Which Prop for Gasser 26cc
I have noticed most guy's with gas engines use wooden props or carbon fiber props. Is there a danger in using the nylon props or is this because of realistic effect? What are the advantages or disadvantage of the use of each? Thanks Robert
RE: Which Prop for Gasser 26cc
It makes no difference if you want to run a plastic prop. I see lots of guys using Master Airscrew props on small gassers.
Thats not saying the plastic props pull any better. The only way to figure out which prop works best on your engine and airframe is to buy about $200 worth of props and fly them all. The prop that works good on this engine and airframe won't work worth a poop on the next airframe wit the exact same engine. Each airframe has it's own unique drag and handling characteristics.
Use what makes ya happy.
Using APC would not be feasable on bigger engines as it would get incredibly heavy on your plane and your wallet.
MA plastic and wood props are truly useless when it comes to maximum prop efficiency.
Xoar, NX, JXF, etc.. type of wooden props are more efficient, much lighter and cheaper to buy. Plus they look much better than both APC and MA IMO.
My Feedback: (10)
ORIGINAL: liquid_TR
In my mind I fly like Chuck Yeager. In reality I fly like Joe Average.
A ground strike with a wooden prop usually results in nothing more than a broken prop. A ground strike with an APC prop often results in a bent crankshaft, broken firewall, etc.
I use wooden props.
Rick
I use wooden props.
Rick
I am starting out with a 16x8 APC, the engine is 26 Evolution on a Showtime 90. I have read a couple of post from a guy that had this same setup and he was using a 17x8. I will test it with what I have and then go larger if needed. My original post was that I had concerns of using APC props because of some sort of danger issue. Never hurts to ask. Better to ask than to find out while your in the hospital from some sort of injury, from the prop coming apart. I saw a 14x 4W come off an OS61FX running max RPM, because of a loose prop nut. It snacthed the engine from the fire wall and slung that prop about 30 ft. I promise you that will leave a mark if you get hit with it. Thanks Guys I will post my findings or what I settle with. Thanks Again Robert
