SYSSA 30CC GAS MADE IN USA
#3251
RE: SYSSA 30CC GAS MADE IN USA
Will Todd ever manufacture an engine in the 45 to 50 cc range? I have a pristine NIB Byron Originals Ryan ST-A, and I don't think that a 30cc (anyone's 30cc) engine has enough guts to swing enough prop for that one. How bout it Todd?
Bill, Waco Brother #1
#3253
ORIGINAL: ghoffman
How about a 60cc twin?
#3254
NY
What is the AUW and wingspan of the ST-A?
The SAP on standard Pitts muffler produces about 18 lbs of thrust, which may be enough for a scale vintage racer. Speeds will likely be more scale-ish as well because the max thrust comes from using something like an 18x6 at 9K RPM.
#3255
NY
Is it the same size/weight as the PT-20? As you know, a guy from [link=http://www.rcuniverse.com/forum/m_8581419/mpage_1/key_/tm.htm]another thread[/link] successfully flew that model with the Saito 36cc gasser.
The SAP with standard Pitts muffler will produce probably (and I'm just totally guessing here) significantly more power than the Saito. Certainly not as cool-sounding as a 4-stroker, though.
#3256
The Byron Originals Ryan ST-A has a 90 inch wingspan. The all up weight should be in the mid 20 pound range. Problem with running a small displacement engine is the prop diameter. To be scale appearing, this one will need a prop in the 22-24 inch range. I don't believe that a 30cc engine is going to pass muster on that issue.
#3257
A smaller prop that fits the engine for flying is fine as the prop is hard to see in the air. As noted, a smaller prop with the correct pitch turning at higher rpms may give scale speeds. And yes, a scale diameter prop at a lower rpm could accomplish the same but with a larger engine.
Swap out the flying prop with a static display prop for show.
The Syssa may be a bit on the smaller end for a mid 20 lb plane though.
What does Byron recomend for power.
#3258
hi is anyone using this motor in a slipstream mx2 ?
when i order this engine which length of standoffs do i need ?
and what spinner adapter is everyone using ? tru turn ?
thank you.
thank you.
#3259
My Feedback: (36)
TN
Had my trusty Syssa break a keyway today flipped prop one time after choke and backfire then nothing I guess I will be calling Todd Monday anyone change a keyway on this engine? I have the engine on a 10lb 13 oz dry Sbach by slipstream.
#3260
Any one looking for one might check this out ..
http://www.rcuniverse.com/market/item.cfm?itemId=662107
I wish this add was there when I wanted one!! and it still looks tempting!
#3262
ORIGINAL: skylarkmk1
#3263
ORIGINAL: FLYING-HIGH2
thank you.
thank you.
Anyway, the distance from the front of the prop hub (rear of the propeller or spinner) to the back of the engine crankcase (front of standoffs) is shown as 3.919". You can use that length to compute the standoff length you need once you get the prop hub to firewall or engine box distance for the MX2. The distance from the front of the prop hub to the rear of the carb mounting screws is 5.825" to give you an idea of how long the engine is not counting the prop shaft.
#3264
ORIGINAL: Hog78
#3265
NY
ORIGINAL: Stickbuilder
Maybe something like a ZDZ 40 F3A (also rear induction, rear exhaust) to keep it all under the cowl.
#3268
My Feedback: (16)
ORIGINAL: Hog78
what is the new hub? thanks
[img]{akamaiimageforum}/upfiles/26087/Up47531.jpg[/img]
[img]{akamaiimageforum}/upfiles/26087/Af90295.jpg[/img]
#3269
My Feedback: (19)
ORIGINAL: AJsToyz
#3272
NY
Whoa-ho Bill,
Got yourself a new avitar I see.
I would agree that the Syssa is too small compared to the G-38 with Byro drive.
Whoa-ho Bill,
And is the Byro drive currently available?
#3273
ORIGINAL: Joystick TX
I hate it when that happens. My keyway broke early this year, had one of the ''soft'' keys. The hub is pressed on and it is recommended that it be sent back for service. Got the engine back in about 1-1/2 weeks. I have had over 70 flying hours since then with no key problems. You may want to let Todd know if you want the old or new style hub.
ORIGINAL: Hog78
I don't really buy into the soft key theory as much as the key is the weekest link. It's needed to protect the relatively small diameter prop shaft from twisting under an overload condition. I'm sure Todd is aware of the structural limitations and failure loads for each of his engines components and designed accordingly. It's a great insurance plan if only it had a field level repair. Just my $.02
I don't see any difference with the new hub when it comes to how it's mounted to the shaft. Is there? I still havn't received my order from July so I cant look at it and see. assuming my new engine comes with the new hub??
