Two Stroke Oil Detectives - a new project!
My Feedback: (9)
WA
I was at our local ACE hardware the other day and noticed that they now have some store brand 2 stroke synthetic oil that is biodegradable. I'll post a pic later in the day if I can. I wonder if this is the same stuff as Stihl Ultra?
Sam
Sam
RE: Two Stroke Oil Detectives - a new project!
ORIGINAL: Jezmo
Is Stihl HP Ultra biodegradeable? I haven't read that anywhere in the literature; coulda just missed it though.
My Feedback: (9)
WA
Here are some pix of the oil. Any way to tell if it's made by the same company that makes Stihl's oil? It's $1.49 per bottle at Ace.
Sam
Sam
I don't think it's the same as Stihl. Stihl oil carries the JASO FB and API TC/TC+ certifications. The Ace oil is marketed by Green Earth Technologies and carries the JASO FD and API TC certifications. Stihl is bottled by BP Lubricants USA/Castrol, can't tell where the Ace oil is bottled. They also have other differences like flash point, viscosity, and pour temperature, as shown in the attached graph. I'm also pretty sure the Ace oil is not synthetic, it's maketing literature brags that it is "grown" in the USA,[sm=50_50.gif]. Give it whirl and see what you think, it being a vegetable base stock oil I might mix it at 40:1 to be on the safe side to start with.
ORIGINAL: jedijody
Yes, it is, http://www.stihlusa.com/accessories/twocycleoil.html
ORIGINAL: Jezmo
HP Ultra is a fully synthetic 2-cycle engine oil specially suited for high performance chain saws and power tools. This oil has outstanding engine cleaning characteristics, plus “ultra” superior lubricating qualities in comparison to other 2-cycle engine oils. It is ideal for use in STIHL 4-MIX® engines. This oil is biodegradable, degrading by 80% in 21 days.
STIHL recommends a mix of 50:1 high-quality 89 octane or higher unleaded gasoline to STIHL engine oil. This same mix ratio should be used during break-in.
Also good for break-in they claim!!! Capt,n[X(]
My Feedback: (9)
WA
I have a tendency to buy too much oil at a time and I really don't like switching brands. I don't fly enough to burn through tons of it. I am using Pennzoil for break in and after a gallon or so I will be switching to the Husqvarna HP, which I have a gallon of! When that is done, I'll certainly try the Stihl Ultra, but at the rate I use oil, it could be a few years and maybe there will be a new elixir available by then.
Sam
Sam
My Feedback: (43)
TX
FWIW, my local stihl dealer gave me some grief when I tried to buy the ultra this summer. Seams they had been instructed to only sell it for use with their 4-MIX® engines. I went back later, avoided the question and bought some from a different counterman. Haven't used it yet, still finishing off my supply of a another brand of synthetic.
My Feedback: (19)
ORIGINAL: catfish2
Now can someone suggest why this oil isn't a good oil? Just a conversation starter on my part as I really don't care. There are plenty of oils out there that suit our purposes just fine.
Jody, can you give us a bit more on the Stihl orange bottle oil? Can you be more specific on how the performance and residue characteristics are different from Pennzoil? Does it leave more residue? Are we talking about wear performance or performance as in more power?
Hope you can clarify this a little.
My Feedback: (41)
ORIGINAL: Jezmo
ORIGINAL: Jezmo
Karol
Ok, I'm not any kind of chemist, or oil expert, all I can do is describe what I've seen in engines you guys send me. First though I will say I've never used the Stihl oil in the orange bottle (mineral) or the black bottle (mineral/synthetic blend), I prefer synthetics. They are much better under high stress and heat situations. Once you see the inside of enough engines and ask some questions it's easy to tell what oil was run in some engines just by looking at the inside. Although wear is minimal, piston skirts and bearings are well protected, and combustion chamber and exhaust port carbon accumulations are thin and relatively easy to remove, Penzoil pistons have some of the worst staining and carbon just below the ring that I’ve seen. There is also more carbon in the crankcase and overall a dirtier engine interior, not a big deal, just an observation.
The inside of engines running on synthetic oils are typically much cleaner, little to no carbon below the ring, clean oil in crankcase, less accumulation in the combustion chamber and exhaust port. The synthetics do not coke as easily and some of them just go out the exhaust in close to the same shape they went in helping to flush loose dirt and carbon out of the engine. Over time, mineral oil deposits add up and if enough accumulation is on the side of the piston it will start to displace the oil. This takes a long time and most of our engines have other issues before that is a problem. But any time you can minimize contaminants in an engine it will have less wear and last longer. T.O.M. posted some excellent examples of pistons with about 500 hours on them that had been run on synthetic oil (Stihl HP Ultra) and although there is a bit more carbon on the exhaust side of the dome, you can actually see through the carbon on the rest of the piston top. since he already posted them in a public forum I'm sure he won't mind me showing them again. The second piston is one that ran Penzoil but for only about 5 gallons, with more time the stains get darker and some accumulation develops. I don't want anyone thinking that I don't like Penzoil oil because I do, but, I think there are many mineral oils that work just as well and if one of those is more convenient and affordable for you then you could do much worse. I also don't want to sound like I own stock in Stihl, but people ask me all the time what I use so what am I to do. Stihl just happens to the most convenient quality oil for me to get and it's not too expensive. I would have no problem using any one of several different synthetics if they were easier for me to get.
My Feedback: (24)
TN
ORIGINAL: captinjohn
STIHL HP Ultra 2-Cycle Engine Oil
ORIGINAL: jedijody
ORIGINAL: Jezmo
My Feedback: (24)
TN
ORIGINAL: jedijody
It does not degrade until you pour it out on the ground or otherwise expose it to the elements ie; sun, water, earth. It keeps just fine all winter long in my weed whacker/chainsaw fuel jug.
