If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Page 204 of 211 FirstFirst ... 104154194202203204205206 ... LastLast
Results 5,076 to 5,100 of 5270
Thread: DLE30!
  1. #5076
    Join Date
    Apr 2007
    Lady Lake, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: NEW DLE30!
    I took the 190 to the field and test flew the 17-10 Biela three blade prop. I put 1/8 turn rich on the high end because this prop is going to put more load on the engine. Turning up about 6,000 rpm at the field. It felt like enough thrust. A club member suggested a high speed taxi to see how it felt. So I did, but waited too long to throttle back and plane took off. Seemed to be enough power, then engine started sagging. I throttled back and it kept running so I put the gear down and didn't move the throttle until final. Landed ok. I put another 1/8 turn rich on the high end and 1/8 turn rich on the low needle. Ran ok until I pulled the nose up, sagged again. Landed ok. now 1/4 turn rich. Took off, too rich. 1/8 turn lean. Took off ok. Ran ok. aceleration after take off is slower but gets up to good speed and ran ok in level flight, but when I pulled up to do a loop the engine slowed and started four cycling. Not much verticle with this prop. Also the engine seems more sensitive to needle adjustments running this much prop.
    Just confirmed what I thought. This is too much prop for the engine. Any prop shorter than 17" wouldn't look right on this plane with the big cowling. I think a 17-8 three blade is the way to go. I agree a 6 pitch wouldn't be enough. Now I need to find a 17-8 three blade prop.
  2. #5077
    Join Date
    Aug 2004
    Spartanburg, SC
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: NEW DLE30!
    Try Troybuilt Models.
    A three blade prop looks good on this model or any warbird for that matter, but a three blade is not as efficient as a two blade.
    If you have to bend over more than once, it wasn't a good landing....
  3. #5078
    Join Date
    Apr 2009
    Whitestone, NY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: NEW DLE30!
    Agree with Iffy - everything I've read says the less prop blades the more efficient the prop. Though, if you've got an over-powered engine you can afford a little less prop efficiency, especially if you need the ground-clearance. Pretty sure why this setup works on the real-life warbirds.
    I picked up an H9 P51 150 (80") with an MVVS 35 here on RCU. I'm putting a Xoar 2-blade 20x8 in it (recommended for this engine). Once I reinforce the retract area of the wings I'll fly it and let you know.
  4. #5079
    Join Date
    Aug 2004
    Spartanburg, SC
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: NEW DLE30!
    Hey Don...Haven't heard from you in quite a while, hope all is well.
    Congrats on getting the P-51, they are a lot of fun and also a bit tricky...so be carefull...
  5. #5080
    Join Date
    Apr 2009
    Whitestone, NY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: NEW DLE30!
    Iffy - thanks. On the DLE 30 I'm still impressed by this engine's power. I have mine on a CG Sukhoi (73") swinging an APC 18x10 and it's got great speed and unlimited vertical. Really impressive. Once I get some 3D practice on foamies I'll try a Xoar 20x8 on the Sukhoi and try some 3D with that.
    With the P51 - yeah - I had one flight so far. The plane \ engine came with no muffler - only a header - so was loud as hell - 97db. They let me fly it anyway, but I was nervous and came in too slow. The plane dropped the last 3 feet and the gear grabbed in the grass runway, ripping them off, damaging the wings. But it's amazing how LITTLE reinforcement H9 designed into the retract area. So, reinforcing the wing is my next project. Am hoping the replacement stock retracts are strong enough on smooth landings (good retracts cost a fortune...)
  6. #5081
    Join Date
    Aug 2004
    Spartanburg, SC
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: NEW DLE30!
    Yeah, I have the DLE 30 on a Goldwing Yak, swinging a Xoar 18-10 also...like you say, unlimited vertical, more power that you can believe from this engine.
    On the P-51, you are right, they seem to think that toothpicks will be enough for the landing gear on these planes...NOT for a grass runway as I have found out...[X(]...unless you re-inforce it well.
  7. #5082
    drube's Avatar
    Join Date
    Sep 2009
    North Port, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: NEW DLE30!
    Thanks guys.
    Alan
    CORSAIR Brotherhood # 90
  8. #5083
    Moderator w8ye's Avatar
    Join Date
    Dec 2001
    Shelby, OH
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: NEW DLE30!
    WHEELPANTS and RETRACTS do not like GRASS!
    Attended the CutFinger Institute of DirtNap University for years but never did graduate....
    Recipient, Mangledhand award August 2008
    Club Saito Member #7
    Original AMA #31261
  9. #5084
    Join Date
    May 2008
    Winnipeg, MB, CANADA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: NEW DLE30!
    Most efficient prop is a one blade.
  10. #5085
    Join Date
    Oct 2006
    salem, OR
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: NEW DLE30!
