If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Results 1 to 19 of 19
Thread: G62 power
  1. #1
    Join Date
    Apr 2005
    , IL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    G62 power
    Hi all,
    I am using a Zenoah G62 to power an 87" Ziroli Stearman. It seems uuder powered. It will not do a loop from level flight. Today I test ran the engine without the muffler. I picked up 500 RPM. I went from 6700 to7200 using an Xoar 22x8. Is this a typical loss for a muffler? Would 500 Rpm make the power difference to make the Stearman more aerobatic?
    Jim
  2. #2
    mrbigg's Avatar
    Join Date
    Oct 2004
    Streator, IL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: G62 power
    500 RPM is a big gain. I would recommend that you try a 21x8 or 10 on the 62 also and let it rev. You'll be shocked at the difference. I know people like using a 22" prop on this engine and that's what Zenoah recommends, but put a 21" on there and you'll see what I mean. That bipe you have is compounding the rev problem because of all the drag it has. The 62 makes it's power up higher in the rpm range.
    Smooth, like Keith Stone.
  3. #3
    Join Date
    Apr 2003
    Great Mills, MD
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: G62 power
    If you are using a stock muffler then yes, it will be down on power, by a good bit. Anything else will be better with a header and tuned pipe being the best for top power.
  4. #4
    Join Date
    Jan 2002
    Arcen, , NETHERLANDS
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: G62 power
    The stock muffler comes to life at elevated rpm. A 20x10 prop will have plenty of pull and speed
    Pe, (www.mvvs.nl), MVVS, MOKImotor, RCexl, MTW, Xoar, Mejzlik.
    Blessing in ignorance? There is sanctuary in analysis.
  5. #5
    Join Date
    Apr 2003
    Hemderson, NV
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: G62 power
    Iuse the G-62 in a 30% Extra and the 22X8 worked pretty good but I started using a number of different pitches and found a lot more torque with the 22X6 and 22X4. I'm also using XOAR props.
    Drinking and driving are illegal, why do bars have parking lots
    Daisy Air Guns, keeping kids off your lawn for 100 years
  6. #6
    soarrich's Avatar
    Join Date
    Feb 2002
    Middletown, NJ
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: G62 power
    I have a MT62 which is a clone of the G62. I'm using a Xoar 23x8 with good result. I think the rpms where 6800rpm, the Vess 22A didn't pull as well, other than right out of hover, and was much louder.
    Rich Border AMA 77727
    Sig Kadet Brotherhood #2
  7. #7
    RTK's Avatar
    Join Date
    Apr 2003
    Left Coast , CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: G62 power
    Dump the stock muffler, or any muffler that knocks 500 rpm off of open stack, let the 62 spin up, they are not happy at lower rpms or with restrictive exhausts.. Try for a static of 7000
    Yes, 500 rpm makes a big difference in performance on any plane.
    Attached Thumbnails Attached Thumbnails Click image for larger version.
  8. #8
    soarrich's Avatar
    Join Date
    Feb 2002
    Middletown, NJ
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: G62 power
    ORIGINAL: RTK
    What is PS?
  9. #9
    RTK's Avatar
    Join Date
    Apr 2003
    Left Coast , CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: G62 power
    Horse Power in their measure
  10. #10
    Join Date
    Jan 2006
    Kalona, IA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: G62 power
    A really good alternative in-cowl muffler, that is inexpensive and readily available...is the DL50 muffler. Last time I checked they are $35, and any of the DL engine distributors can mail you one. Buy yourself two 10-32 square nuts from the local hardware store, and you are set. The nuts will go into the exhaust flange on the cylinder, to accept the DL50 muffler bolts. This setup is INCREDIBLY lightweight, and a pretty easy breathing option if you must use an in cowl setup. Use red locktite on the muffler bolts/nuts, and permatex ultra copper (or equivalent) as a gasket. Only a very thin amount is needed at the mating surface between cylinder and muffler, but you can literally fill the void in the exhaust flange on the cylinder around the nuts for the mounting bolts, once attached, and it is completely leak free.
