Mustang 50 engine help
ID
Hi Guys
I was at a flyin last weekend and a friend has a mustang 50 in a Bravo, the combo is great. He started having some issues last year with it and another fellow was trying to sort it out, but I guess didn't get it done.
Top end and midrange runs fine and for that matter so does the bottom end, but heres the deal when coming in for a landing the engine will die most of the time,( its not idled down to slow either) I did open the bottom end up a little thinking it may have been lean and reset the top, seems as though the 2 needles over lap each other quite alot in this engine.
I know the carb had a rebuild last year by the guy that was trying to sort it out. He dosen't have a tube soldered on the diaphram cover yet and ran into the fuse but i'm thinking that may be next. IMHO I still think its the needles.
Any suggestions would be appreciated
RE: Mustang 50 engine help
If it runs and idles well on the ground, but not in the air, you can be certain it is a carb reference pressure issue. At least run a line in the fuselage. Better still, connect it to a static tube (part of pitot tube system)
ID
Thats the puzzeling part, it seems to run good in the air as well on the ground untill the landings and it will die about 1/2-2/3's of the time.
It has all new linkage and a good servo operating things ,so I don't think its a slop problem,but again I was going off what I was told and didn't see it first hand.
I did notice when going from full throttle on the ground to idle the engine would go to a slower RPM than normal and gradually pick back up, thus thinking it may have been to lean on the bottom.
Thanks for the info I told him about the tube and line going to a bottle which I use on all my gas engines but the owner had that deer in the headlights look on his face.
