Prop nut for Brison 2.4?
My Feedback: (47)
GA
Hey guys I'm having a heck of a time trying to find a prop nut for my engine,,I have this Brison 2.4 Engien installed on the Hangar 9 1/4 scale Cub,, yeahh I know they call for a 20 to 26cc but why not I had the engine and it fits perfect..
Anyway I'm trying to finish the front of the plane up now that I like it a lot and I can not find the right prop nut for it.
This engine has a 3/8 -24nf threaded shaft and the propo nut needs to be as wide as the prop hub which is like 1' 11/16' but I think if I could find a prop nut that is like 1'5/8 to a 1'3/4 would look ok,, now the prop shaft comes out about 7/8' from the prop hub so the spinner nut will also need to be that deep.
will this be an imposible task to find something like this?
Thanks for any input!!!!!
My Feedback: (87)
RE: Prop nut for Brison 2.4?
Tru-Turn sells something they call a Prop Hub. It's built hollow like a spinner but shaped externally like a prop nut for a scale appearance. I just looked and it seems they offer them in 1-1/2 and 1-3/4" diameters that would seem to fit your Cub. When you click on the item you want to get to its details page, it will also have a link to their "adapter finder" to identify which adapter will be needed for your Brison.
http://www.truturn.com/cgi-bin/store...ophubs&maxp=30
