hobby city Turnigy HP 50 engine-any good?
Reply
Old 04-21-2009, 09:07 PM
grant118
My Feedback: (26)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default hobby city Turnigy HP 50 engine-any good?
Hobby city has a new gas engine Turnigy HP50. It looks to have a DL50 cylinder with a different crank case. Has anyone tried one? How do they perform?
grant118 is offline
Old 04-21-2009, 09:41 PM
larrysogla
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: hobby city Turnigy HP 50 engine-any good?
I bought the Turnigy 52cc gasoline engine from Hobbycity.com and it was delivered last week by the mailman. I have not fired it up since I am trying to clear my garage first. However on visual inspection the machining is OK and for $159.95 which I paid for it I am initially happy. I should be able to run it next month(May) on a test stand and hopefully with my garage cleared already I hope to test fit it on my CMP Cessna 140 83" wingspan. I eventually plan on running it on 1/3 10% glow fuel with 2/3 E85 gasoline as I already have received the glow plug aluminum adapter to run it on glow plugs eliminating the ignition battery, ignition module, spark plug and cable. Probably will save close to 1 lb. by going glow. Hopefully the airframe will be strong enough to absorb all this vibration and power. I plan on reinforcing the critical areas with triangle stock and plywood doublers just for insurance against wood/glue fatigue.
larry
larrysogla is offline
Old 04-22-2009, 01:01 AM
bcchi
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: larrysogla
larry
Good Luck,
BCCHI
bcchi is offline
Old 04-22-2009, 01:09 AM
NM2K
My Feedback: (14)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
How about some break-in time on gas/oil mix, as it was designed to burn? Otherwise, any failure, such as a busted crankshaft, or blown piston, won't really carry much weight if it occurs on gas/glow.
Ed Cregger
NM2K is offline
Old 04-22-2009, 08:55 AM
Walt and Sage
Walt and Sage's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I have one sitting hear waiting to be installed on a 50 cc Yak.
MUCH maching, SURE LOOKS NICE !!!! Hope it runs as good as it looks,,,,,
NOTE: for Lary
The 52cc is a 45cc overboar motor, not the 50HP motor...
We will be running the OVERBOAR this weekend on a Giant U-CAN_DO on its maiden flight..
Walt and Sage is offline
Old 04-22-2009, 07:35 PM
togatoga
My Feedback: (42)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I posted in another thread. I got 6450rpm on a menz 22x8 on the fiirst tank.
togatoga is offline
Old 04-22-2009, 09:09 PM
Tired Old Man
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
That's pretty weak if the carb was tuned. If the carb was not tuned there as no point in obtaining any numbers.
Tired Old Man is offline
Old 04-22-2009, 10:50 PM
dirtybird
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: AJ4PJ
Ed Cregger
I have a replica Super Cyclone gas ignition engine made in Phoenix in the 80's. It beautifully made.
The manual that came with it advises to break the engine in on no nitro glow fuel. They say the engine will run cooler on glow fuel.
dirtybird is offline
Old 04-23-2009, 03:09 PM
NM2K
My Feedback: (14)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
My father used to have an old hillybilly expression that he would say during such times. It was, "Paper will lie still for anything". Meaning that paper will let you write anything you want upon its surface without protest. Truth or wisdom has nothing to do with it.
I'm not trying to be insulting or a smarty parts. I only meant that using the engine in the conditions for which it was designed might reflect a truer picture of what kind of value the engine represents.
Ed Cregger
NM2K is offline
Old 04-24-2009, 06:01 AM
jonkoppisch
My Feedback: (161)
jonkoppisch's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
A guy in our club has one on a 30% sd yak. It flies the crap out of it!!!! It's been well used/abused and keeps on going. He loves it. For the price, if you break something, no big deal, get another... Anyway, after seeing many flights on it and how well it runs, several of us in the club have also bought them..
jonkoppisch is offline
Old 04-25-2009, 01:35 AM
larrysogla
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I paid $159.95 for my Turnigy 52cc overbore and on visual inspection it looks to be well machined........of course everybody now uses CNC machine tools, so more or less the machining finesse is there. As for durability.......forged crankshaft??, cylinder and piston metallurgy, ball bearing quality, shaft seal rubber compound, etc. Only time will tell................but hey!! for $159.95 if it lasts for 100 hours........then I got more than my money's worth. Model airplanes are only one heartbeat away from disaster that is why I am very reluctant to put expensive engines on my model airplanes and also my model airplanes are all under $225. I don't have money to indulge on expensive airplanes and engines.
Walt and Sage,
Please post on how the maiden flight went with the 52cc overbore on your U-CanDo. Did it have enough torque for unlimited vertical?? How much was the fully fueled all up weight?? Was starting the engine easy?? How was the break-in?? What gas/oil combination did you use for break-in??
Thanks in advance.
larry
Old 04-28-2009, 10:03 AM
Walt and Sage
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Walt and Sage,
Thanks in advance.
larry
Larry,
Maiden flight went PERFECT !!!!!
