DLE30!
Old 07-18-2010, 11:06 AM
  #3451
Switch_639
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: NEW DLE30!
what will help lower the idle closer to say under 2000 for now? once the engine is properly broken in?
Switch_639 is offline
Old 07-18-2010, 11:18 AM
  #3452
Super08
Super08's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Yes and if it is too rich it is hard to get it down to a low idle.
Super08 is online now
Old 07-18-2010, 11:48 AM
  #3453
Switch_639
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
how many flights approx does it take for the engine to run in properly? or how many hours of runtime?
Old 07-18-2010, 12:02 PM
  #3454
captinjohn
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Do many heat cycles
captinjohn is offline
Old 07-18-2010, 12:04 PM
  #3455
captinjohn
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: captinjohn
Do many heat cycles
Got to make fast short replies...my connection keeps kicking out! Capt,n
Old 07-18-2010, 12:45 PM
  #3456
Switch_639
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
heat cycles? and how many is many...
Old 07-18-2010, 01:24 PM
  #3457
captinjohn
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: Switch_639
10-15 per day...for 7 days after shutting down...park piston at Top dead center. Capt,n
Old 07-19-2010, 01:51 AM
  #3458
HornetFitter
HornetFitter's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Finally got my DLE 30 sorted out. It would start with a new plug, but would only run (sputtering) for about 15 seconds, then nothing. Testing for spark outside the combustion chamber revealed a strong arc, but it would not fire reliably when installed in the combustion chamber. After going through 3 NGK plugs, I figured...This thing just SUX! So, I got a return authorisation number from HK and ordered one from another supplier. I initially installed the carb and reed block from the new engine, but the result was negligable, So, I switched out the ignition pack and it fired right up (untill my neighbour came out and complained aout the noise. (it was 10 pm....It is OK to make as much noise as they want when his buddies are over drinking on a Friday night though). So I shut it down and called it a successful night.
HornetFitter is offline
Old 07-19-2010, 08:43 AM
  #3459
Super08
Super08's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Good to hear. I was down in you neck of the woods for the first two weeks of July. I went out to the field a couple of times, but no one was around. The dogs had fun running around anyways. I see the land is up for sale. That may cause you problems down the road if someone wants to use the land for crops. I spent some time sitting up the road from AETE watching the boys do circuits. What can I say... I miss home.
Old 07-19-2010, 10:45 AM
  #3460
HornetFitter
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: Super08
You should have fired off a PM to me. I would have been happy to come out with my 1/4 Cub on floats (Not really; just sick of all the rain)...Yes, the land went on the block this spring. It will most likely be used for residential development. All the builders are buying up land just outside city corporate limits, to avoid the high taxes in town. The "bird watching area" gets some heavy use during Maple Flag, but there is usually something happening most days.
Take care!
D
Old 07-19-2010, 10:11 PM
  #3461
bigtim
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
finally got the 30 mounted in my ESM FW190, after some tribulation I went ahead and got these stand offs from china, to extend the engine out enough to fit the cowl opening location,a perfect match for my pits style muffler I got from Jody as well, nice looking offering BTW, the 30 fits cleanly in the cowl of the ESM FW with just the plug sticking out the bottom of the cowl.
my plan is to mount the ign. to the firewall and the battery directly underneath to keep my weight forward, any reason i couldn't use a metal strap to secure the ign or would a plastic zip tie be a better option.
here's a shot of my repainted FW 190A the stock paint is not really all that close to scale
ID:	1470540   Click image for larger version
ID:	1470541   Click image for larger version
ID:	1470542   Click image for larger version
bigtim is offline
Old 07-20-2010, 07:21 PM
  #3462
captinjohn
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: bigtim
If you can keep ignition & battery away from the exhaust. Looks like you could place 2 balsa sticks 90 degree across the top standoffs. Maybe use stick foam strips lengthwise of battery and use tie raps or good rubber bands to hold to top stand-offs. You need air to circulate around the ignition & battery...but still keep vibration out. Just a Idea!
