adds weight so i can avoid putting the 2 rx batteries up front with the ignition battery maybe that would be a good idea?
#1258
RE: RCGF Engines
T.O.M,
I know, and I would if I could, have you any idea how nice it is to fly at sea level during the holidays, when I go to the coast
This is one of the perks that I don't want to miss.
one day when I grow up, I will go live there
Steve,
don't slam that 65cc too much, they are one of my favorite engines, the one I have, has been to hell and back and it's always been a one flipper.
As for the Su from Nitro, the tail heavy thing is a problem with the SU's, that is why my Customer went from the 50cc to the 62cc. And then of course, there is the elevation that I am famous for.....
Steve,
#1259
RE: RCGF Engines
Yep - gotta admit that 65 sure is reliable and bullet proof - no doubt about it. I have one that has outlived 3 airframes after "ground testing incidents" and it just goes from one to the next. Who knows one of these days, I might even have to put some spare parts into it.
Funny thing is - I originally put it into an ARFMFG 50cc SU (Very similar to the Nitroplanes frames) for the exact same reason - nose weight.
#1260
NY
RE: RCGF Engines
ORIGINAL: Tired Old Man
cmoulder,
Thinking more about that twin 50 of yours. Until recently the only small twins I've seen used were 3w-56 and what I think was a small BME a long time ago. So as far as muffler designs there hasn't been a lot to go on. The 3w was headered to a single pipe and I can't recall how the other was set up.
Since a twin 50 eliminates the normally centered cylinder and moves the exhaust locations to outside positions....perhaps a twin muffler design that sweeps both mufflers towards the crankcase to some extent, or easier still, a manifold for a two into one muffler can design, might be conceivable.
cmoulder,
I think the vast majority of users will need this anyway, and it would make it an attractive package.
Imagine an ad or a review in a magazine demonstrating that a guy could install this nice little setup in an Edge or Extra without hacking up the cowl at all. This would be an extremely strong selling point.
Seems to me the angled stock mufflers should be standard, and I'd be quite happy with the option to buy the 2-into-1 muffler or can.
#1261
My Feedback: (15)
AL
RE: RCGF Engines
...., or easier still, a manifold for a two into one muffler can design, might be conceivable.
Mike
#1263
RE: RCGF Engines
I put the 20 cc in a world models extra 330L 60 size. It weighs 7.5 oz more than the supertigre 90 but the battery for the ignition of the 20 cc sitting behind the canopy takes care of that, the 8 0z tank sits sideways in front of the wingtube and I made a 3/16 ply mount to bring the engine far enough forward to clear the caowl. the supertigre 90 ran 16 minutes at full throttle to deadstick, throttle servo linkage came off just as I was going vertical!!!
rkliemann
rkliemann
#1264
RE: RCGF Engines
Here's a few progress photos of the 26cc on the P-47
Little bird told me that the CM-6 plug/cap will be shorter - looking at this (stock) I shouldn't have to cut the cowl for plug clearance.
Business end. Going to light her off in a few hours
#1265
My Feedback: (8)
RE: RCGF Engines
You should put some foam rubber under and in back of the electronic moduel to protect it from the vib. The mount sure looks good. Or is there foam there and i just cant see it. I plan on putting my 26 in seagull 90 Yac
#1268
RE: RCGF Engines
Thanks. I have some foam backed velcro below the module, if I change to the CM-6 plug the mod gets replaced - so it's just "in there" for now.
Yep - those are PSP spacers behind the RCGF supplied spacers -and PSP 1/8" washers behind those.
#1271
RE: RCGF Engines
Looked at the RCGF 62..... an attractive engine, and I have a question.....the cylinder casting appears to be originally a piston port engine, but the inlet is capped . and the crankcase has been machined for the rear carb set up. just wondering what the original jug assembly was intended for.....
#1272
My Feedback: (49)
AZ
RE: RCGF Engines
Heres what you guys need and ill send a link to Henry so he can look.This is for the GT80 twin.I was going to post a pic but its so small on the site and when i try to blow it up it becomes blury.Maybe i can blow it up then clean it up.
http://www.bissonmufflers.com/en/muf...ting_id=114109
#1273
My Feedback: (15)
AL
RE: RCGF Engines
ORIGINAL: buck1856
For the Glasair installation, which has a very low profile cowling on the bottom, a muffler which I have described would still only work if the engine could be positioned back about an inch. That's why I asked Johnny (Factory) if they could come up with prop extensions; assuming the extension would not lead to other fatigue problems with the crankshaft.
Mike
#1274
RE: RCGF Engines
Yes - that is similar to one of the concepts for the 50cc twin muffler that we are currently working with. Ours is being planned to also help overcome the space issue of the "Extra" style cowls (Sorry Experimentalaviator, it still might not completely solve your issue though it wil help - we can't win them all). Of course the other ones are a "2 into one" header and canister set and a twin canister set.
As for the 62 cylinder? - who knows what was the original. There are only actually about 2 suppliers of good quality cylinder blanks here that supply about 85% of all the good engine manufacturers here (I don't dare to guess what that percentage is of all engine manufacturers though).
That is the reason that many engines look similar but the quality can vary widely from brand to brand. It is what happens after the blank is received that makes the difference.
