DLE30!
#4176
RE: NEW DLE30!
hi all,
lovely engine, I have the rear carby version, 30cc, I put about 3/4 litre through it on the ground, I started off with a Master Airscrew 18x8 for the first couple of runs, then changed to a JXF 19 x 8, much better prop, IMO, about 7k top rpm, idle about 1700, so far I have had 3 flights with the engine, it is in an ESM P-47, the engine is running smooth, heaps of power, I am very happy with it.
I mounted my ignition unit on the stand offs, with velcro, a thin 3 ply bracket cable tied to the stand offs, then some thick velcro, with another cable tie as a safety around the unit. I use a 4 cell 2000 mah battery pack,
cheers, Oldtimer.
cheers, Oldtimer.
#4177
RE: NEW DLE30!
ORIGINAL: summerwind
i've read it twice and still haven't seen any mention of where or how to mount the ignition module.........where should i be looking?
thx
mike
ORIGINAL: airborne2.4
Have a look at this:
http://www.rcuniverse.com/forum/m_86...tm.htm#8673009
ORIGINAL: Richard39
I have read a lot of the many post here on the DLE 30.... but still have questions... my questions are for I guess all gas engines... where do I mount the electronic Ignition and how? I have heard inside and I have heard outside of the airplane at the firewall.... do you use metal tape to prevent rf interference at the firewall?
Thanks...Richard
Thanks...Richard
thx
mike
#4179
ID
RE: NEW DLE30!
Hi If I have a engine box as a rule this is the way I do my Ign box, I use zip ties and not velcro for better holding IMO. I also don't use any thing under the box but make sure that it tight again the side of the engine box for no movment due to any vibrations.
The fig shown is a 55 but the same allpies to my 30 set up, with one exception the 55 has bolts going into the standoffs from both ends, where as the 30 standoffs are short and has pass thru bolts with blind nuts. (Caution) make sure you have good harden blind nuts if you choose to go that way. This is but just one set up there are many others that will work good also, just depend's on the particular plane your mounting the engine on as to what setup is needed.
As far as a 10x24 versis a 5 MM I would rather go with a 10x32 for the finner thread and ease of getting blind nuts and so forth , never try to mix the two up although they may go together they won't hold and a stripped thread is the end result and could be a very major safety factor.
#4180
My Feedback: (14)
AL
RE: NEW DLE30!
Cyberwolf.... thanks for the great reply and picture... very helpful... I will be connecting to the firewall as there is no box.. only the standoffs...
I do have the 10 x 32 bolts from the firewall to the standoff... using lock washers on a 3/4 inch fender washer... also using the fender washer on the front of the firewall where the standoff connects... I can not find a manual or any info on the proper size bolts for the provided standoffs... seems odd they send 4 bolts with the standoffs when 8 bolts are required....
thanks again... Richard
#4181
DC
RE: NEW DLE30!
10-32 bolts are .190 diameter, will screw into 5mm hole but will be loose and not recommended'
5mm bolts are about .196 and should be used with the supplied standoffs unless the holes in the standoffs are drilled all the way through, then it makes no difference if you use matching nuts...
GOOD 5mm bolts will not screw into GOOD 10-32 nuts without some force.....
#4182
My Feedback: (14)
AL
RE: NEW DLE30!
Thanks Antique... I guess I should remove the 10x32... but I wish that I would have info with the new dle 30 that states 5mm... Is this printed somewhere or should we just assume that made in China translates into 5MM... a manual would be nice... something in writing....
I tried the bolts they furnished and the 10x32 and could not tell any difference in hand screwing them in and out.... just concerns me that either one could be the wrong or right one for safety....
#4186
RE: NEW DLE30!
ORIGINAL: Richard39
P.S I won,t buy anything without good directions from now on!!!
#4187
RE: NEW DLE30!
The 5mm mounting bolts that come with this engine screw very nicely into both ends of the standoffs that came with my dle30. Also the standoffs have holes all the way through them, and you can slide an 8-32 all the way through them (without engaging the threads at all). So that gives you another option for mounting.
Ed
Ed
#4188
RE: NEW DLE30!
why doesn't the plug cap on these engines have a silicone boot to cover all the exposed metal?
since i was a kid i remember everything i touched that was gas/ignition related had rubber spark plug caps.
#4190
RE: NEW DLE30!
i understrand that, but still read reports of radio interference, so i thought that the exposed steel cap might be contributing to this.
i'm using Futaba 2.4 system so i doubt i will have any issues.
#4194
RE: NEW DLE30!
ORIGINAL: w8ye
Just think what you already know about model airplanes.
Soon you will be an expert on gas engines
#4197
RE: NEW DLE30!
#4198
RE: NEW DLE30!
Jody,
Maidenmy 73"MX2 with the DLE 30 last weekend and boy, did it handle theMX2 like a rag doll. Totally pleased with this little engine and happy I decided to try the DLE line as a second gas engine. Inoticed however thatthe Pitts style exhaustIbought from VVRc changed colour from the flat black to a BEAUTIFULbronze. Has anyone else had this experience, or is this an indication that the engine is running too hot and I need to cut out the cowl some more?
Looking forward to your collective wisdom.
Dale
Dale
#4199
RE: NEW DLE30!
That is normal, the balck is just paint and it turns to the bronze color from the heat. From my experience the down tubes remain black, just the part of the muffler where its connected to the cylinder and a portion of the can behind the cylinder turn the bronze color.
#4200
RE: NEW DLE30!
What's the difference between the side-carb and rear-carb (v2?) engines? Is the rear-carb one more powerful?
If the carb sticks into the fuse, wont it make a big and smelly mess in there? (Storing the plane indoors where people dont like gas smell)
