DLE 55 or MT 57
Old 08-24-2009, 10:42 AM
Eganwp
Eganwp's Avatar
Default DLE 55 or MT 57
Hey guys,
I'm going to be building a 50cc bird here shortly. Wondering your opinions on both these engines. Will go in ~14-15lb 87" plane, and I fly at 3500ft ASL. Looking for overall engine quality, superior running performance, HP, tuning, longevity, reliable ignition, etc. Which engine would you buy, the new DLE 55 or the MT 57?
DLE 55 engine specs
1、Performance
5.5HP/7500rpm
Idle Speed: 1350 rpm/min.)
14.2Kg Pulling Force / 100 meters Altitude
12.5Kg Pulling Force / 1800 meters Altitude
The specification of the aircraft propeller: 22×8; 22×10;23×8;23×10;
the type of the sparking plug :NGK CM6
2、Parameter
Exhaust Amount ) :55.6cm3
diameter × stroke ) : 45mm×35mm
Ratio of compression):7.6:1
Ratio of lubricating capacity): 30:1
Weight: Main engine - 1310g Exhaust pipe - 100g Ignition apparatus - 120g
MT 57 engine specs
Cylinder Capacity 57cc
Power Rating 5.6 HP
Bore Diameter 44 mm
Stroke 38 mm
Weight( engine only with plug) 1495g
Speed Range 8700 RPM
Crankshaft 2 Ball bearings
Connecting Rod Needle bearings on both ends
Ignition 4.8 V
Propeller - 2 Bladed 21 x 10
24 x 10
Eganwp
Old 08-24-2009, 10:51 AM
Super08
Super08's Avatar
Default RE: DLE 55 or MT 57
The DLE55 is very user friendly and easy to install and set up. It is also the smoother running of the two. The 57 has a hair more power, but also has a more vibration. The 57's carb arms are not as user friendly for attaching pushrods and takes a little more work. It also has more torque for swinging a larger prop due to its long stroke design. If you are new to gasseres I would recommend the DLE.
If you chose the MT57 be sure you get the new version with the updated crankcase. The early ones had a few problems which look to be all worked out now.
Old 08-24-2009, 11:41 AM
Eganwp
Eganwp's Avatar
Thanks for the quick reply. I was leaning towards the DLE 55 also, however I can get a used MT-57 locally for $300. He said he had issues with its transition from low to high and had replaced seals and ring. 6400rpm on a 23x8 XOAR.
Anyone else have an opinion or experience on these 2 engines?
Old 08-24-2009, 01:30 PM
JOHNS3D
JOHNS3D's Avatar
Egan you can get a DLE for almost the same price...maybe a few bucks more....so lets try it.
Old 08-24-2009, 01:53 PM
JoeAirPort
My Feedback: (41)
JoeAirPort's Avatar
DLE-55. I have one and love it. Light, powerful, reliable, easy to start.
Old 08-24-2009, 09:41 PM
C185Pilot
My Feedback: (25)
I have the MT-57 and it has run perfectly. It is probably the strongest engine that I own in the 50 cc category. I also have a DL-50 and am happy with it...I don't think that you can go wrong with either...forced to choose I would take the MT-57.
Mike
Old 08-25-2009, 01:19 AM
Jr25
My Feedback: (7)
Ditto what joe posted. I have a DLE 55 on a 18lb Yak and absolutely LOVE it! Tons of vertical pull (Xoar 22x8), starts cold on about 5 flips, and have only needed to slightly touch the needles 1 time since I bolted it on. This is my 1st new gas engine and I would buy another one in a heart beat...
Good luck with your decision.
Fr
Old 08-25-2009, 10:16 AM
Tired Old Man
Why would you consider buying a used engine that has known problems??????
Old 08-25-2009, 10:54 AM
outssider
My Feedback: (23)
i have a mt57 you can have cheap. It has transition problems too! went back for service...same thing....bad transition....
Old 08-26-2009, 11:36 AM
farooq
Did you guys try with the timing adjustment with MT-57
Old 08-26-2009, 04:49 PM
Super08
Super08's Avatar
I have mine timed at 30. I just got back from flying my Python which has the MT57 in it. It is running like a swiss watch as the saying goes. Switched to a 22x10 Xoar carbon fiber prop for the last two flights and my god does it pull hard. My suggestion to go with the DL50/55 is for a person that is new to gas engines. The DL is a little more user friendly in my opinion, and not because I don't like my MT57, which I do. As for performance f find the MT pulls just a few rpm more than a DL on the same day with the same prop. I own both and like them both. As for the DL55 I haven't used one yet, some say they have no more power than the 50 and some say they do.
Old 08-27-2009, 06:53 AM
farooq
Super08
What about the vibration and engine transition.