Motor was very rich new, had to lean H / L
Not sure about the model weight but will hover at 1/3 throttle
We are using Penzoil 32-1 for break in...
Motor is still a little tight and performance should improve over time but
MORE than needed to hover and pull out...
VERY FUNNY PLANE as all moves are in SLOW MOTION...
I may just do the same combo and remove the pink....
Note: There was a group of 10 or so young girls that clapped
and yelled at our every move with the CHEAP PLANE and Motor...[8D]
Installing smoke next..
COMBO worth every cent SO FAR..
Walt
Old 04-29-2009, 05:16 PM
parkfly14
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
glad to hear you guys are having good success with your engines. I'm looking at either the 45CC or the 52CC gas engine from hobbycity for my 1/4 scale patty wagstaff extra.
Does anyone know how to put a smoke system on this engine? That is pretty much the only thing keeping me from going electric with this plane
Thanks!
parkfly14 is offline
Old 04-30-2009, 01:22 AM
xyzengine
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The TGY 50HP is different from TGY 52cc.
TGY HP50 is a rotary valve engine,and the muffler is like this[link=http://xyzengines.ec51.com/offer/833055.html]muffler[/link]
xyzengine is offline
Old 04-30-2009, 02:36 AM
NM2K
My Feedback: (14)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: xyzengine
It would be nice if the website worked properly. I'm interested in the bicycle engine. Clicking the short cut takes me nowhere.
Ed Cregger
NM2K is offline
Old 04-30-2009, 06:04 PM
parkfly14
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: xyzengine
I also noticed the turnigy hp50 is also quite a bit lighter than the tgy 52cc. Do you know if the weight spec on hobbycity for the HP50 includes muffler, CDI igntion, ect?
Old 05-01-2009, 08:03 AM
Walt and Sage
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: parkfly14
ORIGINAL: xyzengine
Weight on the box says 1.38kg or 3.04lbs
Does not say what is included but the 50hp is lighter as we have both motors...
Old 05-03-2009, 12:07 PM
Tom in Cincy
My Feedback: (16)
Tom in Cincy's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
There are now 5 of the TGY 52's running at our field. They all run great. Pretty scary for such a cheap motor. Scary for the LHS and the other engine importers that is. One of the motors did have aluminum machine shavings caught in a red grease that packed the rear bearing. It was pretty obvious when turning the motor over by hand. It ran fine after getting sprayed out. Just a FYI. Lots of motor for the money.
Tom in Cincy is offline
Old 05-07-2009, 01:08 PM
JTF
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I got mine a couple of days ago - the Turnigy HP50 (or TR-50HP) is a rotary valve engine as mentioned above (DA and DL are reed valve engines) and the measured weight is:
engine with no aux: 1370 g
muffler: 102 g
ign system: 96 g
stand-offs (4 pcs): 77 g
plug: 14 g
misc (bolts): 50 g
TOTAL: 1709 g (1 kg 709 g).
BR Jussi
JTF is offline
Old 05-08-2009, 03:51 PM
LOGRUS
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I have it - TURNIGY HP50 50cc.
My motor have a broken rotary valve ( crack )/ i break in only 2 hour. [:@] Max RPM - 5800@3W 22x10
see [link]http://www.youtube.com/watch?v=8nwQvrUja70[/link]
Service Hobbycity does not work. I have written already five letters - deaf silence.
ID:	1194573   Click image for larger version
ID:	1194574   Click image for larger version
ID:	1194575   Click image for larger version
ID:	1194576   Click image for larger version
ID:	1194577   Click image for larger version
LOGRUS is offline
Old 05-08-2009, 07:21 PM
xyzengine
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
This is Carl from XYZ,
I see your issue,I think may be I can help you.pls contact me by zj-jn.cn@hotmail.com
If you would like send to us ,we will mend it for you with no charge.And if you want us to help contact Hobbycity we will alse be pleased to do so.
Carl
Old 05-09-2009, 08:42 AM
Walt and Sage
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Nice Carl, ............[sm=thumbs_up.gif]
Nice that you would help and to know you are here...
If my first 50hp runs good the next I will purchase from you...
Walt
Old 05-09-2009, 08:51 AM
LOGRUS
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Sended email.
Thanks and I am wait. Hope.
LOGRUS is offline
Old 05-10-2009, 07:52 PM
xyzengine
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Glad to know you here as well.
I will try my best to help you guys on our XYZ.
Old 05-10-2009, 09:57 PM
Mitsu1
My Feedback: (13)
Mitsu1's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: Walt and Sage
Walt
What need is there to buy direct from XYZ? XYZ manufactures the engine for Hobbycity. Hobbycity rebadges the engines as "Turnigy" and sells at a great price. When you buy from Hobbycity you are still supporting Carl and XYZ Engines anyways. Can't say for sure in this case, but buying 1 unit from the factory is almost always more expensive than buying in volume or buying from a volume purchasing dealer like Hobbycity.
Mitsu1 is offline
Contact Us Archive Advertising Cookie Policy