Capt,n
Old 07-22-2010, 12:55 PM
  #3463
jvg69
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
YES, LIKE RUNNING AN ENGINE AT W.O.T. THAT HAS NOT BEEN BROKEN IN YET. IF YOU DIDNT KNOW WHAT YOU WERE DOING WHY NOT ASK SOMEONE WHO IS EXPERIENCED. NOW YOU ARE GOING TO SAY ITS A WARRANTY ISSUE WHEN ITS NOT,ITS ABUSE.
jvg69 is offline
Old 07-22-2010, 08:15 PM
  #3464
maddog 71
maddog 71's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Just got my first DLE 30 whats the little clear plastic clips for looks like they fit the cooling fins for something?
maddog 71 is offline
Old 07-22-2010, 08:27 PM
  #3465
jedijody
jedijody's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
They are meant to beused forholding the radio plugs for the ignition together.
jedijody is offline
Old 07-22-2010, 08:29 PM
  #3466
maddog 71
maddog 71's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
OK thanks!
Old 07-22-2010, 08:41 PM
  #3467
captinjohn
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Well I had to take time to clean the shop....took about 2 hours!!!! Anyway I found a special part I made on the lathe....nice side benifit. Also got most of the things I will need to finish one plane. It looks like it will not be in time for our anual fly in.Iguess it may rain anyway. The Beat goes on................................................ ........ Capt,n
Old 07-22-2010, 09:12 PM
  #3468
Tired Old Man
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: jvg69
I'm not too clear on what you're referring to. Please enlighten me.
If my experience level troubles you, I'm definately open to your expert tutelage[sm=teeth_smile.gif] I suppose shortly after you are taught that using all caps is viewed as yelling at someone in internet protocol you could step up and show me all that I need to know about the proper handling and running of two stroke gas engines. Shall we start with carbureted, injected, or heavy fuel versions? What about injected heavy fuel? Singles, opposed twins and quads, inlines, or radials? By brand perhaps? I'm all ears and desparate to glean as much useful and pertinent information from you as I can
I should quote P.T. Barnum here but I'll restrain myself. Your reply would be both appreciated and entertaining.
Tired Old Man is offline
Old 07-22-2010, 10:25 PM
  #3469
Super08
Super08's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
This is going to be good...lol. [sm=lol.gif]
Old 07-22-2010, 11:16 PM
  #3470
captinjohn
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Yup....funny....read all 6 posts......from....
Old 07-22-2010, 11:40 PM
  #3471
Tired Old Man
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Read two of them. A TBM employee it appears. That other UAV company, lol. Still clueless with the reference and applicability of his post.
I would very much like to learn why a new engine cannot be run at wot. There is clearly much I have to learn about the correct operating methods concerning new small gas two strokes.
Old 07-23-2010, 12:42 AM
  #3472
jetmanr18
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi Jody!
I am new to the Giant Scene and need to ask you two questions:
1) Are there any "metric screw" torque tables in inch pounds anywhere in the forum? (I have a "TORX" screwdriver-type torquewrench).
2) Do you use or recommend the JIS screwdrivers instead of the American Phillips? (I'm having great luck with mine on Japanese engines!).
Brian Gray- jetmanr18
bgray191@mchsi.com
P.S. I'd PM you with this request, but I haven't yet figured out how...
jetmanr18 is offline
Old 07-23-2010, 01:41 AM
  #3473
Antique
Antique's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hey pat, let me in on it too, we just ran a newly assembled GT80 race twin at about 10,500 on the test stand....Had about 5 minutes warm up time on it...
Antique is offline
Old 07-23-2010, 02:14 AM
  #3474
jedijody
jedijody's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: jetmanr18
Hi Jody!
bgray191@mchsi.com
Well you must have heard about Google, it's this coolthing where anyone can type in any question and it will give you just as many different answers asa gas engineforum.
http://www.imperialinc.com/pdf/A_Fas...rqueCharts.pdf
For inch lbs., multiply the foot lbs. by 12.
JISfasteners suck, it's the Japanese just being different to be a pain in the butt. Plus, I doubt you will find the JIS screw drivers very handy on a Chinese engine held together with socket headed cap screws. They may come in handy though if your video camera needs a carb rebuild before filming your DLE30 maiden.
jedijody is offline
Old 07-23-2010, 07:27 AM
  #3475
darkith
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: Tired Old Man
His post has a reference link to this old ToM post: http://www.rcuniverse.com/forum/fb.asp?m=9585744
Which is in reference to this post: http://www.rcuniverse.com/forum/fb.asp?m=9583821
Seems either like somebody with an axe to grind, or somebody doing searches and finding an post they just have to disagree with in ALL CAPS (and either not caring or not noticing that it's an old post).
Ahhhh, what fun.
D.
darkith is online now
Display Modes
