Gas/oil mixture for gas engines
For my gas engines I use Klotz oil at a 32:1 ratio. What would be the pro or con on mixing at 40:1 and adding about 2 oz of castor oil? Can castor mix ok with gas/Klotz mixture?
Richard
Richard
RE: Gas/oil mixture for gas engines
ORIGINAL: RHarding
Richard
Richard
CA
Looks like they've already done it for you. http://klotzlube.com/proddetail.asp?...%5FQuart&cat=4
ORIGINAL: Tired Old Man
If you like a varnished piston and cylinder in a gas engine then Klotz and castor are something you could use to achieve your goals relatively quickly.
I see a lot of posts about gas/oil mixtures. Most use Klotz KL 100 or KL 200. I haven't seen any with Klotz RC Modelube. Why is that? Did I just miss those posts? It's made for gas.
In re: Roral Purple. Which of their oils do you use? The auto store here where I get my auto oil sells it, but I don't know anything about it.
Richard
Richard
My Feedback: (19)
ORIGINAL: RHarding
Richard
Richard
Truckracer,
Sorry you had an unhappy experience with Klotz. I have been using Klotz in glow engines since my U/C speed days in the late 60's and then off and on in my glow R/C engines since then. I have used it in my gas R/C engines, weedeaters, blowers, and chain saw off and on for years. I have nothing but good things to say about Klotz. My original question was about mixing a small amount of castor oil with the Klotz/gas mix. Don't know why some people prefer to stir the pot and not stay with the theme of the forum. Once again I am so sorry you did not have a good experience with the Klotz oil. Have you considered the possibility that you mixed it incorrectly?
My Feedback: (87)
Not sure why one would want to add castor oil in a gas 2 stroke engine. If this were a 2 stroke glow engine, sure. Klotz remains a major player in glow fuel lubrication. With and without castor. Not so in 2 stroke gasoline. At least not today.
There have been significant advances in oil available for gas 2 stroke engines since the 60's and 70's, absolutely no offense intended. Most are far better options than Klotz with or without castor. Redline, Belray, Stihl, Royal Purple, and Pennzoil Aircooled are all good options today.
My Feedback: (19)
ORIGINAL: RHarding
Truckracer,
Truckracer,
As for my glo experiences with Klotz or Klotz with castor added or premixed, I simply found better alternatives that didn't present the problems that I had with Klotz. Not saying Klotz isn't a good product at all just that Klotz didn't work out as well as other oils in my applications.
Captn.
My comments about castor in oil were directed towards gas engines. Gas engines run much hotter than glow engines, where castor is normally used. As heat increases castor turns to a varnish. Any amount of castor in a gas engine will become ugly over time. The amount added determines the time. The stuff makes a nasty glaze on cylinder walls and pistons, frequenty defeating the ring seal. Whether the oil is synthetic or mineral based doesn't matter if it's used in a gas engine. The end result by adding castor is the same. Just visualize a lighter shade of brown that you see cooked onto the outside of glow engines if you want to know what it looks like. Adding a lot of castor soon converts the inside appearance of a gas engine to closely resemble the outside of an uncared for glow engine with a lot of time on it.
As RC Addiction noted, there are too many far superior oils available off the shelf for gas engines to add castor to a gas fuel mix. BTW, I won't use Klotz either, but people make their own choices for their own reasons.
CA
Better quit using RedLine oil then cause it's a Castor oil 2 cycle mix. http://www.redlineoil.com/products_m...p?categoryID=3
My Feedback: (19)
ORIGINAL: altavillan
Now, that's the answers I was hoping for. Thanks to everyone. It's good to hear straight forward answers or comments from several people. We can learn, no matter how old we are or how long we have been in this wonderful hobby. I like that small amount of castor in my glow engines. It will save an engine if one leans the engine a little toooooo much. Tired Old Man, you brought something up that I had totally forgotten. Gas engines do run hot. I thank all of you for your comments. Truckracer, if I offended you with my post yesterday, I appologize.