Old 08-27-2009, 07:14 AM
Super08
Super08's Avatar
Mine had vibration at the start but not anymore. The transition is good, no burbles and very fast. I think most of the problems were with the first run of engines early last year when it first hit the market.
Old 08-27-2009, 10:55 AM
Hughes500E
My Feedback: (16)
Hughes500E's Avatar
MT 57 engine here as well, mine is running very well. All the DL engines I have been around run well but definitely less power. I have one of the original engines timed at 27 degrees on my Extreme Flight Yak, I enjoy it!
Old 12-29-2009, 01:04 AM
unit53
Hey there everyone,,happy new years in advance,,,in response to the topic question,,i feel the dl may be a little more rugged in appearance and in service,but the mt has the thumbs up on the preference,for power and when properly tuned runs like the 600.00 50cc that others rave over,regardless of the issues from a certain dealer who didnt fully repair my motor,i ,can only assume that quality control is being implemented now that it appears the engine line is expanding,the omly thing i could reccomend as a non expert in all the technical aspects of everything supporting a particular engine,,is quality control,such as out of center cranks or leaky case,seals ,,i would,hope they  tommy would test run ,instead of sending an untested motor.and lastly the spreader plates that are found at paragon and other vendors,,should come standard,,,im certain others have had perfect service from their mt57,,and regardless of my personal issues ive had i still like the motor and i also realize the first version and the timing defects have been addressed along with the case crack problems have been addressed,and what ill most likely have to do is see if i can get lspro or another vendor to honor any warranty issues,because theres no way ill ever deal with ,,the previous guy who patted himself on the back for a shabby repair job.so thats my story .bottom line mt 57 is a great motor when all is per specs.and in many ways despite the price difference is a better than a da
Old 12-29-2009, 01:22 AM
unit53
oh i forgot to add ,,a slanted plug hole to accept a cm6 plug wouldnt be bad either
Old 12-29-2009, 06:56 AM
closetguy
My Feedback: (13)
I had a MT57 actually had two of them,one was a replacement engine from Tommy.He gave me a new one to replace the first one that had a crack case.
One strong engine never dead stick,great transition,no burble when the needles are set rite,doesn't die or want to stop when inverted,BUT the thing would shake like a dog *****en bones.Loosen up two air frames that i had it on.
7250 on a Vess23-a,i would buy the DL55,but i would never buy another china made engine.
Old 12-29-2009, 08:42 AM
K-Bob
Um...........did you just say that if it weren't for the out of center cranks, leaky case seals, the need for third party modifications, case cracks, timing defects, and poor service, they were just as good as a DA50?
OK. Just wanted to make sure.
Old 12-29-2009, 01:10 PM
georgee
ORIGINAL: closetguy
7250 on a Vess23x6 ?Not bad nr s at all.Well, my veryfirst DL50 engine after cca.450 take offs is turning a 23x8 METTS wood prop cca. 7000-7050 rpms.
My 3 DLE 55 s are still in the break in period,these are turning usually in the 7500-7600 rpm range with a 22x8 wood prop, without excess shaking and transition problems
Old 12-29-2009, 03:35 PM
closetguy
My Feedback: (13)
ORIGINAL: K-Bob
OK. Just wanted to make sure. [img][/img]
I should have made myself more clear.I was telling Eganwp that the dl55 is a much better engine and thats the one i would buy.
But that will never happen again because IMO i think ALL china made engines are ment to be disposable engines.If a guy had tools to make the cylinders round and not almost round like they come out of china and replace the bearings with better made ones, that will last for more than two seasons,they might be worth the 350.00.But why would you rebuild a engine that the cylinder is out of round to begin with.
One thing i did notice is that the MT57 had twice the compression of any DL50 that i flip over at the field, but that doesn't make it better.
Old 01-01-2010, 03:49 AM
erieqc
Hey Dan
Have you guys been flying out at the 250 runway.
Old 01-01-2010, 06:38 AM
w8ye
My Feedback: (16)
w8ye's Avatar
Chapin Airport south of town?
Old 01-01-2010, 08:26 AM
closetguy
My Feedback: (13)
Yep,sounds like Jim already knows where it's at already.Not a bad place to fly,runway goes east-west,and it's about 3/4 of a mile long paved strip.The only bad thing is that you half to face south to fly,always looking into sun and house's are north of you so can't fly there.
Just payed dues to Willard club so i will still fly there,but they will half to get someone else to mow the field this year i did it for the last three years.
Old 01-02-2010, 04:47 AM
erieqc
I didn't make it out there much this year because of the hours plan on going more this year. I have to wait and see what happens. I dodn't know if I'm going to join WEillard this year or not yet. Time will tell.
Bill
Old 01-07-2010, 01:56 PM
Matt
Question..........on a DLE 55cc gas engine, would a 23x8 Beechwood, Xoar propeller be good to use with out over reving?
