Help reading plugs
Old 08-30-2009, 03:48 PM
  #51
RTK
RTK's Avatar
Default RE: Help reading plugs
ORIGINAL: mbinkley
I just got a chance to test the trust on my BME115 with a 28X10 PT Models prop and MTW75H cans. The out side temp was 86 and the humity was 90% and the elevtion was 764 feet. The rpm was 6684 this was using a TNC tack.
And a digital fish scale got 49.4 pounds of thrust.
ORIGINAL: crazyflyboy30
What thrust can you out of that BME ?
If you try a different prop I think you can break 50lbs
Old 08-31-2009, 10:24 AM
  #52
mbinkley
RTK what prop would you try.
Do you think I should be looking for more RPMs.
Old 08-31-2009, 11:23 AM
  #53
raflyer
My Feedback: (14)
Considering that your D.A. was probably 3000ft ++ i would say your numbers are close. D.A.= Density Altitude If you knew the baro reading we would know for sure but i bet i'm close. Many years racing has taught me the affect of DA on performance
Old 09-01-2009, 08:20 PM
  #54
mbinkley
raflyer
Thanks .
I will look back in the weather charts and see what they say the Baro was that day and time. And post it