Have a great day,
Richard
Have a great day,
Richard
My Feedback: (87)
ORIGINAL: RHarding
Richard
Richard
It's motor cycle racing oil. Cleaned out the black from Amsol in less than a gallon and the motor is clean as a whistle now.
MB, CANADA
Just use whatever 2stroke oil for air cooled engines thats available. I happen to use castrol grand prix right now, but if the store doesnt have it, I will use something else.
The only thing thats critical is using the correct oil ratio.
As previously stated, I dont think castor oil would be a good idea. Im sure that in small amounts, it probably would take a long time to affect anything. I always liked the smell of burning castor oil though. I guess the carbon/varnish could always be blown out of the engine by spraying a light mist of water in the carb with the engine at mid throttle. An old mechanic taught me that trick. It really blasts all the crap out of the engine.
MB, CANADA
actually it does. Anywhere the flame from combustion contacts, it will clean. The water boils causing steam. The steam will follow the flame front, and will be like using a steam cleaner on the combustion chamber, the cylinder walls and the top of the piston and part of the ring grooves. You dont have to worry about the piston skirt, cause it would take gobs and gobs of varnish and sludge to affect anything. The trick with the water, is to do it a number of times, to ensure a good cleaning. Doing it once or twice wont do a very good job.
ORIGINAL: captinjohn
Your reply is kinda a general statement. There are various blends of Klotz oil. Each can has a different part# One blend is pure synthetic. If you add castor to a any type oil with caster all ready in it...you could end up with varnish. Also if you use the right after run oils...it will loosen up the hard carbon ,ect ant most will blow right out the exhaust on start-up. I have done this since late 1970 and know it works. Capt,n
Capt'n,
Thanks for the clarification. I'd like tro add a little input about the after run oils. The engines I see generally have more hours on them that any model engine might hope to attain. Those that have been run using a good synthetic at 50-1 or denser ratios have little carbon in them at the time they are removed from use. A caveat is they don't run excessively rich like so many modelers like to run theirs. A clean burn at a well balanced air to fuel ratio makes a lot of difference in carbon accumulation and self cleaning. Most all the better synthetics do a pretty fair job of self cleaning when mixed appropriately. The minerals require a lot more oil in the mix to self clean as well.
My opinion is modelers (myself included) frequently become overly concerned about the oil used instead of the ratio used. Just as important is taking the time to correctly tune the engine for the prop and airframe it's used on. Far too many people pull an engine out of the box and go fly without ever considering carb tuning, which is a necessity during the running of the first tank of gas. Then there's the group that want to run "a little rich" ,or 100-200 degrees rich of peak. Toss in those that fail to consider cylinder cooling and you have a whole lot of engines where the brand of oil used will have little difference in the final outcome. Modelers just don't run their engines hard enough for the "best" oils to make much of a difference over a "good" oil. Our fun flying uses engines providing .75 to 1, up to 2 to 1 power to weight ratios so they don't work very hard.
My Feedback: (19)
Capt'n
I always respect your opinions on these forums because you're such a gentleman in the way you post here. Respectfully though, I can't see the value of using after run oils and choking the engine after the last run of the day. Here's my reasons. First, unlike glo engines, I have never seen corrosion or rust inside our gasers ... so after run oils seem pointless. I wouldn't want to choke the engine to kill it because all my fleet of gassers are stored in my house .... so the smell from the excess gas would be noticed and would be objectionable. As it is, they hardly have an odor at all. Of course the cat pan nearby might help mask any odor anyway ... And as for carbon buildup, oil selection (and ratios as TOM pointed out) seems to pretty much eliminate that as a problem. I've pretty much migrated back to cheap (or should that be reasonable priced) oils that are available close to home and mixed at generous ratios. Pennzoil at the present time seems to fill the bill quite nicely.