    Flew my Sbach with the DLE-30 in it yesterday and today. Engine is running great at top speed, idles nice, and transitions smooth. My only issue is that it still spits black residue out on the bottom of the plane, via the JTec pitts style muffler. I've leaned the high needle in small increments and the residue is still there. I opened and closed the low needle in small increments and it did not seem to affect running, nor the black residue. I looked at my log and I have about 40 flights on it, btwn 5 and 10 minutes each, so if averaged, that is 7.5x40=300minutes=5hours. I started with Pennzoil (hard to find in my town) and now use Walmart's SuperTech. Still mixing at 32:1. Should I be concerned at all that the residue still occurs. Does it ever stop? Thanks. Jon
    Carl Goldberg Ultimate 10-300 Brotherhood #01
    Club Saito #707
    P-47 Thunderbolt Brotherhood #97
  11. #5086
    Join Date
    Apr 2009
    Whitestone, NY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: NEW DLE30!
    w8ye - are you saying that you should never land on grass with retracts? Even if the wing is enforced? (I DO plan on doing my initial flights at the 1,000 ft runway at Floyd Bennett Field in Brooklyn, but WOULD like to fly this bird at my other, grass-covered fields.
  12. #5087
    Join Date
    Dec 2001
    Shelby, OH
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: NEW DLE30!
    I've been around model airplanes for more years than I care to admit. Grass and it's irregularities has always been problematic for wheel pants and retracts.
    They are just nothing but trouble on grass. Seen it time and again.
    Original AMA #31261
  13. #5088
    Join Date
    Apr 2009
    Whitestone, NY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: NEW DLE30!
    In the situations where I do want to keep the wheelpants on (usually scale planes, bipes), I upgrade to larger wheels and dremel-out the pants opening. That seems to give me the 1/4" in additional elevations that the pants need to clear the grass.
  14. #5089
    Join Date
    Aug 2004
    Spartanburg, SC
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: NEW DLE30!
    ORIGINAL: maukaonyx
    I have weaned my DLE 30 off of 32:1 and gone to 50:1...not as much black residue now, but as long as you see it, you know that it is receiving enough lubrication. I use Bel Ray MC-1 all synthetic. Before I did that, I was practically having to wash my plane down with gas to get the residue off. [>:]
  15. #5090
    Join Date
    Jul 2011
    Reedsburg, WI
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: NEW DLE30!
    It's more likely a matter of the oil you use.
    Using low quality oil and or leaner mixtures will shorten the life time of the engine.
    There are lots of threads here about oil, you can order it online or go to an auto store, they might have
    what you are looking for.
    Some black spots are normal, the needles should be on the rich side.
  16. #5091
    Join Date
    Jul 2004
    Arkansas city, KS
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: NEW DLE30!
    Standard rule of thumb when going to a 3 blade prop from a 2 blade is to drop an inch and stay with the same pitch. This will yield approximeatly the same rpm. A 19x8 "2 blade" xoar will turn 7200~7500 rpm. A good spot to be with the 30. If you want to go to a 3 blade. Try a 18x8
    http://www.valleyviewrc.com/estore/x...ller-18x8.html
  17. #5092
    Join Date
    Apr 2007
    Lady Lake, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: NEW DLE30!
    Johnfly, Thanks for the input. I checked out the Xoar three blade props at Valley View RC. They have a 17-8 and 18-8 three blade Xoar props. It looks like they will drill the 18-8 for the DLE 30 so it seems they believe it is a good prop for the DLE 30. You are correct, I'll looking for about 7,200 to 7,500 rpm static. The Master Airscrew 18-8 two blade turns up 8,450 rpm and the Biela 17-10 three blade 6,000 rpm. I'm leaning towards the 18-8. They are not cheap so I don't want to get the wrong one. I wish there was more data out there re props and max static rpm with the DLE 30.
  18. #5093
    Join Date
    Dec 2006
    STEWARTSTOWN, PA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: NEW DLE30!
    I've got a DLE-30 I want to get rid of but it needs a new ignition module. I'm converting to electric. Is the DLE-30 w/o the ignition worth much of anything?
  19. #5094
    cmptrguy's Avatar
    Join Date
    Apr 2008
    Hayden, ID
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: NEW DLE30!
    if it is in running condition I will give you a $100.00 for it.
    Cmptrguy
  20. #5095
    Join Date
    Apr 2005
    Enumclaw, WA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: NEW DLE30!
    I will give you $110.
  21. #5096
    Join Date
    Dec 2006
    STEWARTSTOWN, PA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: NEW DLE30!
    I'll have to think on it. It's cheap enough that I'm tempted to keep it just in case the electric conversion doesn't pan out.
  22. #5097
    Join Date
    Apr 2005
    Enumclaw, WA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: NEW DLE30!
    I hear you there. You can find a 30 complete for $175 so by the time you get an ignition......
    Good luck and fly safe.
  23. #5098
    Join Date
    Apr 2009
    Whitestone, NY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: NEW DLE30!
    SBach - those HobbyKing ignitions that are supposed to work fine are only $25. I have two - not tested them yet.
  24. #5099
    Join Date
    Apr 2005
    Enumclaw, WA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: NEW DLE30!
    As long as they are RCEXL and for the DLE30, otherwise you are gambling.
  25. #5100
    Join Date
    Apr 2007
    Lady Lake, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: NEW DLE30!
    Johnfly, I got the three blade 18-8 from Valley View. It was not cheap. It only turned about 6,500 rpm. Ran ok on the ground with good idle and transition, but in the air the engine started sagging, I guess the three blade put more load on it and it started leaning out too much. Then on landing I hit a gopher hole, broke a gear mount and broke the expensive prop. I've now replaced it with a 18-10 two blade and repaired the gear mount and wing. I got in there and found out it didn't have any glue in most of the joints. Well, that is what you get with an ARF sometimes. If I try another three blade it will probably be a 17-8, either Xoar or Zinger. Not sure yet.
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
