Prop for DL-111
My Feedback: (39)
FL
Prop for DL-111
Looking for someone with experience with the DL-111. Instruction sheet calls for 27 X 10 , 26 X 12, or 28 X 10 prop to be used. If you have run this engine and have done any testing with different props, please share your results, to include which prop, and where did you purchase it.
Thanks in advance.
Thanks in advance.
RE: Prop for DL-111
I was running a 27-10 laminated BME on mine and felt it was under propped. It worked great on the DL 100 but wasn't quite enough for the 111. Depending on your plane I would buy one each of the PAU props. 27-3dB and a 28-3dB. One of those two will make you very happy.