    Chad
  11. #11
    soarrich's Avatar
    Join Date
    Feb 2002
    Middletown, NJ
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: G62 power
    ORIGINAL: RTK
    I'm not breaking chops, but who are "they"? Is PS and HP 1 to 1. Pe's HPspreadsheetshows the 62 making about 5HPat 7000 rpm.
  12. #12
    RTK's Avatar
    Join Date
    Apr 2003
    Left Coast , CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: G62 power
    That comes directly from Zenoah.net All of their engines have HP/Torque curves
  13. #13
    frieshoo's Avatar
    Join Date
    Jan 2002
    Fries, VA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: G62 power
    I agree with Chad. The DL muffler works great on a G62.
    Like others have said: Always prop your G62 at 7000-7400 rpms.
    Dennis Anders AMA 625293
    The Unfrozen Caveman Sport Flyer
  14. #14
    Join Date
    Mar 2002
    Arvada, CO
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: G62 power
    ORIGINAL: jim52519
    Hi all,
    Jim
    Did you tune the needles properly? If you haven't tuned it yet, then thats the problem. The stock muffler will cost you 500RPM easily. That engine should swing a 22-10 over 7000RPM. All mine do and I have more than a handful of them with pitts mufflers.
    Lean the high speed needle to max RPM and then richen about 200RPM. Use a tach.
    Now throttle back to idle and tune the low speed needle leaner about 1/8 turn. Check transition. Will it transition without bogging or skipping? If yes then lean the low speed needle again and again until it won't transition cleanly. After each adjustment run to full throttle and back down slowly. When it won't transition, richen a little less than 1/8 turn.
    Now check high speed needle again. Lean to peak and then richen 200RPM. Use a tach.
    Airplanes have expiration dates. Its just not printed anywhere on them.
    Im not really an airplane pilot; but I did stay at a Holiday Inn Express last night.
  15. #15
    Join Date
    Apr 2002
    Silverdale, WA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: G62 power
    ORIGINAL: soarrich
    ORIGINAL: RTK
    I'm not breaking chops, but who are "they"? Is PS and HP 1 to 1. Pe's HP spreadsheet shows the 62 making about 5HP at 7000 rpm.
    "PS" stands for "pferdestarke" = "horse strength". One BHP = ~1.013 PS. Apparently British horses are slightly stronger than German horses...(actually it is just a metric conversion from British units)
    One BHP = 745.7 watts, one ps = 735.5 watts.
  16. #16
    Mein Duff's Avatar
    Join Date
    May 2009
    Santa Rosa, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: G62 power
    PS comes from German meaning:  "Pferde Staerke"  or transalated as "horse power".....one PS ( horse power) is required to pull 10 pounds as a rule of thumb when calculating engine needs in model aircraft.
    Don'  know why we didn't use an american acronysm for this......
    Fleet Brotherhood #5
    Half A Wing, Three Engines and A Prayer
  17. #17
    Skratchbilt's Avatar
    Join Date
    May 2009
    Springfield, MO
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: G62 power
    Would you happen to have a direct link to these DL50 exhausts? I too am using a G-62, and would like to avoid all the hangups others are having before firing it up. So fa, this thread has been very useful!
    Keep Your Head Up On a Swivel
  18. #18
    Jonas Bergstrφm's Avatar
    Join Date
    May 2004
    Kungsbacka, SWEDEN
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: G62 power
    Hi
    I have build a Stearman from Fliarand it was very heavy.
    I also used a ZG62 but i used a REAL silencer and I have over 6500 rpm with a Menz 22x10.
    Se the pics.
    It sounds lovely also, not like a moped.
    Look at www.toni-clark.com
    Good luck
    Jonas
ID:	1214203   Click image for larger version.
ID:	1214204   Click image for larger version.
ID:	1214205   Click image for larger version.
  19. #19
    Join Date
    Jan 2006
    Kalona, IA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: G62 power
    ORIGINAL: Skratchbilt
    Call Bob at DLUSA: http://www.dlusa.net/Parts.html
    Or Jody/Tom at: http://www.valleyviewrc.com/
    Chad
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
