20cc rear carb engine
I have been following this thread for some time to find out more about the new 20cc rear carb engine. It seems it finally is here in the states and some people have one. If someone would post some weight,measurements and price, I would appreciate it.
RE: 20cc rear carb engine
I have been following this thread for several weeks since I am interested in the new 20cc rear carb engine. Since they are now in the states and some people have one, could someone post the price, weight and measurements? All the post I see are someone has one but that is all the information given.
IA
Here you go:
http://www.zrcgf.com/store/Details.c...=26&category=2
Aerovate 20cc
Engine Displacement (cc)- 20cc
Bore x Stroke (mm) - 1.18"x1.10" (30mmx28mm)
Carburetor- Walbro type (HLIC)
Ignition- RCEXL System
Power supply- 4.8-6V
Weight - with ignition & muffler- 38.1 ounces (1080g)
Weight - w/o ignition & muffler- 29.3 ounces (830g)
Maximum Output- 2.2hp/1.65KW
Speed range- 1500-9800rpm
Gas/Oil Mix- 25-40:1 (90 octane gas)
Propeller- 16*6 9000 rpm
Full accessory package includes - Muffler, engine stand-offs, spark plug, bolts, tools, electronic ignition
FULL ENGINE SPECS -
Aerovate Engine Spec Sheet - 20cc engine.pdf
Price: $229.99
Aerovate 20cc
FULL ENGINE SPECS -
Price: $229.99
Thanks for the link but I already have seen that one. It is a side carb model. I want to find more about the rear carb since I have a model I am planning on installing it in. The width, height and weight will decide if I can use it. Also I am interested in the price. It has been a long time since I neglected to ask how much before I bought anything.
PA
I just got one from [link=http://www.kmp.ca/]KMP[/link] just wating for it to get here the price with shipping was $246 I can give specs to you when I get it. Just call them for the rear carb it is not on there site.
decent rear carb 20cc?? not likely to happen soon at a decent price. 20cc is still the realm for glow engines, so at best you could see a glow engine-like gas engine with front carb, so it can do without the xtra parts needed for a rear carb lay-out. Just my thoughts, it may not be yours.
Mitchf, you have been very helpful. Now would you mind giving me the measurements for prop hub to firewall, mounting width, width including factory muffler and height from centerline? Once I get these measurements I will be good to go. I plan to mount the 20 on a Bruce Tharpe Flying King.
I talked with Henry at RCGF about rotating the cylinder towards the rear. He and his crew think it is possible. You have to modify the cylinder skirt to clear the crank counter balance, but should work. I have one on order. I'll break it in stock, then later I'll sacrafice the warrenty and rotate the cylinder and see if it works. I'm planning on putting mine in a Rascal110 and some time later, I'll buy a couple more for busa 1/4 scale J3 and L4.
Edwin
Edwin
What about ring wear/cylinder mating. If you break the motor in first and THEN rotate the cylinder, are you not concerned about the fact that the piston/cylinder have allready mated with one another????
FL
Hey Guys
Aussiesteve and I are running the 20cc side and 20cc rear to get the numbers. As distributors of the Aerovate engines, we prefer that the guys put the rpm and thrust numbers on the blog, but these engines have stirred our interest. We see these engines as extremely plausible replacements for 70- 120 ci glow engines.
We put the engines on test stands and ran them using 32:1 gas/oil.
20cc Side mount - 16/6 - 9300 rpm...
20cc Rear mount - 16/8 - 9300 rpm....
The engines have less than an hour run time on them (he and I are in the middle of 6 other projects!)
There will be video posted on the
[link=http://www.zrcgf.com]www.zrcgf.com[/link] site tonight of the 20cc running a Profile plane... REALLY NICE!!!! Thanks T3BEATZ!!
Here are the links !!!!
[link=http://www.youtube.com/watch?v=OD6jaaO8Bgw]Aerovate 20cc Video 1[/link]
[link=http://www.youtube.com/watch?v=SveTee_jfKk]Aerovate 20cc Video 2[/link]
Wow.. nice videos! If those RPM figures are correct - the slimy and expensive glow power is over in 60-90 class as well!
Very nice engine! Its light, cheap to buy, cheap to run, very powerful and looks good. At last..
Its time we will see a 50% drop in price for OS engines hahah!
My Feedback: (21)
KY
That's a great looking motor, good price, and should be the perfect motor for my Sr. Telemaster to keep it out of glow. I only saw the side carb for sale on the website - any news on when the rear carb would be available?
